Additional Resources:
Product Page
3D Model
PCB Footprint
date
07/06/2021
page
1 of 6
SERIES: PDS1-D │ DESCRIPTION: DC-DC CONVERTER
FEATURES
1 W isolated output
smaller package
single unregulated output
1,500 Vdc isolation
short circuit protection
extended temperature range (-40~105°C)
antistatic protection up to 8kV
high efficiency at light load
efficiency up to 80%
EN 62368-1
MODEL
input
voltage
output
voltage
output
current
output
power
ripple
and noise2
efficiency
typ
(Vdc)
range
(Vdc)
(Vdc)
min
(mA)
max
(mA)
max
(W)
typ
(mVp-p)
typ
PDS1-S3-S3-D
3.3
2.97~3.63
3.3
30
303
1
60
72
PDS1-S3-S5-D
3.3
2.97~3.63
5
1
60
76
PDS1-S5-S3-D
5
4.5~5.5
3.3
30
303
1
60
72
1
PDS1-S5-S5-D
5
4.5~5.5
5
1
60
80
PDS1-S5-S9-D1
5
4.5~5.5
9
12
111
1
60
80
1
PDS1-S5-S12-D
5
4.5~5.5
12
9
84
1
60
80
PDS1-S5-S15-D1
5
4.5~5.5
15
7
67
1
60
80
PDS1-S5-S24-D
5
4.5~5.5
24
4
42
1
60
80
PDS1-S12-S3-D
12
10.8~13.2
3.3
30
303
1
60
72
1
PDS1-S12-S5-D
12
10.8~13.2
5
1
60
80
PDS1-S12-S9-D1
12
10.8~13.2
9
12
111
1
60
80
1
PDS1-S12-S12-D
12
10.8~13.2
12
9
83
1
60
80
PDS1-S12-S15-D1
12
10.8~13.2
15
7
67
1
60
80
PDS1-S15-S5-D
15
13.5~16.5
5
1
60
80
PDS1-S15-S15-D
15
13.5~16.5
15
7
67
1
60
80
PDS1-S24-S3-D
24
21.6~26.4
3.3
30
303
1
60
72
1
PDS1-S24-S5-D
24
21.6~26.4
5
1
60
80
PDS1-S24-S9-D1
24
21.6~26.4
9
12
111
1
60
80
1
PDS1-S24-S12-D
24
21.6~26.4
12
9
84
1
60
80
PDS1-S24-S15-D1
24
21.6~26.4
15
7
67
1
60
80
PDS1-S24-S24-D
24
21.6~26.4
24
4
42
1
60
80
1
1
Notes:
1. UL approved
2. Ripple and noise are measured at 20 MHz BW by “parallel cable” method with 1 μF ceramic and 10 μF electrolytic capacitors on the output.
cui.com
Product Page
3D Model
PCB Footprint
CUI Inc │ SERIES: PDS1-D │ DESCRIPTION: DC-DC CONVERTER
date 07/06/2021 │ page 2 of 6
PART NUMBER KEY
PDS1 - SXX - SXX - D
Base Number
Output Voltage
Input Voltage
INPUT
Packaging Style
DIP
parameter
conditions/description
min
typ
max
units
operating input voltage
3.3 Vdc input models
5 Vdc input models
12 Vdc input models
15 Vdc input models
24 Vdc input models
2.97
4.5
10.8
13.5
21.6
3.3
5
12
15
24
3.63
5.5
13.2
16.5
26.4
Vdc
Vdc
Vdc
Vdc
Vdc
surge voltage
for maximum of 1 second
5 Vdc input models
12 Vdc input models
15 Vdc input models
24 Vdc input models
-0.7
-0.7
-0.7
-0.7
-0.7
5
9
18
21
30
Vdc
Vdc
Vdc
Vdc
Vdc
filter
capacitance filter
max
units
±1.5
±1.2
OUTPUT
parameter
min
line regulation
for Vin change of 1%
3.3 Vdc output models
all other models
load regulation
measured from 10% load to full load
5 Vdc output models
9 Vdc output models
12 Vdc output models
15 Vdc output models
24 Vdc output models
voltage accuracy
see tolerance envelope curves
switching frequency
100% load, nominal input voltage
temperature coefficient
100% load
typ
18
12
8
7
6
5
100
kHz
±0.03
%/°C
max
units
1
s
max
units
PROTECTIONS
parameter
short circuit protection1
3 & 24 Vdc input models; PDS1-S5-S24-D
all other models: continuous, automatic recovery
Notes:
min
typ
1. The supply voltage must be discontinued at the end of the short circuit duration
SAFETY AND COMPLIANCE
parameter
isolation voltage
input to output, for 1 minute at 1 mA max.
1,500
Vdc
isolation resistance
input to output at 500 Vdc
1,000
MΩ
safety approvals2
certified to 62368-1: EN
certified to 60950-1: UL
conducted/radiated emissions
CISPR32/EN55032 class B (external circuit required)
ESD
IEC/EN61000-4-2, class B, contact ± 8kV
MTBF
as per MIL-HDFK-217F @ 25°C
3,500,000
hours
RoHS
2011/65/EU
Notes:
min
2. See specific models noted on page 1
cui.com
typ
Product Page
3D Model
PCB Footprint
date 07/06/2021 │ page 3 of 6
ENVIRONMENTAL
parameter
min
max
units
operating temperature
see derating curve
-40
105
°C
-55
125
°C
95
storage temperature
storage humidity
non-condensing
temperature rise
at full load, Ta=25°C
typ
25
°C
SOLDERABILITY
parameter
hand soldering
wave soldering
min
typ
max
units
1.5 mm from case for 10 seconds
300
°C
see wave soldering profile
260
°C
max
units
Peak Temp. 260°C Max.
Wave Soldering Time
4 Sec. Max.
250
Temperature (°C)
200
10 Sec. Max.
150
100
50
Time (sec.)
MECHANICAL
parameter
dimensions
12.70 x 10.16 x 8.20 (0.500 x 0.4 x 0.323 inch)
min
case material
plastic (UL94-V0)
typ
mm
weight
1.8
g
PIN CONNECTIONS
Vin
5
+Vo
7
0V
AC
܍A܍C
AC
AC
܍A܍C
4UZK -XOJSS
cui.com
AC
4
AC
GND
AC
Function
1
AC
PIN
AC
AC
units: mm[inch]
tolerance: ±0.25[±0.010]
pin section tolerance: ±0.10[±0.004]
AC
MECHANICAL DRAWING
AC
Product Page
3D Model
PCB Footprint
date 07/06/2021 │ page 4 of 6
DERATING CURVES
EMC RECOMMENDED CIRCUIT
Figure 1
Table 1
Recommended external circuit components
Vin
(Vdc)
C1
3.3
5
C2
LDM
4.7μF/50V
10μF
6.8μH
4.7μF/50V
4.7μF
6.8μH
12
4.7μF/50V
2.2μF
6.8μH
15
4.7μF/50V
1μF
6.8μH
24
4.7μF/50V
0.47μF
6.8μH
TEST CONFIGURATION
Figure 2
Table 2
External components
Note:
Lin
4.7μH
Cin
220μF, ESR < 1.0Ω
at 100 kHz
1. Input reflected-ripple current is measured with an inductor Lin and capacitor Cin to simulate source impedance.
cui.com
Product Page
3D Model
PCB Footprint
date 07/06/2021 │ page 5 of 6
APPLICATION NOTES
1. Output load requirement
To ensure this module can operate efficiently and reliably, the minimum output load may not be less than 10% of the full load during
operation. If the actual output power is low, connect a resistor at the output end in parallel to increase the load.
2. Overload Protection
Under normal operating conditions, the output circuit of this product has no protection against overload. The simplest method to add
this is to add a circuit breaker to the circuit.
3. Recommended circuit
If you want to further decrease the input/output ripple, you can increase the capacitance accordingly or choose capacitors with low
ESR(see Figure 3 & Table 3). However, the capacitance of the output filter capacitor must be appropriate. If the capacitance is too
high, a startup problem might arise. For every channel of the output, to ensure safe and reliable operation, the maximum capacitance
must be less than the maximum capacitive load (see Table 4).
Figure 3
Table 3
Note:
1.
2.
3.
4.
Table 4
Vin
(Vdc)
Cin
(µF)
Vout
(Vdc)
Cout
(µF)
Vout
(Vdc)
Max. Capacitive Load
(μF)
3.3
4.7
3.3
10
3.3
220
5
4.7
5
10
5
220
12
2.2
9
4.7
12
220
15
2.2
12
2.2
15
220
24
1
15
1
24
220
24
0.47
Operation under minimum load will not damage the converter; however, they may not meet all specifications listed.
Max. capacitive load tested at input voltage range and full load.
It is recommended to use either ceramic capacitors or electrolytic capacitors on the input and the output. Using tantalum capacitors may increase the risk of failure.
All specifications measured at: Ta=25°C, humidity
很抱歉,暂时无法提供与“PDS1-S12-S15-D”相匹配的价格&库存,您可以联系我们找货
