Additional Resources:
Product Page
3D Model
PCB Footprint
date
07/09/2021
page
1 of 10
SERIES: PCN2-S │ DESCRIPTION: DC-DC CONVERTER
FEATURES
up to 2 W isolated output
industry standard SIP package
nominal input voltages: 5, 12, 24 Vdc
single/dual unregulated output
1,000 Vdc isolation voltage
low ripple and noise
-40 to 100°C
efficiency up to 86%
MODEL
input
voltage
output
voltage
output
current
output
power
ripple
& noise1
efficiency
typ
(Vdc)
range
(Vdc)
(Vdc)
min
(mA)
max
(mA)
max
(W)
max
(mVp-p)
typ
PCN2-S5-S5-S
5
4.5~5.5
5
2
100
82
PCN2-S5-S12-S
5
4.5~5.5
12
2
150
86
PCN2-S5-S15-S
5
4.5~5.5
15
2
150
85
PCN2-S5-D5-S
5
4.5~5.5
±5
±200
2
150
83
PCN2-S5-D12-S
5
4.5~5.5
±12
±83
2
150
86
PCN2-S5-D15-S
5
4.5~5.5
±15
±67
2
150
86
PCN2-S12-S5-S
12
10.8~13.2
5
2
100
82
PCN2-S12-S12-S
12
10.8~13.2
12
2
150
83
PCN2-S12-S15-S
12
10.8~13.2
15
2
150
84
PCN2-S12-D5-S
12
10.8~13.2
±5
±200
2
150
82
PCN2-S12-D12-S
12
10.8~13.2
±12
±83
2
150
82
PCN2-S12-D15-S
12
10.8~13.2
±15
±67
2
150
84
PCN2-S24-S5-S
24
21.6~26.4
5
2
100
79
PCN2-S24-S12-S
24
21.6~26.4
12
2
150
81
PCN2-S24-S15-S
24
21.6~26.4
15
2
150
82
PCN2-S24-D5-S
24
21.6~26.4
±5
±200
2
150
79
PCN2-S24-D12-S
24
21.6~26.4
±12
±83
2
150
81
PCN2-S24-D15-S
24
21.6~26.4
±15
±67
2
150
82
Notes:
1. At full load, nominal input, 20 MHz bandwidth oscilloscope, with a 0.33 µF ceramic capacitor on the output.
2. Required to add a 2.2 µF (5 & 12 Vdc input models) or 10 µF (24 Vdc input models) ceramic capacitor to the input to reduce input voltage stress.
3. All specifications are measured at Ta=25°C, nominal input voltage, and rated output load unless otherwise specified.
PART NUMBER KEY
PCN2 - SXX - X XX - S
Base Number
Input Voltage
Output
S = single
D = dual
cui.com
Output Voltage
Packaging Style:
S = SIP
Product Page
3D Model
PCB Footprint
CUI Inc │ SERIES: PCN2-S │ DESCRIPTION: DC-DC CONVERTER
date 07/09/2021 │ page 2 of 10
INPUT
parameter
conditions/description
min
typ
max
units
operating input voltage
5 Vdc input models
12 Vdc input models
24 Vdc input models
4.5
10.8
21.6
5
12
24
5.5
13.2
26.4
Vdc
Vdc
Vdc
surge voltage
for maximum of 100 ms
5 Vdc input models
12 Vdc input models
24 Vdc input models
9
18
30
Vdc
Vdc
Vdc
current
5 Vdc input models
12 Vdc input models
24 Vdc input models
filter
capacitive
500
210
110
mA
mA
mA
input reverse polarity protection no
input fuse
Notes:
1 A time delay fuse for 5 Vdc input models (recommended)
500 mA time delay fuse for 12 Vdc input models (recommended)
250 mA time delay fuse for 24 Vdc input models (recommended)
1. Required to add a 2.2 µF (5 & 12 Vdc input models) or 10 µF (24 Vdc input models) ceramic capacitor to the input to reduce input voltage stress.
OUTPUT
parameter
maximum capacitive load
at full load
min
typ
voltage accuracy
line regulation
1.0% change in input voltage
load regulation
from full load to 20% load
switching frequency
at nominal Vin, full load
max
units
470
μF
±3.0
±1.2
±10
80
temperature coefficient
kHz
±0.05
%/°C
max
units
1
s
max
units
PROTECTIONS
parameter
short circuit protection
momentary
min
typ
SAFETY AND COMPLIANCE
parameter
isolation voltage
input to output for 1 minute
1,000
min
isolation resistance
input to output
1,000
isolation capacitance
input to output
conducted emissions
EN 55022 Class A & Class B (external circuit required,
see Figure 4)
MTBF
as per MIL-HDBK-217F, full load, GB, 25°C
RoHS
2011/65/EU
typ
Vdc
MΩ
15
pF
3,300,000
hours
ENVIRONMENTAL
parameter
min
max
units
operating temperature
see derating curve
-40
100
°C
-55
125
°C
95
storage temperature
operating humidity
non-condensing
cui.com
typ
Product Page
3D Model
PCB Footprint
date 07/09/2021 │ page 3 of 10
SOLDERABILITY
wave soldering
see wave soldering profile
Notes:
1.
2.
3.
4.
5.
min
typ
max
units
260
°C
max
units
Temperature (°C)
parameter
Soldering materials: Sn/Cu/Ni
Ramp up rate during preheat: 1.4°C/s (from 50°C to 100°C)
Soaking temperature: 0.5°C/s (from 100°C to 130°C), 60±20 seconds
Peak temperature: 260°C, above 250°C for 3~6 seconds
Ramp down rate during cooling: -10°C/s (from 260°C to 150°C)
Time (Seconds)
MECHANICAL
parameter
min
dimensions
0.77 x 0.28 x 0.40 [19.6 x 7.2 x 10.2 mm]
case material
non-conductive black plastic
typ
inches
weight
2.7
MECHANICAL DRAWING
units: inches [mm]
tolerance: X.XX ±0.01 [±0.25]
X.XXX ±0.005 [±0.13]
pin section tolerance: ±0.002[±0.05]
PIN CONNECTIONS
Single
Dual
+Vin
+Vin
2
-Vin
-Vin
4
-Vout
-Vout
5
No pin
Common
6
+Vout
+Vout
0.09[2.3] 0.300[7.62]
0.100[2.54]
0.8mm PLATED THROUGH HOLE
1.5mm PAD SIZE
0.28[7.2]
1
Function
0.066 [1.68]
PIN
Recommended PCB Layout
Top View
cui.com
g
Product Page
3D Model
PCB Footprint
date 07/09/2021 │ page 4 of 10
DERATING CURVE
EFFICIENCY CURVES
cui.com
Product Page
3D Model
PCB Footprint
date 07/09/2021 │ page 5 of 10
EFFICIENCY CURVES (CONTINUED)
cui.com
Product Page
3D Model
PCB Footprint
date 07/09/2021 │ page 6 of 10
cui.com
Product Page
3D Model
PCB Footprint
date 07/09/2021 │ page 7 of 10
PACKAGING
units: mm
Tube size: 20 x 11 x 330 mm
QTY: 14 pcs
cui.com
Product Page
3D Model
PCB Footprint
date 07/09/2021 │ page 8 of 10
TEST CONFIGURATIONS
Input Ripple Current & Output Noise
Figure 1 Measuring Input
Ripple Current
Table 1
Input
Voltage
(Vdc)
L1
C1
C2
5
12 µH
2.2 µF tantalum capacitor
NC
12
12 µH
NC
24
12 µH
10 µF ceramic capacitor
NC
Figure 2 Measuring Output Ripple &
Noise for Single Output Models
Figure 3 Measuring Output Ripple &
Noise for Dual Output Models
Table 2
Input
Voltage
(Vdc)
Cin
5
2.2 µF ceramic capacitor
12
24
cui.com
Product Page
3D Model
PCB Footprint
date 07/09/2021 │ page 9 of 10
EMC RECOMMENDED CIRCUIT
Test Condition
Input Voltage: Nominal
Output Load: Full Load
Figure 4 Conducted Emissions Test Circuit
Table 3
Table 4
EN55022 Class A
Recommended External Circuit Components
EN55022 Class B
Model
C11
C21
L1
C11
C21
L1
PCN2-S5-S5-S
4.7 µF / 50 V
NC
2.2 µH
PCN2-S5-S12-S
4.7 µF / 50 V
NC
2.2 µH
PCN2-S5-S5-S
10 µF / 25 V
NC
5.6 µH
PCN2-S5-S12-S
10 µF / 25 V
NC
5.6 µH
PCN2-S5-S15-S
10 µF / 25 V
NC
PCN2-S5-D5-S
4.7 µF / 50 V
NC
5.6 µH
PCN2-S5-S15-S
10 µF / 25 V
10 µF / 25 V
5.6 µH
2.2 µH
PCN2-S5-D5-S
10 µF / 25 V
NC
5.6 µH
PCN2-S5-D12-S
4.7 µF / 50 V
PCN2-S5-D15-S
10 µF / 25 V
NC
2.2 µH
PCN2-S5-D12-S
10 µF / 25 V
NC
5.6 µH
NC
5.6 µH
PCN2-S5-D15-S
10 µF / 25 V
10 µF / 25 V
5.6 µH
PCN2-S12-S5-S
PCN2-S12-S12-S
10 µF / 25 V
NC
5.6 µH
PCN2-S12-S5-S
10 µF / 25 V
10 µF / 25 V
5.6 µH
4.7 µF / 50 V
NC
5.6 µH
PCN2-S12-S12-S
10 µF / 25 V
10 µF / 25 V
5.6 µH
PCN2-S12-S15-S
PCN2-S12-D5-S
4.7 µF / 50 V
NC
5.6 µH
PCN2-S12-S15-S
10 µF / 25 V
10 µF / 25 V
5.6 µH
10 µF / 25 V
NC
5.6 µH
PCN2-S12-D5-S
10 µF / 25 V
10 µF / 25 V
5.6 µH
PCN2-S12-D12-S
4.7 µF / 50 V
NC
5.6 µH
PCN2-S12-D12-S
10 µF / 25 V
10 µF / 25 V
5.6 µH
PCN2-S12-D15-S
4.7 µF / 50 V
NC
5.6 µH
PCN2-S12-D15-S
10 µF / 25 V
10 µF / 25 V
5.6 µH
PCN2-S24-S5-S
4.7 µF / 50 V
4.7 µF / 50 V
5.6 µH
PCN2-S24-S5-S
10 µF / 50 V
10 µF / 50 V
5.6 µH
PCN2-S24-S12-S
4.7 µF / 50 V
4.7 µF / 50 V
5.6 µH
PCN2-S24-S12-S
10 µF / 50 V
10 µF / 50 V
5.6 µH
PCN2-S24-S15-S
4.7 µF / 50 V
4.7 µF / 50 V
5.6 µH
PCN2-S24-S15-S
10 µF / 50 V
10 µF / 50 V
5.6 µH
PCN2-S24-D5-S
4.7 µF / 50 V
4.7 µF / 50 V
5.6 µH
PCN2-S24-D5-S
10 µF / 50 V
10 µF / 50 V
5.6 µH
PCN2-S24-D12-S
4.7 µF / 50 V
4.7 µF / 50 V
5.6 µH
PCN2-S24-D12-S
10 µF / 50 V
10 µF / 50 V
5.6 µH
PCN2-S24-D15-S
4.7 µF / 50 V
4.7 µF / 50 V
5.6 µH
PCN2-S24-D15-S
10 µF / 50 V
10 µF / 50 V
5.6 µH
Notes:
1. Ceramic Capacitor
Model
Notes:
cui.com
Product Page
3D Model
PCB Footprint
date 07/09/2021 │ page 10 of 10
REVISION HISTORY
rev.
description
date
1.0
initial release
07/26/2016
1.01
company logo updated
03/30/2021
1.02
derating, efficiency curves and circuit figures updated
07/09/2021
The revision history provided is for informational purposes only and is believed to be accurate.
Headquarters
20050 SW 112th Ave.
Tualatin, OR 97062
800.275.4899
Fax 503.612.2383
cui.com
techsupport@cui.com
CUI offers a two (2) year limited warranty. Complete warranty information is listed on our website.
CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is
assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a
life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
很抱歉,暂时无法提供与“PCN2-S12-D15-S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+51.91289
- 10+50.50984
- 30+44.16980
- 105+43.73135
- 255+43.40689
