Additional Resources:
Product Page
3D Model
date
11/02/2021
page
1 of 11
SERIES: VPOL5A-12-SMT │ DESCRIPTION: POINT OF LOAD CONVERTER
FEATURES
industry standard pin out
high efficiency to 92%
300 KHz switching frequency
8.3-14 VDC wide input range
0.75-5.0 VDC wide output range
over temperature protection
continuous short circuit protection
remote on/off
cost-efficient open frame design
UL/C-UL 60950-1 (E222736) certified
MODEL
input
voltage
typ
(Vdc)
VPOL5A-12-SMT
Notes:
12
range
(Vdc)
8.3~14
output
voltage
output
current
output
power
ripple
and noise1
efficiency
(Vdc)
max
(A)
max
(W)
max
(mVp-p)
typ
5
3.75
6.0
7.5
9.0
10.0
12.5
16.5
25.0
50
50
50
50
50
50
50
75
73
80
82
84
85
87
89
92
0.75
1.2
1.5
1.8
2.0
2.5
3.3
5.0
1. Ripple and noise are measured at 20 MHz BW by “parallel cable” method with 1 µF ceramic and 10 µF electrolytic capacitors on the output.
PART NUMBER KEY
VPOL5A -12- XX - XX
Base Number
Input Voltage
Output Voltage
cui.com
Packaging Style
SMT
Product Page
3D Model
CUI Inc │ SERIES: VPOL5A-12-SMT │ DESCRIPTION: POINT OF LOAD CONVERTER
date 11/02/2021 │ page 2 of 11
INPUT
parameter
conditions/description
operating input voltage
input under-voltage lockout
turn-on voltage treshold
turn-off voltage treshold
lockout hysteresis voltage
input current
0~14 Vdc
no load input current
0.75 output
1.2 output
1.5 output
1.8 output
2.0 output
2.5 output
3.3 output
5.0 output
off converter input current
shutdown input idle current
min
typ
max
units
8.3
12
14.0
Vdc
8.0
7.9
0.1
3.5
25
30
30
35
45
50
inrush current
input reflected-ripple current
Vdc
Vdc
Vdc
P-P thru 1µH inductor, 5Hz to 20MHz
A
mA
mA
mA
mA
mA
mA
mA
mA
10
mA
0.1
A2s
150
mA
OUTPUT
parameter
min
capacitive load
low ESR
output voltage set point
at nominal input
trim adjustment range
selected by an external resistor
line regulation
low to high
load regulation
10~100% load
0.7525
3,000
µF
5.0
50% load step change
5
A
200
mV
300
positive logic
logic low (module off)
logic high (module on)
negative logic
Vdc
±0.5
kHz
or open circuit
Vdc
or open circuit
0.4
Vdc
1
mA
3.5
ms
leakage current
start-up time
rise time
temperature coefficient
units
±0.2
switching frequency
remote on/off
max
±1.5
operating current range
transient response deviation
typ
3.5
-40~85°C
±0.03
ms
%/°C
PROTECTIONS
parameter
continuous, hiccup
min
typ
max
120
units
°C
SAFETY AND COMPLIANCE
parameter
safety approvals
60950-1: UL/cUL
MTBF
as per MIL-HDBK-217F @ 25°C
RoHS
yes
min
1,500,000
cui.com
typ
max
units
hours
Product Page
3D Model
date 11/02/2021 │ page 3 of 11
ENVIRONMENTAL
parameter
min
max
units
operating temperature
see derating curve
-40
85
°C
-55
125
°C
storage temperature
DERATING CURVES
Figure 1
cui.com
typ
Product Page
3D Model
date 11/02/2021 │ page 4 of 11
MECHANICAL
parameter
dimensions
22.9 x 10.16 x 5.6 (0.9 x 0.4 x 0.22 inch)
min
weight
units: inches [mm]
tolerance: x.xx ±0.02 [±0.5], x.xxx ±0.010 [0.25]
PIN CONNECTIONS
Function
1
+Vo
2
Trim
3
Common
4
+Vin
5
REM
cui.com
max
units
mm
2.3
MECHANICAL DRAWING
Pin
typ
g
Product Page
EFFICIENCY CURVES
cui.com
3D Model
date 11/02/2021 │ page 5 of 11
Product Page
3D Model
date 11/02/2021 │ page 6 of 11
THEORY OF OPERATION
A block diagram of the VPOL5A-12-SMT series converter is shown in Figure 2. Extremely high efficiency power
conversion is achieved through the use of synchronous rectification and drive techniques. Essentially, the
powerful VPOL5A-12-SMT series topology is based on a non-isolated synchronous buck converter. The control
loop is optimized for unconditional stability, fast transient response and a very tight line and load regulation. In
a typical pre-bias application the VPOL5A-12-SMT series converters do not draw any reverse current at
start-up. The output voltage can be adjusted from 0.75 to 5.0vdc, using the TRIM pin with a external resistor.
The converter can be shut down via a remote ON/OFF input that is referenced to ground. This input is
compatible with popular logic devices; a 'positive' logic input is supplied as standard. Positive logic implies
that the converter is enabled if the remote ON/OFF input is high (or floating), and disabled if it is low. The
converter is also protected against over-temperature conditions. If the converter is overloaded or the ambient
temperature gets too high, the converter will shut down to protect the unit.
Figure 2
cui.com
Product Page
3D Model
date 11/02/2021 │ page 7 of 11
TYPICAL APPLICATION CIRCUITS
The SMT converters must be must be connected to a low AC source impedance. To avoid problems with loop
stability source inductance should be low. Also, the input capacitors should be placed close to the converter
input pins to de-couple distribution inductance. However, the external input capacitors are chosen for suitable
ripple handling capability. Low ESR polymers are a good choice. They have high capacitance, high ripple
rating and low ESR (typical
很抱歉,暂时无法提供与“VPOL5A-12-SMT”相匹配的价格&库存,您可以联系我们找货
