PDM1-S12-D24-S
PDM1-S12-D24-S
    CUIDEVICES
    CONVDC/DC1W+/-24V21MAOUT
PDM1-S12-D24-S 数据手册
Additional Resources: Product Page | 3D Model | PCB Footprint date 09/07/2022 page 1 of 7 SERIES: PDM1-S │ DESCRIPTION: DC-DC CONVERTER FEATURES • • • • • • • • • 1 W isolated output smaller package single/dual unregulated output 1,500 Vdc isolation short circuit protection extended temperature range (-40~105°C) antistatic protection up to 8kV high efficiency at light load efficiency up to 80% MODEL input voltage output voltage output current output power ripple and noise2 efficiency typ (Vdc) range (Vdc) (Vdc) min (mA) max (mA) max (W) typ (mVp-p) typ (%) PDM1-S3-S3-S 3.3 2.97~3.63 3.3 31 303 1 60 72 PDM1-S3-S5-S 3.3 2.97~3.63 5 20 200 1 60 78 PDM1-S3-S9-S 3.3 2.97~3.63 9 11 111 1 60 78 PDM1-S3-S12-S 3.3 2.97~3.63 12 9 84 1 60 78 PDM1-S3-S15-S 3.3 2.97~3.63 15 7 67 1 60 78 PDM1-S3-D5-S 3.3 2.97~3.63 ±5 ±10 ±100 1 60 78 PDM1-S3-D12-S 3.3 2.97~3.63 ±12 ±5 ±42 1 60 78 PDM1-S3-D15-S 3.3 2.97~3.63 ±15 ±4 ±34 1 60 76 PDM1-S5-S3-S 5 4.5~5.5 3.3 31 303 1 60 74 1 PDM1-S5-S5-S 5 4.5~5.5 5 20 200 1 60 80 PDM1-S5-S9-S1 5 4.5~5.5 9 11 111 1 60 80 1 PDM1-S5-S12-S 5 4.5~5.5 12 9 84 1 60 80 PDM1-S5-S15-S1 5 4.5~5.5 15 7 67 1 60 80 PDM1-S5-S24-S 5 4.5~5.5 24 5 42 1 60 80 PDM1-S5-D3-S 5 4.5~5.5 ±3.3 ±15 ±152 1 60 71 PDM1-S5-D5-S 5 4.5~5.5 ±5 ±10 ±100 1 60 80 PDM1-S5-D9-S 5 4.5~5.5 ±9 ±6 ±56 1 60 80 PDM1-S5-D12-S1 5 4.5~5.5 ±12 ±5 ±42 1 60 80 1 PDM1-S5-D15-S 5 4.5~5.5 ±15 ±4 ±34 1 60 80 PDM1-S5-D24-S1 5 4.5~5.5 ±24 ±3 ±21 1 60 80 PDM1-S9-D9-S 9 8.1~9.9 ±9 ±6 ±56 1 60 80 PDM1-S9-D15-S 9 8.1~9.9 ±15 ±4 ±34 1 60 80 PDM1-S12-S3-S 12 10.8~13.2 3.3 31 303 1 60 76 PDM1-S12-S5-S1 12 10.8~13.2 5 20 200 1 60 80 PDM1-S12-S9-S 12 10.8~13.2 9 11 111 1 60 80 PDM1-S12-S12-S1 12 10.8~13.2 12 9 84 1 60 80 PDM1-S12-S15-S 12 10.8~13.2 15 7 67 1 60 80 1 1 1 1 1 Notes: 1. UL approved 2. Ripple and noise are measured at 20 MHz BW by “parallel cable” method with 1 μF ceramic and 10 μF electrolytic capacitors on the output. cui.com Additional Resources: Product Page | 3D Model | PCB Footprint CUI Inc │ SERIES: PDM1-S │ DESCRIPTION: DC-DC CONVERTER MODEL (CONTINUED) input voltage date 09/07/2022 │ page 2 of 7 output voltage output current ripple and noise2 efficiency max (mA) max (W) typ (mVp-p) typ (%) typ (Vdc) range (Vdc) PDM1-S12-S24-S1 12 10.8~13.2 24 5 42 1 60 80 PDM1-S12-D3-S 12 10.8~13.2 ±3.3 ±15 ±152 1 60 76 1 PDM1-S12-D5-S 12 10.8~13.2 ±5 ±10 ±100 1 60 80 PDM1-S12-D9-S1 12 10.8~13.2 ±9 ±6 ±56 1 60 80 1 PDM1-S12-D12-S 12 10.8~13.2 ±12 ±5 ±42 1 60 80 PDM1-S12-D15-S1 12 10.8~13.2 ±15 ±4 ±34 1 60 80 PDM1-S12-D24-S 12 10.8~13.2 ±24 ±3 ±21 1 60 80 PDM1-S15-S5-S 15 13.5~16.5 5 20 200 1 60 80 PDM1-S15-S9-S 15 13.5~16.5 9 11 111 1 60 80 PDM1-S15-S12-S 15 13.5~16.5 12 9 84 1 60 80 PDM1-S15-S15-S 15 13.5~16.5 15 7 67 1 60 80 PDM1-S15-S24-S 15 13.5~16.5 24 5 42 1 60 80 PDM1-S15-D5-S 15 13.5~16.5 ±5 ±10 ±100 1 60 80 PDM1-S15-D9-S 15 13.5~16.5 ±9 ±6 ±56 1 60 80 PDM1-S15-D12-S 15 13.5~16.5 ±12 ±5 ±42 1 60 80 PDM1-S15-D15-S 15 13.5~16.5 ±15 ±4 ±34 1 60 80 PDM1-S15-D24-S 15 13.5~16.5 ±24 ±3 ±21 1 60 80 PDM1-S24-S3-S 24 21.6~26.4 3.3 31 303 1 60 74 PDM1-S24-S5-S1 24 21.6~26.4 5 20 200 1 60 80 PDM1-S24-S9-S 24 21.6~26.4 9 11 111 1 60 80 PDM1-S24-S12-S1 24 21.6~26.4 12 9 84 1 60 80 1 PDM1-S24-S15-S 24 21.6~26.4 15 7 67 1 60 80 PDM1-S24-S24-S1 24 21.6~26.4 24 5 42 1 60 80 1 PDM1-S24-D5-S 24 21.6~26.4 ±5 ±10 ±100 1 60 80 PDM1-S24-D9-S1 24 21.6~26.4 ±9 ±6 ±56 1 60 80 1 PDM1-S24-D12-S 24 21.6~26.4 ±12 ±5 ±42 1 60 80 PDM1-S24-D15-S1 24 21.6~26.4 ±15 ±4 ±34 1 60 80 PDM1-S24-D24-S 24 21.6~26.4 ±24 ±3 ±21 1 60 80 1 1 1 Notes: (Vdc) min (mA) output power 1. UL approved 2. Ripple and noise are measured at 20 MHz BW by “parallel cable” method with 1 μF ceramic and 10 μF electrolytic capacitors on the output. PART NUMBER KEY PDM1 - SXX - XXX -S Base Number Output S = single D = dual Input Voltage cui.com Output Voltage Packaging Style SIP Additional Resources: Product Page | 3D Model | PCB Footprint CUI Inc │ SERIES: PDM1-S │ DESCRIPTION: DC-DC CONVERTER date 09/07/2022 │ page 3 of 7 INPUT parameter conditions/description min typ max units operating input voltage 3.3 Vdc input models 5 Vdc input models 9 Vdc input models 12 Vdc input models 15 Vdc input models 24 Vdc input models 2.97 4.5 8.1 10.8 13.5 21.6 3.3 5 9 12 15 24 3.63 5.5 9.9 13.2 16.5 26.4 Vdc Vdc Vdc Vdc Vdc Vdc surge voltage for maximum of 1 second 3.3 Vdc input models 5 Vdc input models 9 Vdc input models 12 Vdc input models 15 Vdc input models 24 Vdc input models -0.7 -0.7 -0.7 -0.7 -0.7 -0.7 5 9 12 18 21 30 Vdc Vdc Vdc Vdc Vdc Vdc filter capacitance filter max units ±1.5 ±1.2 % % OUTPUT parameter conditions/description line regulation for Vin change of 1% 3.3 Vdc output models all other models min load regulation measured from 10% load to full load 3.3 Vdc output models 5 Vdc output models 9 Vdc output models 12 Vdc output models 15 Vdc output models 24 Vdc output models voltage accuracy see tolerance envelope curve switching frequency 100% load, nominal input voltage temperature coefficient 100% load typ 18 12 9 8 7 6 % % % % % % 100 kHz ±0.03 %/°C max units 1 s max units PROTECTIONS parameter conditions/description short circuit protection 3.3 Vdc input single output models, 24 Vdc input single/dual output models, PDM1-S5-S24-S, PDM1-S5-D24-S, PDM1-S3-D15-S all other models: continuous, auto recovery 1 Notes: min typ 1. The supply voltage must be discontinued at the end of the short circuit duration SAFETY AND COMPLIANCE parameter conditions/description isolation voltage input to output, for 1 minute at 1 mA max. 1,500 isolation resistance input to output at 500 Vdc 1,000 isolation capacitance input to output at 100Khz/0.1V safety approvals certified to 60950-1: UL conducted emissions CISPR32/EN55032 class B (external circuit required, see Figure 1) radiated emissions CISPR32/EN55032 class B (external circuit required, see Figure 1) ESD IEC/EN61000-4-2, class B, contact ± 8kV for single outputs IEC/EN61000-4-2, class B, contact ± 6kV for dual outputs MTBF as per MIL-HDBK-217F at 25°C 2 RoHS Notes: min yes cui.com Vdc MΩ 20 3,500,000 2. See specific models noted on pages 1 and 2 typ pF hours Additional Resources: Product Page | 3D Model | PCB Footprint CUI Inc │ SERIES: PDM1-S │ DESCRIPTION: DC-DC CONVERTER date 09/07/2022 │ page 4 of 7 ENVIRONMENTAL parameter conditions/description min max units operating temperature see derating curve -40 105 °C -55 125 °C 95 % storage temperature storage humidity non-condensing temperature rise Ta = 25°C typ 25 °C SOLDERABILITY parameter conditions/description hand soldering wave soldering min typ max units 1.5 mm from case for 10 seconds 300 °C see wave soldering profile 260 °C max units Peak Temp. 260°C Max. Wave Soldering Time 4 Sec. Max. 250 Temperature (°C) 200 10 Sec. Max. 150 100 50 0 MECHANICAL Time (sec.) parameter conditions/description min dimensions 19.50 x 6.00 x 9.30 (0.768 x 0.236 x 0.366 inch) case material epoxy resin (UL94-V0) weight typ mm 2.4 MECHANICAL DRAWING units: mm[inch] tolerance: ±0.25[±0.010] pin section tolerance: ±0.10[±0.004] PIN CONNECTIONS PIN Single Output Dual Output 1 Vin Vin 2 GND GND 4 0V -Vo 5 No Pin 0V 6 +Vo +Vo Front View Side View Bottom View PCB Layout Top View cui.com Grid Size: 2.54mm x 2.54mm g Additional Resources: Product Page | 3D Model | PCB Footprint CUI Inc │ SERIES: PDM1-S │ DESCRIPTION: DC-DC CONVERTER date 09/07/2022 │ page 5 of 7 DERATING CURVES EMC RECOMMENDED CIRCUIT Figure 1 Table 1 Recommended external circuit components Vin (Vdc) C1 CY LDM 3.3 4.7μF/50V -- 6.8μH 5 4.7μF/50V -- 6.8μH 9 4.7μF/50V -- 6.8μH 12 4.7μF/50V -- 6.8μH 15 4.7μF/50V 1nF/2KV 6.8μH 4.7μF/50V 1nF/2KV 6.8μH 24 Note: cui.com 1. See Table 2 for Cout values. Additional Resources: Product Page | 3D Model | PCB Footprint CUI Inc │ SERIES: PDM1-S │ DESCRIPTION: DC-DC CONVERTER date 09/07/2022 │ page 6 of 7 APPLICATION NOTES 1. Output load requirement To ensure this module can operate efficiently and reliably, the minimum output load may not be less than 10% of the full load during operation. If the actual output power is low, connect a resistor at the output end in parallel to increase the load. 2. Recommended circuit If you want to further decrease the input/output ripple, you can increase the capacitance accordingly or choose capacitors with low ESR (see Figure 2 & Table 2). However, the capacitance of the output filter capacitor must be appropriate. If the capacitance is too high, a startup problem might arise. For every channel of the output, to ensure safe and reliable operation, the maximum capacitance must be less than the maximum capacitive load (see Table 3). Figure 2 Single output Dual output Table 2 Table 3 Vin (Vdc) Cin (µF) Single Vo (Vdc) Cout (µF) Dual Vo (Vdc) Cout (µF) Single Vout (Vdc) Max. Capacitive Load (μF) Dual Vout (Vdc) Max. Capacitive Load1 (μF) 3.3 4.7 3.3 10 ±3.3 4.7 3.3 220 3.3 100 5 4.7 5 10 ±5 4.7 5 220 5 100 9 2.2 9 2.2 ±9 1 9 220 9 100 12 2.2 12 2.2 ±12 1 12 220 12 100 15 2.2 15 1 ±15 0.47 15 220 15 100 24 1 24 1 ±24 0.47 24 220 24 100 Note: Note: It’s not recommended to connect any external capacitors in applications with less than 0.5 watt output. Note: 1. For each output. 1. Operation under minimum load will not damage the converter; however, they may not meet all specifications listed. 2. Max. capacitive load tested at input voltage range and full load. 3. All specifications measured at: Ta=25°C, humidity
PDM1-S12-D24-S 价格&库存
很抱歉,暂时无法提供与“PDM1-S12-D24-S”相匹配的价格&库存,您可以联系我们找货
