VHD1-S5-S9-DIP
VHD1-S5-S9-DIP
    CUIDEVICES
    DC/DC CONVERTER 9V 1W
VHD1-S5-S9-DIP 数据手册
Additional Resources: Product Page date 01/13/2014 page 1 of 5 SERIES: VHD1-DIP │ DESCRIPTION: DC-DC CONVERTER 1 W isolated output industry standard 17 pin DIP package single unregulated outputs 6,000 V isolation short circuit protection UL safety approvals wide temperature (-40~85°C) efficiency up to 75% U • • • • • • • • ED FEATURES input voltage typ (Vdc) range (Vdc) VHD1-S5-S5-DIP 5 4.5~5.5 VHD1-S5-S9-DIP 5 4.5~5.5 VHD1-S5-S12-DIP 5 4.5~5.5 5 4.5~5.5 VHD1-S12-S5-DIP 12 10.8~13.2 output current output power ripple and noise1 efficiency (Vdc) min (mA) max (mA) max (W) max (mVp-p) typ (%) 5 20 200 1 150 68 9 12 111 1 150 72 12 9 84 1 150 74 15 7 67 1 150 74 5 20 200 1 150 69 N VHD1-S5-S15-DIP output voltage TI MODEL N RoHS 12 10.8~13.2 9 12 111 1 150 72 12 10.8~13.2 12 9 84 1 150 74 VHD1-S12-S15-DIP 12 10.8~13.2 15 7 67 1 150 75 1. ripple and noise are measured at 20 MHz BW IS C Notes: O VHD1-S12-S9-DIP VHD1-S12-S12-DIP D PART NUMBER KEY Base Number VHD1 - SXX - SXX -DIP Input Voltage Output Voltage cui.com Packaging Style Additional Resources: Product Page CUI Inc │ SERIES: VHD1-DIP │ DESCRIPTION: DC-DC CONVERTER date 01/13/2014 │ page 2 of 5 INPUT conditions/description min typ max units operating input voltage 5 V model 12 V model 4.5 10.8 5 12 5.5 13.2 Vdc Vdc min OUTPUT parameter conditions/description line regulation for Vin change of 1% load regulation measured from 10% load to full load voltage accuracy see derating curves switching frequency 100% load, input voltage range PROTECTIONS 10 conditions/description min N parameter typ short circuit protection SAFETY AND COMPLIANCE units % 15 % kHz ±0.03 %/°C typ units 1 s max units conditions/description for 1 minute at 1 mA max. 6,000 Vdc isolation resistance at 500 Vdc 1,000 MΩ safety approvals UL 60950 (E222736) 3,500,000 hours ENVIRONMENTAL operating temperature storage temperature storage humidity temperature rise min typ max units -40 85 °C -55 125 °C non-condensing at full load 15 1.5 mm from case for 10 seconds D IS C lead temperature conditions/description O parameter N yes TI parameter RoHS compliant typ max isolation voltage MTBF min max ±1.2 250 U temperature coefficient ED parameter cui.com 95 % 25 °C 300 °C Additional Resources: Product Page CUI Inc │ SERIES: VHD1-DIP │ DESCRIPTION: DC-DC CONVERTER date 01/13/2014 │ page 3 of 5 DERATING CURVES 2. output voltage vs. output current ED 1. output power vs. ambient temperature Load (%) 100 80 60 40 -40 -20 0 20 40 60 71 85 100 U 20 120 MECHANICAL N Ambient Temperature (°C) parameter conditions/description dimensions 32.30 x 14.70 x 9.40 (0.768 x 0.396 x 0.492 inch) case material plastic (UL94-V0) MECHANICAL DRAWING N units: mm tolerance: ±0.25 pin section tolerance: ±0.10 mm O Side View 9.40 IS C 0.65 4.00 max 4.2 Layout 24 23 17 16 15 14 13 1 2 8 9 10 1112 g 1.00 2.54 2.54 PIN CONNECTIONS 32.30 24 23 17 16 15 14 13 14.70 1 2 8 9 10 11 1 2 cui.com units mm 27.94 Top View D typ TI weight min PIN FUNCTION 1 +Vin 2 -Vin 8 NC 10 -Vout 12 +Vout 13 +Vout 15 -Vout 17 NC + 0.15 / - 0 Additional Resources: Product Page CUI Inc │ SERIES: VHD1-DIP │ DESCRIPTION: DC-DC CONVERTER date 01/13/2014 │ page 4 of 5 APPLICATION NOTES Table 1 Input Voltage External Input Capacitance 5V 4.7 μF 12 V 2.2 μF 24 V 1.0 μF +Vin -Vin ED 1. Input filtering To reduce the reflected ripple current and minimize EMI, especially when the converter input is more than 2” away from the DC source, it is recommended to connect a low ESR electrolytic capacitor between Vin and Gnd. The values suggested are as shown in Table 1. If additional filtering is required, the capacitance may be increased, or expanded to an LC network as shown in Figure 1. L L C DC DC +Vout C -Vout U Figure 1 External Input Capacitance 5V 4.7 μF 9V 12 V -Vin REG +Vout DC DC -Vout 2.2 μF 1.0 μF 0.47 μF +Vin -Vin REG DC DC Figure 2 +Vout -Vout N 15 V +Vin TI Table 2 Output Voltage N 2. Output filtering An output capacitor is needed to meet output ripple requirements as shown in Table 2. Output capacitance may be increased for additional filtering, but should not exeed 10μF or expanded to an LC network as in Figure 1. 3. Minimum loading The converter needs a minimum of 10% loading to maintain output regulation. Operation under no-load conditions will not cause immediate damages but may reduce reliability, and cause performance not to meet specifications. O 4. Regulation With a semi-regulated design, the converter’s output voltage varies with load current and will change proportionally to the input voltage. If regulated output is needed, an external regulator can be used as shown in Figure 2. IS C 5. Protection The converter has minimal protection against input over-voltage or output over-load, and may be permanently damaged if exposed to these conditions. An input clamping device can be used for input voltage limiting. An input fuse or an output fuse can also be used to protect against over-loading. 6. Dual outputs used as a single output The +Vout and -Vout can be used to obtain a single output that is the sum of the two outputs. In this case, the COM pin shouldn’t be used. D 7. External Regulator An external 3-terminal regulator can be connected to the output of the converter to achieve full regulation. Make sure the converter’s output voltage provides sufficient head room for the regulator. An additional benefit is that the built-in protection features in the regulator, such as OCP, OTP, etc, will protect the converter also. In a complimentory supply, a negative output regulator must be used to achieve the negative regulated output. Note: All specifications measured at 25°C, humidity
VHD1-S5-S9-DIP 价格&库存
很抱歉,暂时无法提供与“VHD1-S5-S9-DIP”相匹配的价格&库存,您可以联系我们找货
