YR40.245
12-28V, 40A, SINGLE REDUNDANCY MODULE
Y-Series
MOSFET REDUNDANCY MODULE
Single Input with Single Output
Equipped with Plug-connector for “Hot Swapping”
Suitable for all DIMENSION Power Supplies
Except QT40 Series
Only 150mV Voltage Drop at 40A
Only 6.2W at 40A
160% (65A) Peak Load Capability
Reverse Input Polarity Protection
Full Power Between -40°C and +60°C
Width only 46mm
Rugged Metal Housing
Easy Wiring:
Distribution Terminal for Negative Pole Included
3 Year Warranty
PRODUCT DESCRIPTION
SHORT-FORM DATA
The YR40.245 is a redundancy module, which can be
used to build redundant systems. The module has one
input and one output and can carry nominal currents up
to 40A. The output is equipped with a plug-connector,
which allows replacing the power supply or the
redundancy module while the system is running (hotswapping)
Input voltage
Input voltage range
Input current
The novelty of this redundancy module is the utilization
of mosfets instead of diodes for the decoupling of the
output. This reduces the heat generation and the
voltage drop between input and output. The
redundancy module does not require an additional
auxiliary voltage.
Output current
Input to output
voltage drop
Power losses
DC 12-28V
8.4-36.4Vdc
0-40A
40-65A
0-40A
40-65A
max. 22A
typ. 80mV
typ. 150mV
typ. 120mW
typ. 1.8W
typ. 6.2W
-40°C to +70°C
1A/°C
46x124x127mm
Due to the low power losses, the unit is very slender and
only requires 46mm width on the DIN rail. Large
connection terminals allow for a safe and fast
installation. The large international approval package
makes this unit suitable for nearly every application.
Temperature range
Derating
ORDER NUMBERS
MAIN APPROVALS
Dimensions
Weight
±30%
continuous
for 5 seconds
continuous
for 5 seconds
in overload or
short circuit mode
at 20A
at 40A
at no load
at 24V, 20A
at 24V, 40A
operational
+60 to +70°C
WxHxD
340g, 0.75lb
*) Currents at voltages below 6V
**) Plus height for plug connector
For details and the complete approval list, see chapter 15
Redundancy
Module
YR40.245
Accessory
ZM2.WALL
Wall/panel mount
bracket
ZM11.SIDE
Side mount bracket
UL 508
UL 60950-1
Class I Div 2
ATEX
IECEx
Marine
Jun. 2021 / Rev. 1.4 DS-YR40.245-EN
All parameters are specified at 24V, 40A output current, 25°C ambient and after a 5 minutes run-in time unless otherwise noted
www.pulspower.com Phone +49 89 9278 0
Germany
1/20
YR40.245
Y-Series
INDEX
Page
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
Intended Use .......................................................3
Installation Instructions ......................................3
Input and Output Characteristics .......................5
Power Losses ........................................................6
Lifetime Expectancy and MTBF...........................7
Terminals and Wiring ..........................................8
Replacing Units while the System is Running ....9
Functional Diagram ...........................................10
Front Side and User Elements ...........................10
EMC ....................................................................11
Environment ......................................................12
Protection Features ...........................................13
Safety Features ..................................................13
Dielectric Strength ............................................13
Page
15. Approved, Fulfilled or Tested Standards ......... 14
16. Regulatory Product Compliance ...................... 15
17. Physical Dimensions and Weight ..................... 16
18. Accessories ........................................................ 17
18.1. ZM2.WALL - Wall Mounting Bracket ....... 17
18.2. ZM12.SIDE - Side Mounting Bracket ........ 17
19. Application Notes ............................................. 18
19.1. Recommendations for Redundancy......... 18
19.2. Inductive and Capacitive Loads................ 18
19.3. Sidewards Installation Clearances............ 18
19.4. 1+1 Redundancy up to 40A ...................... 19
19.5. N+1 Redundancy, Example with 120A .... 19
19.6. Mounting Orientations ............................ 20
The information presented in this document is believed to be accurate and reliable and may change without notice.
No part of this document may be reproduced or utilized in any form without permission in writing from the publisher.
TERMINOLOGY AND ABREVIATIONS
PE and
symbol
PE is the abbreviation for Protective Earth and has the same meaning as the symbol
Earth, Ground
This document uses the term “earth” which is the same as the U.S. term “ground”.
t.b.d.
To be defined, value or description will follow later.
DC 24V
A figure displayed with the AC or DC before the value represents a nominal voltage with
standard tolerances (usually ±15%) included.
E.g.: DC 12V describes a 12V battery disregarding whether it is full (13.7V) or flat (10V)
24Vdc
A figure with the unit (Vdc) at the end is a momentary figure without any additional
tolerances included.
may
A key word indicating flexibility of choice with no implied preference
shall
A key word indicating a mandatory requirement
should
A key word indicating flexibility of choice with a strongly preferred implementation
1+1 Redundancy
Use of two identical power supplies in parallel to provide continued operation following most
failures in a single power supply. The two power supply outputs should be isolated from each
other by utilizing diodes or other switching arrangements. E.g. two 10A power supplies are
needed to achieve a 10A redundant
N+1
1+1
system.
N+1 Redundancy
Use of three or more identical power
failures in a single power supply. All
isolated from each other by utilizing
arrangements.
E.g.: To achieve a 30A redundant
system, four 10A power supplies are
needed in a N+1 redundant system.
Redundancy
AC
AC
DC
AC
DC
Redundancy
AC
DC
AC
DC
AC
DC
DC
IN
IN
IN
IN
OUT
OUT
OUT
OUT
OUT
OUT
Load
Germany
IN
IN
Load
2/20
YR40.245
Y-Series
1. INTENDED USE
This device is designed for installation in an enclosure and is intended for commercial use, such as in industrial control,
process control, monitoring and measurement equipment or the like. Do not use this device in equipment where
malfunction may cause severe personal injury or threaten human life.
The redundancy module can be used with any type of power supply as long as the maximum output current ratings
are not exceeded. It is suitable for power supplies with continuous overload current as well as any kind of intermittent
(Hiccup) overload behavior.
2. INSTALLATION INSTRUCTIONS
WARNING
Risk of electrical shock, fire, personal injury or death.
Turn power off before working on the device and protect against inadvertent re-powering.
Do not open, modify or repair the device.
Use caution to prevent any foreign objects from entering into the housing.
Do not use in wet locations or in areas where moisture or condensation can be expected.
Do not touch during power-on, and immediately after power-off. Hot surface may cause burns.
Obey the following installation instructions:
This device may only be installed and put into operation by qualified personnel.
This device does not contain serviceable parts. The tripping of an internal fuse is caused by an internal defect.
If damage or malfunction should occur during installation or operation, immediately turn power off and send unit to
the factory for inspection.
Install the device in an enclosure providing protection against electrical, mechanical and fire hazards.
Do not ground or earth the positive output pole which could prevent redundancy in case of a ground failure. Ground
the negative output pole, when needed.
Use only power supplies with a negligible output ripple voltage in the low frequency range between 50Hz and 10kHz
when used in marine applications according to the GL regulations.
Install the device onto a DIN rail according to EN 60715 with the input terminals on the bottom of the device. Other
mounting orientations require a reduction in output current.
Make sure that the wiring is correct by following all local and national codes. Use appropriate copper cables that are
designed for a minimum operating temperature of 60°C for ambient temperatures up to +45°C, 75°C for ambient
temperatures up to +60°C and 90°C for ambient temperatures up to +70°C. Ensure that all strands of a stranded wire
enter the terminal connection.
Unused screw terminals should be securely tightened.
The device is designed for pollution degree 2 areas in controlled environments. No condensation or frost is allowed.
The enclosure of the device provides a degree of protection of IP20.
The input must be powered from a PELV or SELV source or an “Isolated Secondary Circuit” in order to maintain a SELV
or PELV output. C
heck correct input polarity. The device will not operate when input voltage is reversed.
The device is designed as “Class of Protection III” equipment according to IEC 61140.
A PE (ground) connection is not required. However, connecting the chassis ground terminal to ground can be
beneficial to gain a high EMI immunity.
The device is designed for convection cooling and does not require an external fan. Do not obstruct airflow and do not
cover ventilation grid!
The device is designed for altitudes up to 6000m (19685ft). See additional requirements in the product datasheet for
use above 2000m (6560ft).
Germany
3/20
YR40.245
Y-Series
Keep the following minimum installation clearances: 40mm on top, 20mm on the bottom, 5mm left and right side.
Increase the 5mm to 15mm in case the adjacent device is a heat source. When the device is permanently loaded with
less than 50%, the 5mm can be reduced to zero. Under special circumstances clearances can be reduced. See details in
the product datasheet.
The maximum surrounding air temperature is +70°C (+158°F). The operational temperature is the same as the ambient
or surrounding air temperature and is defined 2cm below the device.
The device is designed to operate in areas between 5% and 95% relative humidity.
Installation Instructions for Hazardous Location Areas
The device is suitable for use in Class I Division 2 Groups A, B, C, D locations and for use in Group II Category 3 (Zone 2)
environments.
Hazardous Location classification: ATEX: EPS 11 ATEX 1 312 X, II 3G EX ec IIC T4 Gc
WARNING EXPLOSION HAZARDS!
Substitution of components may impair suitability for this environment.
Do not disconnect the device unless power has been switched off or the area is known to be non-hazardous.
A suitable enclosure must be provided for the end product which has a minimum protection of IP54 and fulfils the
requirements of the EN 60079-0
Germany
4/20
YR40.245
Y-Series
3. INPUT AND OUTPUT CHARACTERISTICS
Number of inputs
Number of outputs
Input voltage
nom.
Input voltage range
Voltage drop, input to output
Input current
Peak input current
Output current
Reverse current
Reverse voltage
Output capacitance
typ.
typ.
nom.
nom.
max
max.
nom.
nom.
max.
max.
max.
typ.
1
1
DC 12-28V ±30%
The input circuitry must meet the SELV requirements
stipulated by IEC/EN/UL 60950-1.
8.4-36.4Vdc
80mV
150mV
0-40A
40-65A
22A
at 20A, see Fig. 3-1
at 40A, see Fig. 3-1
continuous
for 5 seconds
in overload (voltage < 6V) or short circuit mode
for max. 1ms per input
continuous
for 5 seconds
at 24V, per input, -40°C to +70°C
voltage applied to the output, continuously allowed
1500A
40A
40-65A
22A
1mA
40Vdc
320µF
Fig. 3-1 Input to output voltage drop when both inputs draw current
(typical 1+1 redundant case, when the output voltages of the two units are equal)
200mV
175mV
150mV
125mV
100mV
75mV
50mV
25mV
0mV
Voltage Drop, typ
A... 25°C
B... 60°C
B
A
QS40
24V,40A
IIN
A
V UIN
Output
YR40.245
IOUT
A
Input
Output
Variable
Load,
0-40A
UOUT V
Voltage Drop = UIN - UOUT
10A
20A
30A
40A
Output Current
Germany
5/20
YR40.245
Y-Series
4. POWER LOSSES
Power losses
typ.
typ.
typ.
Standby power losses
DC 12V
1.7W
6.1W
0.06W
DC 24V
1.8W
6.2W
0.12W
at 20A
at 40A
at no output current
Fig. 4-1 Power losses when both inputs draw equal current
Power Losses, typ.
8W
7
6
5
4
3
2
1
A... 24V, 25°C
B... 24V, 60°C
QS40
B A
set to
24V
IIN
A
V UIN
Output
YR40.245
IOUT
A
Input
Output
Variable
Load,
0-40A
UOUT V
Losses = ( UIN * IIN ) - UOUT * IOUT
Output Current
10
15
30
35 40A
Germany
6/20
YR40.245
Y-Series
5. LIFETIME EXPECTANCY AND MTBF
Load conditions
Lifetime expectancy *)
MTBF **) SN 29500, IEC 61709
MTBF **) MIL HDBK 217F
Output: 20A
557 000h *)
1 576 000h *)
13 290 000h
22 628 000h
381 000h
518 000h
1 816 000h
2 486 000h
Output: 40A
134 000h *)
378 000h *)
6 357 000h
12 238 000h
278 000h
366 000h
1 401 000h
1 861 000h
at 24V and 40°C
at 24V and 25°C
at 24V 40°C
at 24V 25°C
Ground Fixed GF40 (24V and 40°C)
Ground Fixed GF25 (24V and 25°C)
Ground Benign GB40 (24V and 40°C)
Ground Benign GB25 (24V and 25°C)
The Lifetime expectancy shown in the table indicates the minimum operating hours (service life) and is determined by the lifetime
expectancy of the built-in electrolytic capacitors. Lifetime expectancy is specified in operational hours and is calculated according to the
capacitor’s manufacturer specification. The manufacturer of the electrolytic capacitors only guarantees a maximum life of up to 15 years
(131 400h). Any number exceeding this value is a calculated theoretical lifetime which can be used to compare devices.
**) MTBF stands for Mean Time Between Failure, which is calculated according to statistical device failures, and indicates reliability of a
device. It is the statistical representation of the likelihood of a unit to fail and does not necessarily represent the life of a product.
The MTBF figure is a statistical representation of the likelihood of a device to fail. A MTBF figure of e.g. 1 000 000h means that
statistically one unit will fail every 100 hours if 10 000 units are installed in the field. However, it can not be determined if the failed unit
has been running for 50 000h or only for 100h.
Germany
7/20
YR40.245
Y-Series
6. TERMINALS AND WIRING
Input
Screw termination
IP20 Finger safe construction.
Suitable for field installation.
0.5-16mm2
0.5-10mm2
22-8 AWG
5.2mm (including ferrule)
12mm / 0.5inch
3.5x1mm slotted or Pozidrive No 2
1.2Nm, 10.6lb-in
Type
Solid wire
Stranded wire
American Wire Gauge
Max. wire diameter
Wire stripping length
Screwdriver
Recommended tightening torque
Output
Pluggable screw termination
0.2-16mm2
0.5-10mm2
22-6 AWG
5.4mm (including ferrule)
12mm / 0.5inch
5.5x1mm slotted or Pozidrive No 2
1.4Nm, 12lb-in
To connect the chassis to ground, use a ring-type terminal (ring cable lug) which is suitable for a M4 screw and connect
it to the chassis ground terminal on top of the unit.
Instructions:
a) The external circuitry of all terminals must meet the safety requirements stipulated by IEC/EN/UL 60950-1: SELV.
b) Use appropriate copper cables that are designed for minimum operating temperatures of:
60°C for ambient up to 45°C and
75°C for ambient up to 60°C and
90°C for ambient up to 70°C minimum.
c) Follow national installation codes and installation regulations!
d) Ensure that all strands of a stranded wire enter the terminal connection!
e) Screws of unused terminal compartments should be securely tightened.
f) Ferrules are allowed.
g) Do not connect or disconnect the wires from the terminals below -25°C (-13°F).
Instructions for inserting and removing the pluggable output terminal
To avoid an accidental disconnection of the output, the plug connector is equipped with a locking system.
Fig. 6-1 Removing the latch mechanism
A
Unlock the red sliders by pushing the tabs down
B
At the same time slide the tabs back
C
Pull-out to unplug the connector
To insert the plug connector, reverse the procedure
Germany
8/20
YR40.245
Y-Series
7. REPLACING UNITS WHILE THE SYSTEM IS RUNNING
Fig. 7-1 Replacing the power supply or redundancy module while the system is running
Load
4
Output
2
YR40.245
Redundancy
Module
YR40.245
Redundancy
Module
DC 24V
3a
Power Supply
Output
1
L N PE
Power Supply
Input
DC 24V
L N PE
3b
I
Input
I
L
N
PE
Instructions:
Switch-off circuit breaker (3a).
Remove plug (4). The plug prevents the cables from shorting.
Change power supply (1) or/ and redundancy module (2).
Put the plug (4) back in.
Turn-on the circuit breaker (3a).
The circuit is redundant again.
To replace the right power supply or redundancy module, use the same procedure but turn off circuit breaker (3b).
Germany
9/20
YR40.245
Y-Series
8. FUNCTIONAL DIAGRAM
Fig. 8-1 Functional diagram
control
Input
Output
Chassis
Ground
9. FRONT SIDE AND USER ELEMENTS
Fig. 9-1 Front side
A
Output Terminals (pluggable screw terminals)
B
Chassis Ground Terminals
To be connected on the top side of the housing with a ring-type terminal
(ring cable lug) which is suitable for a M4 screw.
Connection of the chassis is optional and not required since the unit fulfils
the requirements according to protection class III.
C
Input Terminals (screw terminals)
Germany
10/20
YR40.245
Y-Series
10. EMC
The redundancy module is suitable for applications in industrial environment as well as in residential, commercial and
light industry environment without any restrictions. A detailed EMC report is available on request.
EMC Immunity
Electrostatic discharge
Electromagnetic RF field
Fast transients (Burst)
Surge voltage on input
lines
According generic standards: EN 61000-6-1 and EN 61000-6-2
Contact discharge
8kV
EN 61000-4-2
Air discharge
15kV
EN 61000-4-3
80MHz-2.7GHz
20V/m
Input lines
2kV
EN 61000-4-4
Output lines
2kV
500V
EN 61000-4-5
+1kV
+/- Chassis ground
Surge voltage on output
lines
EN 61000-4-5
Conducted disturbance
Power-frequency magnetic
field *)
EN 61000-4-6
EN 61000-4-8
++/- Chassis ground
0.15-80MHz
50Hz
Criterion A
Criterion A
Criterion A
Criterion A
Criterion A
Criterion A
Criterion A
500V
1kV
Criterion A
Criterion A
20V
30A/m
Criterion A
Criterion A
Criterions:
A: Redundancy module shows normal operation behavior within the defined limits.
Notes:
*) A test is not applicable according to EN 61000-6-2, since the device does not contain components susceptible to magnetic fields, e.g. hall
elements, electrodynamic microphones, etc.
According generic standards: EN 61000-6-3 and EN 61000-6-4
limits for DC power ports according
IEC/CISPR 16-1-2, IEC/CISPR 16-2-1
EN 61000-6-3 fulfilled *)
Radiated emission
EN 55011, EN 55032
Class B
This device complies with FCC Part 15 rules.
Operation is subjected to following two conditions: (1) this device may not cause harmful interference, and (2) this
device must accept any interference received, including interference that may cause undesired operation.
EMC Emission
Conducted emission
For information only, not mandatory for EN 61000-6-3. Provided, that power sources connected on the inputs fulfill the requirements too.
Switching frequency
The internal auxiliary supply is generated with a boost converter.
The switching frequency varies from 140kHz to 500kHz depending on the input voltage.
Germany
11/20
YR40.245
Y-Series
11. ENVIRONMENT
Operational temperature *)
Storage temperature
Output derating
Humidity **)
Vibration sinusoidal ***)
Shock ***)
Altitude
-40°C to +70°C (-40°F to 158°F)
-40 to +85°C (-40°F to 185°F)
1A / °C
5 to 95% r.H.
2-17.8Hz: ±1.6mm; 17.8-500Hz: 2g
2 hours / axis
30g 6ms, 20g 11ms
3 bumps / direction, 18 bumps in total
0 to 2000m (0 to 6 560ft)
2000 to 6000m (6 560 to 20 000ft)
Altitude derating
Over-voltage category
2.5A/1000m or 5°C/1000m
not applicable
Degree of pollution
2
for storage and transportation
60-70°C (140°F to 158°F)
IEC 60068-2-30
IEC 60068-2-6
IEC 60068-2-27
reduce output power or ambient temperature,
see Fig. 11-2
> 2000m (6500ft), see Fig. 11-2
The concept of the overvoltage category is
used for equipment energized directly from
the low voltage mains (IEC 60664-1 §4.3.3.2.1).
IEC 62103, EN 50178, not conductive
*) Operational temperature is the same as the ambient temperature and is defined as the air temperature 2cm below the unit.
**) Do not energize while condensation is present
***) Tested in combination with DIN rails according to EN 60715 with a height of 15mm and a thickness of 1.3mm and standard mounting
orientation.
Fig. 11-1 Output current vs. ambient temp.
Allowed Output Current
65A
50
40
Fig. 11-2 Output current vs. altitude
65A
short term (< 5s)
50
normal mode
30
10
Ambient Temperature
normal mode
40
30
short term (< 5s)
40
A
A... Tamb < 70°C
B... Tamb < 60°C
C... Tamb < 50°C
60 70°C
B
C
Altitude
4000
6000m
Germany
12/20
YR40.245
Y-Series
12. PROTECTION FEATURES
Output over-current protection
Reverse input polarity
protection
Degree of protection
Penetration protection
Over-temperature protection
Input transient protection
Output transient protection
Internal input fuse
not included
included
unit does not start when input voltage is reversed
IP 20
> 3.6mm
not included
not included
included
not included
EN/IEC 60529
e.g. screws, small parts
see EMC chapter
13. SAFETY FEATURES
Input / output separation
Class of protection
PE resistance
no galvanic separation
III
< 0.1Ohm
Mosfet between input and output
PE (Protective Earth) or chassis connection not required
between housing and chassis-ground terminal
14. DIELECTRIC STRENGTH
The input and output voltages have the same reference, are floating and have no ohmic connection to ground.
Type and factory tests are conducted by the manufacturer. Field tests may be conducted in the field using the
appropriate test equipment which applies the voltage with a slow ramp (2s up and 2s down). Connect input/output
terminals together before conducting the test.
When testing, set the cut-off current settings to the value in the table below.
Type test
60s
A
500Vac
Factory test
5s
500Vac
Field test
5s
500Vac
Fig. 14-1 Dielectric strength
In- / Output
A
Chassis
Cut-off current setting
> 2mA
Germany
13/20
YR40.245
Y-Series
15. APPROVED, FULFILLED OR TESTED STANDARDS
UL 508
IEC 60950-1
UL 60950-1
ATEX
IECEx
Class I Div 2
Marine (DNV)
Marine (ABS)
IEC 60068-2-60
UL Certificate
Listed equipment for category NMTR - Industrial Control Equipment
Applicable for US and Canada
E-File: E198865
CB Scheme Certificate
General safety requirements for Information Technology Equipment (ITE)
UL Certificate
Recognized component for category QQGQ - Information Technology
Equipment (ITE)
E-File: E137006
Agency Certificate (Bureau Veritas)
EN 60079-0 Explosive atmospheres - General requirements
EN 60079-7 Equipment protection by type of protection "e"
Certificate: EPS 11 ATEX 1 312 X
Temperature Code: T4
Type of Protection: ec
IECEx Certificate
IEC 60079-0 Explosive atmospheres - General requirements
IEC 60079-7 Equipment protection by type of protection "e"
Certificate: IECEx EPS 12.0032 X
CSA Certificate
Power Supplies for Hazardous Location
Applicable for Canada and US
CSA Class: 5318-01 (Canada), 5318-81 (USA)
Groups: A, B, C and D
DNV Certificate
DNV Type approved product
Certificate: TAA00002A7
Temperature: Class D
Humidity: Class B
Vibration: Class C
EMC: Class B
Enclosure: Class A
ABS Design Assessment Certificate
ABS (American Bureau of Shipment) assessed product
Certificate: 17-HG1599236-PD
Manufacturer's Declaration (Online Document)
Environmental Tests, Flowing Mixed Gas Corrosion Test
Test Ke - Method 4
H2S: 10ppb
NO2: 200ppb
Cl2: 10ppb
SO2: 200ppb
Test Duration: 3 weeks, which simulates a service life of 10 years.
Germany
14/20
YR40.245
Y-Series
ISA-71.04 G3
VDMA 24364
Airborne Contaminants Corrosion Test
Severity Level: G3 Harsh
H2S: 100ppb
NOx: 1250ppb
Cl2: 20ppb
SO2: 300ppb
Paint Wetting Impairment Substances Test (or LABS-Test)
Tested for Zone 2 and test class C1 according to VDMA 24364-C1-L/W for
solvents and water-based paints
16. REGULATORY PRODUCT COMPLIANCE
EU Declaration of
Conformity
REACH Directive
WEEE Directive
KC Korean
Certification
EAC TR Registration
The CE mark indicates conformance with the
- EMC directive
- ATEX directive
- RoHS directive
Manufacturer's Statement
EU-Directive regarding the Registration, Evaluation, Authorization and
Restriction of Chemicals
EU-Regulation on Waste Electrical and Electronic Equipment
Registered in Germany as business to business (B2B) products.
KC Korean Certificate
Korean - Registration of Broadcasting and Communication Equipment
Registered under Clause3, Article 58-2 of Radio Waves Act.
Registration No. R-R-PUG-YR40_245
EAC Certificate
EAC EurAsian Conformity - Registration Russia, Kazakhstan and Belarus
8504408200, 8504409000
Germany
15/20
YR40.245
Y-Series
17. PHYSICAL DIMENSIONS AND WEIGHT
Weight
DIN rail
Installation clearances
340g / 0.75lb
Use 35mm DIN rails according to EN 60715 or EN 50022 with a height of 7.5 or 15mm.
The DIN rail depth must be added to the unit depth (127mm) to calculate the total required
installation depth.
See chapter 2
Fig. 17-1 Front view
Fig. 17-2 Side view
Germany
16/20
YR40.245
Y-Series
18. ACCESSORIES
18.1. ZM2.WALL - WALL MOUNTING BRACKET
This standard bracket is used to mount the YR40.245 redundancy module onto a flat surface without utilizing a DIN
rail.
Fig. 18-1 ZM2.WALL Wall mounting bracket
Fig. 18-2 Assembled wall mounting bracket
18.2. ZM12.SIDE - SIDE MOUNTING BRACKET
This bracket is used to mount the YR40.245 redundancy module sideways with or without utilizing a DIN rail.
The two aluminum brackets and the black plastic slider of the unit have to be detached, so that the steel brackets can
be mounted.
For sideway DIN rail mounting, the removed aluminum brackets and the black plastic slider need to be mounted on
the steel bracket.
Fig. 18-3
ZM12.SIDE Side mounting bracket
Fig. 18-4
Side mounting with DIN rail brackets
Germany
17/20
YR40.245
Y-Series
19. APPLICATION NOTES
19.1. RECOMMENDATIONS FOR REDUNDANCY
Recommendations for the configuration of redundant power systems:
Use separate input fuses for each power supply.
Use three-phase power supplies to gain functional safety if one phase fails.
When single-phase power supplies are utilized connect them to different phases or mains circuits if possible.
Set the power supply in “Parallel-Use” mode if this feature is available
It is desirable to set the output voltages of all power supplies to the same value.
19.2. INDUCTIVE AND CAPACITIVE LOADS
The unit is designed to supply any kind of loads, including unlimited capacitive and inductive loads.
19.3. SIDEWARDS INSTALLATION CLEARANCES
The minimum clearance recommendations are defined in chapter 2.
Normally, the following installation clearance are recommended: 40mm on top, 20mm on the bottom, 5mm on the
left and right sides when the device is loaded permanently with more than 50% of the rated power. Increase this
clearance to 15mm in case the adjacent device is a heat source (e.g. another power supply).
The clearance between the power supplies and the redundancy module can be reduced to zero under the following
conditions:
1+1 redundancy application with maximum
40A output current.
The power supplies are from the PULS
DIMENSION series.
The redundancy module is placed between
the two power supplies or at least on one
side of the power supply.
The output voltage is set to the same level
on both power supplies.
max.
40A
Load
Output
Power Supply
DCOK
Parallel Use
Single Use
AC Input
L N PE
24V, 40A
0mm
YR40.245
Redundancy
Module
Input
0mm
Output
DCOK
Parallel Use
Single Use
AC Input
L N PE
24V, 40A
Germany
YR40.245
Redundancy
Module
Input
0mm
Power Supply
18/20
YR40.245
Y-Series
19.4. 1+1 REDUNDANCY UP TO 40A
1+1 Redundancy up to 40A requires two 40A power supplies and two YR40.245 redundancy modules.
Fig. 19-1 Wiring diagram, 1+1 Redundancy, 40A output current
24V
40A
Load
Failure
Monitor
DCOK
Parallel Use
AC Input
L N PE
YR40.245
Redundancy
Module
Single Use
AC Input
DCOK
Parallel Use
Input
24V, 40A
Output
Power Supply
YR40.245
Redundancy
Module
Single Use
Output
Power Supply
Input
24V, 40A
L N PE
I
I
L
N
PE
Note: Use separate mains systems for each power supply whenever it is possible
19.5. N+1 REDUNDANCY, EXAMPLE WITH 120A
N+1 Redundancy up to 120A requires four 40A power supplies and four YR40.245 redundancy modules.
Fig. 19-2 Wiring diagram, n+1 Redundancy, 120A output current
Failure
Monitor
DCOK
Parallel Use
Single Use
AC Input
L N PE
I
24V, 40A
DCOK
Parallel Use
Single Use
Input
AC Input
L N PE
I
24V, 40A
DCOK
Parallel Use
Single Use
Input
AC Input
L N PE
I
DCOK
Parallel Use
Single Use
Input
Output
Power Supply
YR40.245
Redundancy
Module
24V, 40A
Output
Power Supply
YR40.245
Redundancy
Module
Output
Power Supply
YR40.245
Redundancy
Module
Output
Power Supply
24V
120A
- Load
AC Input
L N PE
24V, 40A
YR40.245
Redundancy
Module
Input
I
L
N
PE
Germany
19/20
YR40.245
Y-Series
19.6. MOUNTING ORIENTATIONS
Mounting orientations other than input terminals on the bottom and output on the top require a reduction in
continuous output power or a limitation in the maximum allowed ambient temperature. The amount of reduction
influences the lifetime expectancy of the power supply. Therefore, two different derating curves for continuous
operation can be found below:
Curve A1
Curve A2
Recommended output current.
Max allowed output current (results in approximately half the lifetime expectancy of A1).
Fig. 19-3
Mounting
Orientation A
(Standard
orientation)
Output Current
40A
OUTPUT
30
YR40.245
Redundancy
Module
Ambient Temperature
INPUT
10
Fig. 19-4
Mounting
Orientation B
(Upside down)
A1
40
50
60°C
Output Current
40A
A1
INPUT
30
Redundancy
Module
YR40.245
10
Ambient Temperature
OUTPUT
10
Fig. 19-5
Mounting
Orientation C
(Table-top
mounting)
40
50
60°C
Output Current
40A
30
A2
A1
10
Ambient Temperature
50
40
40A
60°C
A2
OUTPUT
YR40.245
Redundancy
Module
30
A1
10
Ambient Temperature
40
50
60°C
Output Current
A2
30
INPUT
YR40.245
Redundancy
Module
40A
OUTPUT
Fig. 19-7
Mounting
Orientation E
(Horizontal ccw)
30
Output Current
INPUT
Fig. 19-6
Mounting
Orientation D
(Horizontal cw)
A1
10
Ambient Temperature
40
50
60°C
Germany
20/20
