PDS1-S3-S5-D
PDS1-S3-S5-D
    CUIDEVICES
    DIP7
    CONVERT DC/DC 1W 5V 42MA OUT
PDS1-S3-S5-D 数据手册
Additional Resources: Product Page | 3D Model | PCB Footprint date 07/06/2021 page 1 of 6 SERIES: PDS1-D │ DESCRIPTION: DC-DC CONVERTER FEATURES • • • • • • • • • • 1 W isolated output smaller package single unregulated output 1,500 Vdc isolation short circuit protection extended temperature range (-40~105°C) antistatic protection up to 8kV high efficiency at light load efficiency up to 80% EN 62368-1 MODEL input voltage output voltage output current output power ripple and noise2 efficiency typ (Vdc) range (Vdc) (Vdc) min (mA) max (mA) max (W) typ (mVp-p) typ (%) PDS1-S3-S3-D 3.3 2.97~3.63 3.3 30 303 1 60 72 PDS1-S3-S5-D 3.3 2.97~3.63 5 20 200 1 60 76 PDS1-S5-S3-D 5 4.5~5.5 3.3 30 303 1 60 72 1 PDS1-S5-S5-D 5 4.5~5.5 5 20 200 1 60 80 PDS1-S5-S9-D1 5 4.5~5.5 9 12 111 1 60 80 1 PDS1-S5-S12-D 5 4.5~5.5 12 9 84 1 60 80 PDS1-S5-S15-D1 5 4.5~5.5 15 7 67 1 60 80 PDS1-S5-S24-D 5 4.5~5.5 24 4 42 1 60 80 PDS1-S12-S3-D 12 10.8~13.2 3.3 30 303 1 60 72 1 PDS1-S12-S5-D 12 10.8~13.2 5 20 200 1 60 80 PDS1-S12-S9-D1 12 10.8~13.2 9 12 111 1 60 80 1 PDS1-S12-S12-D 12 10.8~13.2 12 9 83 1 60 80 PDS1-S12-S15-D1 12 10.8~13.2 15 7 67 1 60 80 PDS1-S15-S5-D 15 13.5~16.5 5 20 200 1 60 80 PDS1-S15-S15-D 15 13.5~16.5 15 7 67 1 60 80 PDS1-S24-S3-D 24 21.6~26.4 3.3 30 303 1 60 72 1 PDS1-S24-S5-D 24 21.6~26.4 5 20 200 1 60 80 PDS1-S24-S9-D1 24 21.6~26.4 9 12 111 1 60 80 1 PDS1-S24-S12-D 24 21.6~26.4 12 9 84 1 60 80 PDS1-S24-S15-D1 24 21.6~26.4 15 7 67 1 60 80 PDS1-S24-S24-D 24 21.6~26.4 24 4 42 1 60 80 1 1 Notes: 1. UL approved 2. Ripple and noise are measured at 20 MHz BW by “parallel cable” method with 1 μF ceramic and 10 μF electrolytic capacitors on the output. cui.com Additional Resources: Product Page | 3D Model | PCB Footprint CUI Inc │ SERIES: PDS1-D │ DESCRIPTION: DC-DC CONVERTER date 07/06/2021 │ page 2 of 6 PART NUMBER KEY PDS1 - SXX - SXX - D Base Number Output Voltage Input Voltage INPUT Packaging Style DIP parameter conditions/description min typ max units operating input voltage 3.3 Vdc input models 5 Vdc input models 12 Vdc input models 15 Vdc input models 24 Vdc input models 2.97 4.5 10.8 13.5 21.6 3.3 5 12 15 24 3.63 5.5 13.2 16.5 26.4 Vdc Vdc Vdc Vdc Vdc surge voltage for maximum of 1 second 3.3 Vdc input models 5 Vdc input models 12 Vdc input models 15 Vdc input models 24 Vdc input models -0.7 -0.7 -0.7 -0.7 -0.7 5 9 18 21 30 Vdc Vdc Vdc Vdc Vdc filter capacitance filter max units ±1.5 ±1.2 % % OUTPUT parameter conditions/description min line regulation for Vin change of 1% 3.3 Vdc output models all other models load regulation measured from 10% load to full load 3.3 Vdc output models 5 Vdc output models 9 Vdc output models 12 Vdc output models 15 Vdc output models 24 Vdc output models voltage accuracy see tolerance envelope curves switching frequency 100% load, nominal input voltage temperature coefficient 100% load typ 18 12 8 7 6 5 % % % % % % 100 kHz ±0.03 %/°C max units 1 s max units PROTECTIONS parameter conditions/description short circuit protection1 3 & 24 Vdc input models; PDS1-S5-S24-D all other models: continuous, automatic recovery Notes: min typ 1. The supply voltage must be discontinued at the end of the short circuit duration SAFETY AND COMPLIANCE parameter conditions/description isolation voltage input to output, for 1 minute at 1 mA max. 1,500 Vdc isolation resistance input to output at 500 Vdc 1,000 MΩ safety approvals2 certified to 62368-1: EN certified to 60950-1: UL conducted/radiated emissions CISPR32/EN55032 class B (external circuit required) ESD IEC/EN61000-4-2, class B, contact ± 8kV MTBF as per MIL-HDFK-217F @ 25°C 3,500,000 hours RoHS 2011/65/EU Notes: min 2. See specific models noted on page 1 cui.com typ Additional Resources: Product Page | 3D Model | PCB Footprint CUI Inc │ SERIES: PDS1-D │ DESCRIPTION: DC-DC CONVERTER date 07/06/2021 │ page 3 of 6 ENVIRONMENTAL parameter conditions/description min max units operating temperature see derating curve -40 105 °C -55 125 °C 95 % storage temperature storage humidity non-condensing temperature rise at full load, Ta=25°C typ 25 °C SOLDERABILITY parameter conditions/description hand soldering wave soldering min typ max units 1.5 mm from case for 10 seconds 300 °C see wave soldering profile 260 °C max units Peak Temp. 260°C Max. Wave Soldering Time 4 Sec. Max. 250 Temperature (°C) 200 10 Sec. Max. 150 100 50 0 Time (sec.) MECHANICAL parameter conditions/description dimensions 12.70 x 10.16 x 8.20 (0.500 x 0.4 x 0.323 inch) min case material plastic (UL94-V0) typ mm weight 1.8 g PIN CONNECTIONS Vin 5 +Vo 7 0V AC ‫܍‬A‫܍‬C   AC AC      ‫܍‬A‫܍‬C 4UZK -XOJSS cui.com  AC 4 AC GND AC Function 1 AC PIN AC AC units: mm[inch] tolerance: ±0.25[±0.010] pin section tolerance: ±0.10[±0.004] AC MECHANICAL DRAWING AC Additional Resources: Product Page | 3D Model | PCB Footprint CUI Inc │ SERIES: PDS1-D │ DESCRIPTION: DC-DC CONVERTER date 07/06/2021 │ page 4 of 6 DERATING CURVES EMC RECOMMENDED CIRCUIT Figure 1 Table 1 Recommended external circuit components Vin (Vdc) C1 3.3 5 C2 LDM 4.7μF/50V 10μF 6.8μH 4.7μF/50V 4.7μF 6.8μH 12 4.7μF/50V 2.2μF 6.8μH 15 4.7μF/50V 1μF 6.8μH 24 4.7μF/50V 0.47μF 6.8μH TEST CONFIGURATION Figure 2 Table 2 External components Note: Lin 4.7μH Cin 220μF, ESR < 1.0Ω at 100 kHz 1. Input reflected-ripple current is measured with an inductor Lin and capacitor Cin to simulate source impedance. cui.com Additional Resources: Product Page | 3D Model | PCB Footprint CUI Inc │ SERIES: PDS1-D │ DESCRIPTION: DC-DC CONVERTER date 07/06/2021 │ page 5 of 6 APPLICATION NOTES 1. Output load requirement To ensure this module can operate efficiently and reliably, the minimum output load may not be less than 10% of the full load during operation. If the actual output power is low, connect a resistor at the output end in parallel to increase the load. 2. Overload Protection Under normal operating conditions, the output circuit of this product has no protection against overload. The simplest method to add this is to add a circuit breaker to the circuit. 3. Recommended circuit If you want to further decrease the input/output ripple, you can increase the capacitance accordingly or choose capacitors with low ESR(see Figure 3 & Table 3). However, the capacitance of the output filter capacitor must be appropriate. If the capacitance is too high, a startup problem might arise. For every channel of the output, to ensure safe and reliable operation, the maximum capacitance must be less than the maximum capacitive load (see Table 4). Figure 3 Table 3 Note: 1. 2. 3. 4. Table 4 Vin (Vdc) Cin (µF) Vout (Vdc) Cout (µF) Vout (Vdc) Max. Capacitive Load (μF) 3.3 4.7 3.3 10 3.3 220 5 4.7 5 10 5 220 12 2.2 9 4.7 12 220 15 2.2 12 2.2 15 220 24 1 15 1 24 220 -- -- 24 0.47 Operation under minimum load will not damage the converter; however, they may not meet all specifications listed. Max. capacitive load tested at input voltage range and full load. It is recommended to use either ceramic capacitors or electrolytic capacitors on the input and the output. Using tantalum capacitors may increase the risk of failure. All specifications measured at: Ta=25°C, humidity
PDS1-S3-S5-D 价格&库存
很抱歉,暂时无法提供与“PDS1-S3-S5-D”相匹配的价格&库存,您可以联系我们找货
