UF20.241
UF20.241
    PULS
    BUFFERMODULE24-28VDC20A
UF20.241 数据手册
UF20.241 24V, 20A, 200MS, BUFFER MODULE UF-Series BUFFER MODULE       Buffering with electrolytic capacitors instead of lead acid batteries Buffering of 24V loads Minimum hold-up time 0.2s at 20A, longer hold-up time at lower loads Clear status indication by status LED and signaling terminals Quick-connect spring-clamp terminals 3 Years warranty GENERAL DESCRIPTION SHORT-FORM DATA The UF20 buffer module is a supplementary device for regulated DC 24V power supplies, which can be used for various purposes: - Deliver DC-power to bridge failures of the DC voltage supply system. - Extend the hold-up time after loss of the AC power. - Deliver extra short-term peak current above the current rating of the power supply. Supply voltage Required voltage to charge capacitors Threshold voltage for buffer mode Buffer voltage Buffer current Charging time Current consumption It utilizes service-free electrolytic capacitors for storing the energy which allows usage even at ambient temperatures up to +70°C. The buffer module does not require any control wiring. It can be added in parallel to the load circuit at any given point. Power dissipation Buffer time Buffer modules can be connected in parallel to increase the output ampacity or the hold-up time. Temperature range Dimensions Weight ORDER NUMBERS DC 24V -20%/+25% 19.2-30Vdc 23Vdc 22.5V / VIN-1V Selectable 22.5V / VIN-1V 20A Typ. 18s Typ. 80mA Max. 600mA 1.9W Min. 200ms Min. 430ms Typ. 310ms Typ. 670ms Typ. 43s -25°C to +70°C 64x124x102mm 740g / 1.63lb Selectable Stand-by mode During charging Stand-by mode At 22.5V, 20A At 22.5V, 10A At 22.5V, 20A At 22.5V, 10A At 22.5V, 0.1A Operational WxHxD MARKINGS Buffer Module UF20.241 Accessory ZM1.WALL ZM14.SIDE Panel/ wall-mount bracket Side-mount bracket IND. CONT. EQ. UL 508 UL 60950-1 Oct. 2016 / Rev. 2.0 DS-UF20.241-EN All parameters are specified at 24V, 20A, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany EMC 1/18 UF20.241 24V, 20A, 200MS, BUFFER MODULE UF-Series INDEX Page 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. Intended Use .......................................................3 Installation Notes ................................................3 Functional Description ........................................4 Electrical Ratings .................................................5 Selection of the Back-up Threshold Voltage .....6 Buffer Time ..........................................................6 Charging Time .....................................................7 Operating Diagrams............................................7 Active Signal ........................................................8 Ready Signal ........................................................8 Inhibit Input.........................................................8 Efficiency and Power Losses................................9 Lifetime Expectancy and MTBF...........................9 Functional Diagram...........................................10 Page 15. Terminals and Wiring ....................................... 10 16. Front Side and User Elements .......................... 11 17. EMC ................................................................... 12 18. Environment ..................................................... 13 19. Protection Features .......................................... 13 20. Safety Features ................................................. 13 21. Dielectric Strength............................................ 14 22. Approvals .......................................................... 14 23. Physical Dimensions and Weight ..................... 15 24. Accessories ........................................................ 16 24.1. ZM1.WALL - Wall mounting bracket ....... 16 24.2. ZM14.SIDE - Side Mounting Bracket ........ 17 25. Wiring Diagrams............................................... 18 The information given in this document is correct to the best of our knowledge and experience at the time of publication. If not expressly agreed otherwise, this information does not represent a warranty in the legal sense of the word. As the state of our knowledge and experience is constantly changing, the information in this data sheet is subject to revision. We therefore kindly ask you to always use the latest issue of this document (available under www.pulspower.com). No part of this document may be reproduced or utilized in any form without our prior permission in writing. Some parts of this unit are patent by PULS (US patent No 091662,063, Des. 424,529, …). TERMINOLOGY AND ABREVIATIONS Power supply mode Describes a condition where the supply voltage is in the rated supply voltage range and the supplying power supply can deliver a sufficient amount of current for the buffer module and the load. The mode can also be called “Normal mode”. Buffer mode Describes a condition where the input voltage is below the transfer threshold level, the unit is running on capacitors (buffering) and the output is loaded within the allowed limits. The mode can also be called “Capacitor mode”. Inhibit mode Describes a condition where buffering is disabled on purpose (e.g. for service actions). T.b.d. To be defined, value or description will follow later. DC 24V A figure displayed with the AC or DC before the value represents a nominal voltage with standard tolerances included. E.g.: DC 12V describes a 12V battery disregarding whether it is full (13.7V) or flat (10V). 24Vdc A figure with the unit (Vdc) at the end is a momentary figure without any additional tolerances included. may A key word indicating flexibility of choice with no implied preference. shall A key word indicating a mandatory requirement. should A key word indicating flexibility of choice with a strongly preferred implementation. Oct. 2016 / Rev. 2.0 DS-UF20.241-EN All parameters are specified at 24V, 20A, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 2/18 UF20.241 UF-Series 24V, 20A, 200MS, BUFFER MODULE 1. INTENDED USE This device is designed for installation in an enclosure. Use an appropriate enclosure which protects against mechanical, electrical and fire hazards. This device is intended for professional use in areas such as in industrial control, office, communication, and instrumentation equipment. Do not use this device in equipment or systems where malfunction may cause severe personal injury or threaten human life. 2. INSTALLATION NOTES This device may only be installed and put into operation by qualified personnel. This device does not contain serviceable parts or fuses. If damage or malfunction should occur during installation or operation, immediately turn power off and send unit to the factory for inspection. The unit must be powered from a SELV source (according to IEC 60950-1), PELV source (according to IEC 62477-1) or an Isolated Secondary Circuit (according to UL 508) power source. Use DIN-rails according to EN 60715 with a height of 7.5 or 15mm. Mounting orientation must be power terminals on top of the unit. Do not obstruct air flow as the unit is convection cooled. Ventilation grid must be kept free of any obstructions. Signal lines (ready, active and inhibit) must be shorter than 30m. Use an appropriately sized power supply, which can deliver the additional required internal current consumption (including the charging current) specified as input current in the table of chapter 4 and Fig. 4-1. The following installation clearances must be maintained: - Left / right: 0mm - On top of the unit: 40mm - On bottom of the unit: 20mm Agency approvals apply only for altitudes up to 2000m. Maximum surrounding air temperature: +70°C / +158°F. Caution for Canada: For use in a controlled environment according to CSA 22.2 No 107.1-01. WARNING - Risk of electrical shock, fire, personal injury or death. Turn power off before working on the device. Protect against inadvertent re-powering. Make sure that the wiring is correct by following all local and national codes. Do not modify or repair the unit. Do not open the unit as dangerous voltages may be present inside. Use caution to prevent any foreign objects from entering the housing. Do not use in wet locations or in areas where moisture or condensation can be expected. Do not touch during power-on, and immediately after power-off. Hot surfaces may cause burns. Oct. 2016 / Rev. 2.0 DS-UF20.241-EN All parameters are specified at 24V, 20A, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 3/18 UF20.241 24V, 20A, 200MS, BUFFER MODULE UF-Series 3. FUNCTIONAL DESCRIPTION Working principle When the power supply provides sufficient voltage, the buffer module stores energy in the integrated electrolytic capacitors. In case of a voltage dip or loss, this energy is released to the DC bus in a regulated process. Bridges mains faults without interruption Statistic show that 80% of all mains fault lasts less than 0.2s. These mains faults are completely bridged by the buffer unit. This increases the reliability of the system as a whole. optional - AC DC Buffer Module Power Supply AC Buffer Module Load + - DC Transfer Threshold Load + - + L PE + N Buffer Module Fig. 3-2 Transfer behavior Power Supply Output Buffer Module Discharge DC Easy to handle, expandable and maintenance-free The buffer module does not require any control wiring. It can be added parallel to the load circuit at any given point. Buffer modules can be connected in parallel to increase the output ampacity or the hold-up time. Power Supply Storage AC Extended hold-up time Once mains power fails or is switched off, the buffer unit will continue to provide the load current for a defined period of time. Process data can be saved and processes can be terminated before the DC power switches off. Controlled restarts are subsequently possible. Fig. 3-1 Typical wiring diagram Charge DC - t Supply Voltage Power Supply Mode Buffer Mode Oct. 2016 / Rev. 2.0 DS-UF20.241-EN All parameters are specified at 24V, 20A, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany Power Supply Mode t 4/18 UF20.241 24V, 20A, 200MS, BUFFER MODULE UF-Series 4. ELECTRICAL RATINGS Supply voltage Supply voltage range1) Normal operating voltage range2) Transfer voltage for switching into buffer mode Nom. Nom. Typ. Typ. Typ. Transfer voltage for switching from buffer mode into power supply mode Typ. Typ. Buffer voltage Ripple and noise voltage - in buffer mode - in power supply mode Current consumption Typ. Max. Power dissipation Buffer current Buffer current overload behavior Allowed voltage between supply voltage and chassis ground Capacitive and inductive loads Typ. Min. Max. Typ. Min. Max. DC 24V -20%/+25% 19.2 - 30Vdc 23 – 30Vdc 22.5Vdc VIN – 1V Back-up threshold jumper set to “22.5V fixed” Back-up threshold jumper set to “VIN – 1V” See also chapter 5. Back-up threshold jumper set to “22.5V fixed” 22.5Vdc Back-up threshold jumper set to “VIN – 1V” VBUFFER + 1V See also chapter 5. Same as the transfer voltage for switching into buffer mode. 200mVpp Generated by the buffer module. Defined at 20Hz to 20MHz, 50Ohm The ripple and noise voltage is defined by the power supply. 80mA When capacitor is fully charged 400mA During charging of the capacitors 600mA During charging of the capacitors 1.9W When capacitor is fully charged 20A Electronically limited, buffering stops and capacitor gets discharged below 17V. See Fig. 4-2. 60Vdc or Continuous, IEC 62477-1 42.4Vac No limitation 1) Supply Voltage Range: At voltages within the input voltage range, control functions such as LEDs, monitoring features, relay contacts, etc. are functioning normally. Within the input voltage range the unit can either be in power supply mode or in buffer mode. 2) Normal Operating Voltage Range: The normal operating voltage range describes the supply voltage, which supports the full functionality of the buffer module (including charging) but without entering the buffer mode. Fig. 4-1 Selection of an appropriate power supply Fig. 4-2 Output characteristic in buffer mode, 22.5V fixed mode, typ. Buffer Voltage 28V Power Supply Current Load Current 24 22.5V 20 16 12 Internal current consumption Current consumption for charging Buffering stops below 17V 8 4 0 Output Current 0 4 8 12 16 20 24 Oct. 2016 / Rev. 2.0 DS-UF20.241-EN All parameters are specified at 24V, 20A, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 28 32A 5/18 UF20.241 24V, 20A, 200MS, BUFFER MODULE UF-Series 5. SELECTION OF THE BACK-UP THRESHOLD VOLTAGE The buffer behavior can be selected with the back-up jumper selector between “Fixed Mode” and “Variable Mode”. Fixed Mode: (Jumper in position „2-3“ or „22.5V fixed”) If the supply output voltage falls below 22.5V, buffering starts and the supply voltage will be kept at this level. This adjustment is recommended: - when power supplies other than the DIMENSION Q-series are used - with back-feeding loads - when the buffer module is placed close to the load or - whenever in doubt. Variable Mode: (Jumper in position „1-2“ or „VIN – 1V”) Buffering starts if the supply voltage decreases by more than 1V. Buffering ends when supply voltage increases by more than 1V Voltage changes slower than 0.54V/s will be ignored if the voltage is above 22.5V. Below 22.5V buffering starts immediately. This adjustment is recommended for any application where 22.5V is too low for the application or when the buffer module is placed close to the power supply. The factory setting is fixed mode, A missing jumper means also fixed mode. 6. BUFFER TIME The buffer time (sometimes also called autonomy time) is the maximum period of time for which the capacitor can maintain the required output current. The buffer time mainly depends on the output current in buffer mode. To increase the buffer time any given number of buffer modules can be connected in parallel. Buffer time Min. Min. Typ. Typ. Typ. 200ms 430ms 310ms 670ms 43s Fig. 6-1 Buffer time, typ. At 22.5V, 20A At 22.5V, 10A At 22.5V, 20A At 22.5V, 10A At 22.5V, 0.1A Fig. 6-2 Buffer time for small buffer currents, typ. Buffer Current, typ. Buffer Current, typ. 20A 2.0A 15 1.5 10 1.0 5 0.5 0 0 0 0.3 0.6 0.9 1.2 1.5 1.8 2.1 2.4 2.7 3s Buffer Time 3 6 9 12 Oct. 2016 / Rev. 2.0 DS-UF20.241-EN All parameters are specified at 24V, 20A, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 15 18s Buffer Time 6/18 UF20.241 24V, 20A, 200MS, BUFFER MODULE UF-Series 7. CHARGING TIME Charging of the internal capacitors is indicated by the status LED, which is flashing with a slow frequency (1.25Hz). Charging time Min. Max. Min. Max. 20s 29s 15s 21s Initial charging 1) Initial charging 1) Re-charging 2) Re-charging 2) 1) Initial charging is the first charge after voltage is applied to the buffer module. 2) Re-charging is the charging of the internal capacitors after voltage interruptions shorter than 2minutes. Fig. 7-1 Charging time, re-charging Charge min. 100% max. 80 60 40 Charging Time 20 0 5 10 15 20 25 30s 8. OPERATING DIAGRAMS Fig. 8-1 Operating diagram V V Fig. 8-2 Signal schematic Hold-up Time Power Supply Mains t Buffer Capacitor 6 + t 7 Active Vout Ready Optocoupler high ohmic Active Optocoupler high ohmic t Optocoupler low ohmic 8 Ready t 5,1V Optocoupler low ohmic LED 1.25Hz 10Hz t 3mA UF20 9 Inhibit t Charging Mode Standby Mode Buffer Mode Oct. 2016 / Rev. 2.0 DS-UF20.241-EN All parameters are specified at 24V, 20A, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 7/18 UF20.241 24V, 20A, 200MS, BUFFER MODULE UF-Series 9. ACTIVE SIGNAL The signal “Active” (pin 7) is an opto-coupler output which is low ohmic while buffer capacitors are discharged. Wiring scheme see Fig. 8-2, Fig. 25-1 and Fig. 25-2. Signal voltage Signal current Voltage drop across opto-coupler Leakage current Isolation voltage Max. Max. 35Vdc 10mA 0.9V / 3V Max. 50µA See chapter 21. Voltage between pin 6 and 7 At 1mA / 5mA while opto-coupler is low ohmic While opto-coupler is high ohmic 10. READY SIGNAL The signal “Ready” (pin 8) is an opto-coupler output which is low ohmic when buffer capacitors are fully charged. Wiring scheme see Fig. 8-2, Fig. 25-1 and Fig. 25-2. Signal voltage Signal current Voltage drop across opto-coupler Leakage current Isolation voltage Max. Max. 35Vdc 10mA 0.9V / 3V Max. 50µA See chapter 21. Voltage between pin 6 and 8 At 1mA / 5mA while opto-coupler is low ohmic While opto-coupler is high ohmic 11. INHIBIT INPUT Buffering can be disabled or interrupted with the inhibit input (pin 9). Therefore, pin 6 should be connected to the positive pole of the terminal voltage or to the external control voltage and pin 9 must be connected to the corresponding negative pole. Inhibiting the unit also discharges the internal capacitors. Charging of the capacitor is not possible when the buffer module is in inhibit mode. Wiring scheme see Fig. 8-2, Fig. 25-1 and Fig. 25-2. Signal voltage Signal current Inhibit mode Max. Max. 35Vdc (between pin 6 and pin 9) 4mA, current limited Isolation voltage See chapter 21. The unit does not buffer (or stops buffering) if the voltage between pin 6 and pin 9 is higher than 10V. Below 6V buffering will function again. Oct. 2016 / Rev. 2.0 DS-UF20.241-EN All parameters are specified at 24V, 20A, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 8/18 UF20.241 24V, 20A, 200MS, BUFFER MODULE UF-Series 12. EFFICIENCY AND POWER LOSSES Efficiency Typ. >99% Power losses Typ. 1.9W Power supply mode, 20A output current, capacitors fully charged Power supply mode, 0A output current, capacitors fully charged 13. LIFETIME EXPECTANCY AND MTBF Calculated lifetime expectancy*) MTBF**) SN 29500, IEC 61709 MTBF**) MIL HDBK 217F 166 000h*) 469 000h*) 2 327 000h 4 219 000h 398 000h 624 000h 132 000h 195 000h Stand-by mode, 40°C Stand-by mode, 25°C Stand-by mode, 40°C Stand-by mode, 25°C Stand-by mode, 40°C, Ground Benign GB40 Stand-by mode, 25°C Ground Benign GB25 Stand-by mode, 40°C, Ground Fixed GF40 Stand-by mode, 25°C Ground Fixed GF25 The calculated lifetime expectancy shown in the table indicates the minimum operating hours (service life) and is determined by the lifetime expectancy of the built-in electrolytic capacitors. Lifetime expectancy is specified in operational hours and is calculated according to the capacitor’s manufacturer specification. The manufacturer of the electrolytic capacitors only guarantees a maximum life of up to 15 years (131 400h). Any number exceeding this value is a calculated theoretical lifetime which can be used to compare devices. **) MTBF stands for Mean Time Between Failure, which is calculated according to statistical device failures, and indicates reliability of a device. It is the statistical representation of the likelihood of a unit to fail and does not necessarily represent the life of a product. The MTBF figure is a statistical representation of the likelihood of a device to fail. A MTBF figure of e.g. 1 000 000h means that statistically one unit will fail every 100 hours if 10 000 units are installed in the field. However, it can not be determined if the failed unit has been running for 50 000h or only for 100h. *) Oct. 2016 / Rev. 2.0 DS-UF20.241-EN All parameters are specified at 24V, 20A, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 9/18 UF20.241 24V, 20A, 200MS, BUFFER MODULE UF-Series 14. FUNCTIONAL DIAGRAM Fig. 14-1 Functional diagram + Supply + Voltage - Status LED Buffer Capacitor Charger & Inrush Limiter ReversePolarity Protection Safety and OverVoltage Protection Buffer Capacitor Discharger Buffer Capacitor Shut-Down Buffer Capacitor Chassis Ground 6 (+) 9 Inhibit Opto-coupler Input / Output Voltage Monitor Back-up Level Selector + - 8 Ready Ready Monitor Opto-coupler + - 7 Active Active Monitor Opto-coupler 15. TERMINALS AND WIRING The terminals are IP20 finger safe constructed and suitable for field and factory wiring. Type Solid wire Stranded wire American Wire Gauge Max. wire diameter Wire stripping length Tightening torque Screwdriver Supply voltage, chassis ground Quick-connect spring-clamp terminals Max. 6mm2 Max. 4mm2 Max. AWG 20-10 Max. 2.8mm (including ferrules) Typ. 10mm / 0.4inch Not applicable Not applicable Signals Pluggable screw terminals Max. 2.5mm2 Max. 2.5mm2 AWG 22-14 2.25mm (including ferrules) 6mm / 0.25inch 0.4Nm / 3.5lb.inch 3mm slotted Instructions: a) Use appropriate copper cables that are designed for minimum operating temperatures of: 60°C for ambient up to 45°C and 75°C for ambient up to 60°C and 90°C for ambient up to 70°C minimum. b) Follow national installation codes and installation regulations! c) Ensure that all strands of a stranded wire enter the terminal connection! d) Unused terminal compartments should be securely tightened or closed. e) Ferrules are allowed. Oct. 2016 / Rev. 2.0 DS-UF20.241-EN All parameters are specified at 24V, 20A, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 10/18 UF20.241 24V, 20A, 200MS, BUFFER MODULE UF-Series 16. FRONT SIDE AND USER ELEMENTS Fig. 16-1 Front side A Supply Voltage Terminals Quick-connect spring-clamp terminals, two per polarity + Positive supply voltage terminal – Negative (return) supply voltage terminal B Chassis Ground Terminal Quick-connect spring-clamp terminals Connection of the chassis to ground (earth) is optional and only required for a few specific applications. C Signal Connector 4-pole plug connector with screw termination comprises the following signals: - “Active” signal, for details see chapter 9. - “Ready” signal, for details see chapter 10 - “Inhibit” input, for details see chapter 11 D Status LED This green LED indicates that the following information: - OFF: Capacitors are discharged or supply voltage is below 22V. - ON: Capacitors are fully charged - Slow flashing (1.25Hz): Capacitors are getting charged. - Fast flashing (10Hz): Capacitors are getting discharged. E Back-up Threshold Jumper Option 1: Fixed mode (Jumper in position 2-3) The unit switches to buffer mode as soon as the voltage falls below 22.5V. Option 2: Variable mode (Jumper in position 1-2) Unit switches to buffer mode when input voltage decreases by 1V. Voltage changes slower than 0.54V/s will be ignored if the voltage is above 22.5V. Below 22.5V buffering starts immediately. For more details see chapter 5. Oct. 2016 / Rev. 2.0 DS-UF20.241-EN All parameters are specified at 24V, 20A, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 11/18 UF20.241 24V, 20A, 200MS, BUFFER MODULE UF-Series 17. EMC The buffer module is suitable for applications in industrial environment as well as in residential, commercial and light industry environment. EMC Immunity for all operating modes Electrostatic discharge According to generic standards: EN 61000-6-1 and EN 61000-6-2 Electromagnetic RF field Fast transients (Burst) EN 61000-4-3 EN 61000-4-4 Surge voltage on supply voltage terminals Surge voltage on inhibit input, active signal and ready signal Conducted disturbance EN 61000-4-5 EN 61000-4-2 EN 61000-4-5 EN 61000-4-6 Contact discharge *) 8kV Criterion A Air discharge *) 15kV Criterion A 80MHz-2.7GHz 10V/m Criterion A Input lines 2kV Criterion A Output lines 2kV Criterion A Signals lines pin 6, 7, 8, 9 **) 2kV Criterion A +0.5kV Criterion A + / -  chassis ground 1kV Criterion A Not applicable since length of signal wire specified shorter than 30m. 0.15-80MHz 10V Criterion A *) Chassis ground connection earthed (grounded) **) Tested with coupling clamp Criterions: A: Buffer module shows normal operation behavior within the defined limits. According to generic standards: EN 61000-6-3 and EN 61000-6-4 EMC Emission for standby- and charging mode Conducted emission, IEC/CISPR 16-1-2, IEC/CISPR 16-2-1 Limits for DC power ports acc. EN 61000-6-3 supply voltage fulfilled Radiated emission EN 55011, EN 55022 Class B This device complies with FCC Part 15 rules. Operation is subjected to following two conditions: (1) this device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation. Switching Frequency The buffer module has two converters with variable frequencies included. 6 to 610kHz Charging converter at 24V input (is only active during charging) The frequency depends on the state of charge of the capacitors 10 to 70kHz Buffer converter at buffering at 22.5V The frequency depends on the output current. The values are between 10% and 100% of the nominal buffer current Oct. 2016 / Rev. 2.0 DS-UF20.241-EN All parameters are specified at 24V, 20A, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 12/18 UF20.241 24V, 20A, 200MS, BUFFER MODULE UF-Series 18. ENVIRONMENT Operational temperature *) Storage temperature Humidity **) Vibration sinusoidal Vibration random Shock Altitude Over-voltage category Degree of pollution LABS compatibility -25°C to +70°C (-13°F to 158°F) -40 to +70°C (-40°F to 158°F) For storage and transportation 5 to 95% r.H. IEC 60068-2-30 2-17.8Hz: ±1.6mm; 17.8-500Hz: 2g IEC 60068-2-6 2 hours / axis 0.5m²(s³) IEC 60068-2-64 2 hours / axis 30g 6ms, 20g 11ms IEC 60068-2-27 3 bumps / direction, 18 bumps in total 0 to 6000m (0 to 20 000ft) Approvals apply only up to 2000m III IEC 62103, EN 62477-1 II IEC 62103, EN 62477-1, above 2000m altitude 2 IEC 62103, EN 62477-1, not conductive The unit does not release any silicone or other LABS-critical substances and is suitable for use in paint shops. *) Operational temperature is the same as the ambient or surrounding temperature and is defined as the air temperature 2cm below the unit. **) Do not energize while condensation is present 19. PROTECTION FEATURES Electrical protection Over-voltage protection in buffer mode Degree of protection Penetration protection Reverse polarity protection Input overvoltage protection Internal input fuse Electronically protected against overload, no-load and short-circuits Typ. 32Vdc In case of an internal buffer module defect, a redundant circuit limits the maximum output voltage. Max. 35Vdc Buffering stops and automatically attempts to restart. IP 20 EN/IEC 60529 > 3.5mm E.g. screws, small parts Yes Max. -35V Yes Max. 35V, no harm or defect of the unit Not included 20. SAFETY FEATURES Class of protection Isolation resistance Chassis ground terminal resistance No classification according to IEC 61140 or IEC 60950-1 possible > 500MOhm > 500MOhm > 500MOhm < 0.1Ohm Install the buffer module according to Class III rules Supply voltage to signal port Supply voltage to housing Signal port to housing Between housing and chassis ground terminal Oct. 2016 / Rev. 2.0 DS-UF20.241-EN All parameters are specified at 24V, 20A, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 13/18 UF20.241 24V, 20A, 200MS, BUFFER MODULE UF-Series 21. DIELECTRIC STRENGTH The signal port (active and ready signal and inhibit input) is floating and separated from the supply voltage. Type and factory tests are conducted by the manufacturer. Field tests may be conducted in the field using the appropriate test equipment which applies the voltage with a slow ramp (2s up and 2s down). Connect all poles of the power port terminals together as well as all poles of the signal port before conducting the test. When testing, set the cut-off current settings to the value in the table below. The following isolation tests were performed: Type test 60s A 500Vac Factory test 5s 500Vac 500Vac 500Vac Field test 5s 500Vac 500Vac 500Vac > 1mA > 1mA > 1mA Fig. 21-1 Dielectric strength Supply Voltage A B Chassis C Cut-off current setting B 500Vac C 500Vac Active and Ready Signal Inhibit Input 22. APPROVALS EU Declaration of Conformity The CE mark indicates conformance with the EMC directive IEC 60950-1 2nd Edition CB Scheme, Information Technology Equipment UL 60950-1 2nd Edition Recognized for use as Information Technology Equipment, U.S.A. (UL 60950-1) and Canada (C22.2 No. 60950-1); E-File: E137006 Listed for use as Industrial Control Equipment; U.S.A. (UL 508) and Canada (C22.2 No. 107-1-01); E-File: E198865 UL 508 IND. CONT. EQ. Oct. 2016 / Rev. 2.0 DS-UF20.241-EN All parameters are specified at 24V, 20A, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 14/18 UF20.241 UF-Series 24V, 20A, 200MS, BUFFER MODULE 23. PHYSICAL DIMENSIONS AND WEIGHT Width Height Depth Weight DIN-rail Housing material Installation clearances 64mm 2.13’’ 124mm 4.88’’ 102mm 4.02’’ The DIN-rail height must be added to the unit depth to calculate the total required installation depth. 740g / 1.63lb Use 35mm DIN-rails according to EN 60715 or EN 50022 with a height of 7.5 or 15mm. Body: Aluminium alloy Cover: Zinc-plated steel See chapter 2 Fig. 23-1 Front view Fig. 23-2 Side view Oct. 2016 / Rev. 2.0 DS-UF20.241-EN All parameters are specified at 24V, 20A, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 15/18 UF20.241 24V, 20A, 200MS, BUFFER MODULE UF-Series 24. ACCESSORIES 24.1. ZM1.WALL - WALL MOUNTING BRACKET This bracket is used to mount the buffer module on a wall without utilizing a DIN-Rail. The two aluminum brackets and the black plastic slider of the unit have to be detached, so that the steel brackets can be mounted. Fig. 24-1 Wall mounting Fig. 24-2 Mounting Dimensions - Wall mounting bracket Oct. 2016 / Rev. 2.0 DS-UF20.241-EN All parameters are specified at 24V, 20A, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 16/18 UF20.241 24V, 20A, 200MS, BUFFER MODULE UF-Series 24.2. ZM14.SIDE - SIDE MOUNTING BRACKET This bracket is used to mount the buffer module sideways with or without utilizing a DIN-Rail. The two aluminum brackets and the black plastic slider of the unit have to be detached, so that the steel brackets can be mounted. For sideway DIN-rail mounting, the removed aluminum brackets and the black plastic slider need to be mounted on the steel bracket. Fig. 24-3 Side mounting without DINrail brackets Fig. 24-4 Side mounting with DIN-rail brackets Fig. 24-5 Mounting Dimensions Side mounting bracket Oct. 2016 / Rev. 2.0 DS-UF20.241-EN All parameters are specified at 24V, 20A, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 17/18 UF20.241 24V, 20A, 200MS, BUFFER MODULE UF-Series 25. WIRING DIAGRAMS optional External Voltage Source Inhibit Ready Relay, lamp or signal Active Relay, lamp or signal 7 Active optional -- +- +- IN 1 IN 2 Adj DC-OK Overload UF20 Back-up Buffer Threshold Module +Buffered Load 6 + OUT + - optional Oct. 2016 / Rev. 2.0 DS-UF20.241-EN All parameters are specified at 24V, 20A, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 ++ 7 Active YR2 Redundancy Module L N PE L N PE -- Status Power Supply 6 + 7 Active UF20 Back-up Buffer Threshold Module +Unbuffered Load 8 Ready ++ ++ Status 9 Inhibit -- 9 Inhibit 6 + 7 Active L N PE 8 Ready UF20 Back-up Buffer Threshold Module Power Supply L N PE ++ Status + Fig. 25-4 Decoupling of buffered branches 8 Ready -- Adj DC-OK Overload 9 Inhibit Load -- UF20 Back-up Buffer Threshold Module L N PE - ++ Status Power Supply L N PE optional ++ -- 6 + Inhibit Load Fig. 25-3 Paralleling of buffer modules +- -- Adj DC-OK Overload +- 9 Inhibit 6 + 9 Inhibit L N PE L N PE ++ UF20 Back-up Buffer Threshold Module Power Supply 7 Active Load ++ Status Ready Relay, lamp or signal -- Active Relay, lamp or signal -- Adj DC-OK Overload 8 Ready ++ +- Fig. 25-2 Signals supplied from an external voltage source 8 Ready Fig. 25-1 General wiring diagram Germany 18/18
UF20.241 价格&库存
很抱歉,暂时无法提供与“UF20.241”相匹配的价格&库存,您可以联系我们找货
