PEM1-S3-S5-S
PEM1-S3-S5-S
    CUIDEVICES
    CONV DC/DC 1W 5V 200MA OUT
PEM1-S3-S5-S 数据手册
Additional Resources: Product Page | 3D Model | PCB Footprint date 07/07/2021 page 1 of 7 SERIES: PEM1-S │ DESCRIPTION: DC-DC CONVERTER FEATURES • • • • • • • • • • 1 W isolated output smaller package single/dual unregulated output 3,000 Vdc isolation short circuit protection extended temperature range (-40~105°C) antistatic protection up to 8kV high efficiency at light load efficiency up to 81% EN 62368-1 MODEL input voltage output voltage output current output power ripple and noise2 efficiency typ (Vdc) range (Vdc) (Vdc) min (mA) max (mA) max (W) typ (mVp-p) typ (%) PEM1-S3-S3-S 3.3 2.97~3.63 3.3 30 303 1 60 73 PEM1-S3-S5-S 3.3 2.97~3.63 5 20 200 1 60 78 PEM1-S5-S3-S 5 4.5~5.5 3.3 30 303 1 60 73 PEM1-S5-S5-S 5 4.5~5.5 5 20 200 1 60 80 PEM1-S5-S12-S1 5 4.5~5.5 12 9 83 1 60 80 1 PEM1-S5-S15-S 5 4.5~5.5 15 7 67 1 60 81 PEM1-S5-S24-S1 5 4.5~5.5 24 5 42 1 60 81 PEM1-S5-D3-S 5 4.5~5.5 ±3.3 ±15 ±152 1 60 73 PEM1-S5-D5-S1 5 4.5~5.5 ±5 ±10 ±100 1 60 80 1 PEM1-S5-D12-S 5 4.5~5.5 ±12 ±5 ±42 1 60 80 PEM1-S5-D15-S1 5 4.5~5.5 ±15 ±4 ±33 1 60 81 1 PEM1-S5-D24-S 5 4.5~5.5 ±24 ±2 ±21 1 60 81 PEM1-S12-S3-S 12 10.8~13.2 3.3 30 303 1 60 75 PEM1-S12-S5-S 12 10.8~13.2 5 20 200 1 60 80 PEM1-S12-S12-S1 12 10.8~13.2 12 9 83 1 60 80 PEM1-S12-S15-S 12 10.8~13.2 15 7 67 1 60 81 PEM1-S12-D3-S 12 10.8~13.2 ±3.3 ±15 ±152 1 60 74 PEM1-S12-D5-S1 12 10.8~13.2 ±5 ±10 ±100 1 60 80 1 PEM1-S12-D12-S 12 10.8~13.2 ±12 ±5 ±42 1 60 81 PEM1-S12-D15-S1 12 10.8~13.2 ±15 ±4 ±33 1 60 81 PEM1-S15-S5-S 15 13.5~16.5 5 20 200 1 60 80 PEM1-S15-S12-S 15 13.5~16.5 12 9 83 1 60 80 PEM1-S15-S15-S 15 13.5~16.5 15 7 67 1 60 81 PEM1-S15-D5-S 15 13.5~16.5 ±5 ±10 ±100 1 60 80 PEM1-S15-D15-S 15 13.5~16.5 ±15 ±4 ±33 1 60 81 PEM1-S24-S3-S 24 21.6~26.4 3.3 30 303 1 60 75 PEM1-S24-S5-S 24 21.6~26.4 5 20 200 1 60 79 1 1 1 1 Notes: 1. UL approved 2. Ripple and noise are measured at 20 MHz BW by “parallel cable” method with 1 μF ceramic and 10 μF electrolytic capacitors on the output. cui.com Additional Resources: Product Page | 3D Model | PCB Footprint CUI Inc │ SERIES: PEM1-S │ DESCRIPTION: DC-DC CONVERTER MODEL (CONTINUED) input voltage date 07/07/2021 │ page 2 of 7 output voltage output current output power ripple and noise2 efficiency typ (Vdc) range (Vdc) (Vdc) min (mA) max (mA) max (W) typ (mVp-p) typ (%) PEM1-S24-S12-S1 24 21.6~26.4 12 9 83 1 60 81 PEM1-S24-S15-S1 24 21.6~26.4 15 7 67 1 60 81 PEM1-S24-S24-S 24 21.6~26.4 24 5 42 1 60 81 PEM1-S24-D3-S 24 21.6~26.4 ±3.3 ±15 ±152 1 60 73 PEM1-S24-D5-S 24 21.6~26.4 ±5 ±10 ±100 1 60 80 PEM1-S24-D12-S1 24 21.6~26.4 ±12 ±5 ±42 1 60 81 1 PEM1-S24-D15-S 24 21.6~26.4 ±15 ±4 ±33 1 60 79 PEM1-S24-D24-S1 24 21.6~26.4 ±24 ±2 ±21 1 60 80 1 1 Notes: 1. UL approved 2. Ripple and noise are measured at 20 MHz BW by “parallel cable” method with 1 μF ceramic and 10 μF electrolytic capacitors on the output. PART NUMBER KEY PEM1 - SXX - XXX -S Base Number Output S = single D = dual Input Voltage Output Voltage Packaging Style SIP INPUT parameter conditions/description min typ max units operating input voltage 3.3 Vdc input models 5 Vdc input models 12 Vdc input models 15 Vdc input models 24 Vdc input models 2.97 4.5 10.8 13.5 21.6 3.3 5 12 15 24 3.63 5.5 13.2 16.5 26.4 Vdc Vdc Vdc Vdc Vdc surge voltage for maximum of 1 second 3.3 Vdc input models 5 Vdc input models 12 Vdc input models 15 Vdc input models 24 Vdc input models -0.7 -0.7 -0.7 -0.7 -0.7 5 9 18 21 30 Vdc Vdc Vdc Vdc Vdc filter capacitance filter max units ±1.5 ±1.2 % % OUTPUT parameter conditions/description min typ line regulation for Vin change of 1% 3.3 Vdc output models all other models load regulation measure from 10% load to full load 3.3 Vdc input models 5 Vdc input models 12 Vdc input models 15 Vdc input models 24 Vdc input models voltage accuracy see tolerance envelope curve voltage balance dual output, balanced loads ±0.5 switching frequency at full load, nominal input voltage 100 temperature coefficient at full load 18 12 8 7 6 % % % % % ±1 ±0.03 cui.com % kHz %/°C Additional Resources: Product Page | 3D Model | PCB Footprint CUI Inc │ SERIES: PEM1-S │ DESCRIPTION: DC-DC CONVERTER date 07/07/2021 │ page 3 of 7 PROTECTIONS parameter conditions/description min typ short circuit protection1 Note: max units 1 s max units 1. The supply voltage must be discontinued at the end of the short circuit duration. SAFETY AND COMPLIANCE parameter conditions/description isolation voltage input to output for 1 minute, 1 mA max. leakage current 3,000 Vdc isolation resistance input to output at 500 Vdc 1,000 MΩ isolation capacitance input to output, 100KHz, 0.1V safety approvals2 certified to 62368-1: EN certified to 60950-1: UL conducted emissions CISPR22/EN55022, class B (external circuit required, see Figure 1) radiated emissions CISPR22/EN55022, class B (external circuit required, see Figure 1) ESD IEC/EN61000-4-2, class B, contact ± 8kV for single outputs IEC/EN61000-4-2, class B, contact ± 6kV for dual outputs MTBF as per MIL-HDBK-217F @ 25°C RoHS min typ 20 pF 3,500,000 hours 2011/65/EU Note: 2. See specific models noted on pages 1 & 2. ENVIRONMENTAL parameter conditions/description min max units operating temperature see derating curve -40 105 °C -55 125 °C 95 % storage temperature storage humidity non-condensing temperature rise at Ta = 25°C typ 25 °C SOLDERABILITY parameter conditions/description hand soldering wave soldering3 Notes: min typ max units 1.5 mm from case for 10 seconds 300 °C see wave soldering profile 260 °C 3. Preheat conditions: At 120°C for over 1 minute. Peak Temp. 260°C Max. 250 Wave Soldering Time 4 Sec. Max. 250 200 Temperature (°C) Temperature (°C) 200 150 120 >60 seconds 100 50 0 10 Sec. Max. 150 100 50 0 Time (sec.) Preheat Profile Time (sec.) Wave Soldering Profile cui.com Additional Resources: Product Page | 3D Model | PCB Footprint CUI Inc │ SERIES: PEM1-S │ DESCRIPTION: DC-DC CONVERTER date 07/07/2021 │ page 4 of 7 MECHANICAL parameter conditions/description dimensions 19.50 x 6.00 x 9.30 (0.768 x 0.236 x 0.366 inch) min case material epoxy resin (UL94-V0) weight units: mm[inch] tolerance: ±0.25[±0.010] pin section tolerance: ±0.10[±0.004] PIN CONNECTIONS Single Output Dual Output 1 Vin Vin 2 GND GND 5 0V -Vo 6 No Pin 0V 7 +Vo +Vo cui.com max units mm 2.4 MECHANICAL DRAWING PIN typ g Additional Resources: Product Page | 3D Model | PCB Footprint CUI Inc │ SERIES: PEM1-S │ DESCRIPTION: DC-DC CONVERTER date 07/07/2021 │ page 5 of 7 DERATING CURVES EMC RECOMMENDED CIRCUIT Figure 1 Table 1 Recommended external circuit components Vin (Vdc) C1 LDM 3.3 4.7μF/50V 6.8μH 5 4.7μF/50V 6.8μH 12 4.7μF/50V 6.8μH 15 4.7μF/50V 6.8μH 4.7μF/50V 6.8μH 24 Note: 1. See Table 3 for Cout values. TEST CONFIGURATION Figure 2 Table 2 External components Note: Input reflected-ripple current is measured with an inductor Lin and Capacitor Cin to simulate source impedance. cui.com Lin 4.7μH Cin 220μF, ESR < 1.0Ω at 100 kHz Additional Resources: Product Page | 3D Model | PCB Footprint CUI Inc │ SERIES: PEM1-S │ DESCRIPTION: DC-DC CONVERTER date 07/07/2021 │ page 6 of 7 APPLICATION NOTES 1. Output load requirement To ensure this module can operate efficiently and reliably, the minimum output load may not be less than 10% of the full load during operation. If the actual output power is low, connect a resistor at the output end in parallel to increase the load. 2. Overload Protection Under normal operating conditions, the output circuit of this product has no protection against overload. The simplest method to add this is to add a circuit breaker to the circuit. 3. Recommended circuit If you want to further decrease the input/output ripple, you can increase the capacitance accordingly or choose capacitors with low ESR (see Figure 3 & Table 3). However, the capacitance of the output filter capacitor must be appropriate. If the capacitance is too high, a startup problem might arise. For every channel of the output, to ensure safe and reliable operation, the maximum capacitance must be less than the maximum capacitive load (see Table 4). Figure 3 Single output Dual output Table 3 Table 4 Vin (Vdc) Cin (µF) Single Vo (Vdc) Cout (µF) Dual Vo (Vdc) Cout (µF) Single Vout (Vdc) Max. Capacitive Load (μF) Dual Vout (Vdc) Max. Capacitive Load1 (μF) 3.3 4.7 3.3 10 ±3.3 4.7 3.3 220 3.3 100 5 4.7 5 10 ±5 4.7 5 220 5 100 12 2.2 12 2.2 ±12 1 12 220 12 100 15 2.2 15 1 ±15 0.47 15 220 15 100 24 1 24 1 ±24 0.47 220 24 100 Note: Note: It’s not recommended to connect any external capacitors in applications with less than 0.5 watt output. 1. 2. 3. 4. 24 Note: 1. For each output. Operation under minimum load will not damage the converter; however, they may not meet all specifications listed. Max. capacitive load tested at input voltage range and full load. It is recommended to use either ceramic capacitors or electrolytic capacitors on the input and the output. Using tantalum capacitors may increase the risk of failure. All specifications measured at: Ta=25°C, humidity
PEM1-S3-S5-S 价格&库存
很抱歉,暂时无法提供与“PEM1-S3-S5-S”相匹配的价格&库存,您可以联系我们找货
