RS431/ RS432
RS431/ RS432 Precision Programmable Reference
FEATURES
DESCRIPTION
Reference Voltage Tolerance at 25°C
0.5% (A Grade)
1% (B Grade)
Programmable output voltage to 36 V
Low dynamic output impedance 0.2 Ω
Sink current capability of 0.5 mA to 100 mA
Equivalent full-range temperature
coefficient of 50ppm/°C typical
Temperature compensated for operation
over full rated operating temperature range
Low output noise voltage
Fast turn on response
Operation junction temperature from -40°C
to 150°C
The RS431 and RS432 device are three-terminal
adjustable shunt regulators, with a guaranteed thermal
stability over applicable temperature ranges. The output
voltage can be set to any value between VREF
(approximately 2.5V) and 36V with two external
resistors. These devices have provided a very sharp
turn-on characteristic, making these devices excellent
replacement for Zener diodes in many applications.
Both the RS431 and RS432 devices are offered in two
grades, with initial tolerances (at 25°C) of 0.5% and
1%, for A and B grade.
Device Information (1)
Lead-Free Packages: SOT23
APPLICATIONS
PART NUMBER
PACKAGE(PIN)
BODY SIZE (NOM)
RS431
SOT23(3)
1.30mm×2.92mm
RS432
SOT23(3)
1.30mm×2.92mm
(1)
Adjustable voltage and current referencing
Power supply
Zener replacement
Voltage monitoring
Comparator with integrated reference
As precision voltage reference
For more detail information packages, see the order sheet.
Function Block Diagram
CATHODE
REFERENCE
CATHODE
(K)
REFERENCE
(R)
2.5V Vref
ANODE(A)
ANODE
REV A.3
1 / 11
www.run-ic.com
RS431/ RS432
Revision History
Note: Page numbers for previous revisions may different from page numbers in the current version.
Version
Change Date
A.1
2018/11/03
A.2
2020/03/25
A.3
2021/10/28
Change Item
Initial version completed
(1) Change part-number to ordering information table for production management.
(2) Added Figure 8 Reference Voltage vs. Ambient Temperature
(1) Update parameters in Electrical Characteristics on Page 5@A.2 Version
(2) Update parameters in Typical Performance Characteristics on Page 7, 8@A.2 Version
2 / 11
www.run-ic.com
RS431/ RS432
Pin configuration and Functions (Top View)
Cathode 1
Ref 1
3 Anode
3 Anode
Ref 2
Cathode 2
RS431
RS432
Pin Description
PIN
NAME
DESCRIPTION
RS431
RS432
Cathode
1
2
Shunt Current/ Voltage input
Ref
2
1
Threshold relative to common anode
Anode
3
3
Common pin, normally connected to ground
3 / 11
www.run-ic.com
RS431/ RS432
PACKAGE/ORDERING INFORMATION
PRODUCT
ORDERING
NUMBER
VOLTAGE
TOLERANCE
PACKAGE
LEAD
PACKAGE
MARKING (1/2)
PACKAGE OPTION
RS431AYSF3
0.5%
SOT23
431AXX
Tape and Reel,3000
RS431BYSF3
1%
SOT23
431BXX
Tape and Reel,3000
RS432AYSF3
0.5%
SOT23
432AXX
Tape and Reel,3000
RS432BYSF3
1%
SOT23
432BXX
Tape and Reel,3000
RS431
RS432
NOTE:
(1) XX = Data Code
(2) There may be additional marking, which relates to the lot trace code information (include data code and vendor code), the logo or
the environmental category on the device.
4 / 11
www.run-ic.com
RS431/ RS432
SPECIFICATIONS
Absolute Maximum Ratings
over operating free-air temperature range (unless otherwise noted) (1)(2)
Characteristics
Symbol
MIN
MAX
UNIT
Cathode Voltage
VKA
-0.3
37
V
Cathode Current Range (Continuous)
IKA
-100
+155
mA
Reference Input Current Range
IREF
-0.05
+10
mA
Operating junction temperature
Topr
-40
Power Dissipation
PD
Storage temperature
Tstg
(1)
(2)
+150
-55
°C
mW
370
150
°C
Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress
ratings only, and functional operation of the device at these or any other conditions beyond those indicated under Recommended
Operating Conditions is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device
reliability.
All voltages are with respect to the GND pin.
ESD Ratings
V(ESD)
Electrostatic discharge
VALUE
UNIT
Human-body model (HBM)
±5000
V
Charge device model (CDM)
±1500
V
Machine model (MM)
±200
V
Recommended Operating Conditions
Characteristics
Symbol
MIN
MAX
UNIT
Cathode Voltage
VKA
VREF
36
V
IKA
0.5
100
mA
Operating Ambient Temperature Range
TA
-40
+125
°C
Thermal Information
RS431/ RS432
THERMAL METRIC (1)
SOT23
UNIT
3 PINS
RθJA
Junction-to-ambient thermal resistance
185.6
°C/W
RθJC (top)
Junction-to-case (top) thermal resistance
104.3
°C/W
RθJB
Junction-to-board thermal resistance
54.5
°C/W
ψJT
Junction-to-top characterization parameter
31.0
°C/W
ψJB
Junction-to-board characterization parameter
54.5
°C/W
RθJC (bot)
Junction-to-case (bottom) thermal resistance
N/A
°C/W
5 / 11
www.run-ic.com
RS431/ RS432
(Over recommended operating conditions, Full= -40°C to +125°C, typical values are at TA= +25°C, unless otherwise noted.)
PARAMETER
SYMBOL
MIN
TYP
MAX
UNIT
0.5%
2.488
2.50
2.512
V
1%
2.475
2.50
2.525
V
mV
ΔVKA=10V~VREF
-1.2
-2.0
ΔVKA=36V~10V
-1.5
-2.0
CONDITIONS
Reference Input Voltage
VREF
VKA=VREF,
IKA=10mA
Deviation of reference Input Voltage
Over temperature
ΔVREF
VKA=VREF, IKA=10mA
TA= -40°C ~ +125°C
Ratio of Change in Reference Input
Voltage to the Change in Cathode
Voltage
ΔVREF/ΔVKA
IKA=10mA
IREF
IKA=10mA, R1=10kΩ, R2=∞
1.7
4.0
uA
ΔIREF
TA= -40°C ~ +125°C
2
5
uA
Minimum cathode current for regulation IKA (min)
VKA=VREF
0.3
0.5
mA
Off-state Cathode Current
IKA (OFF)
VKA=36V, VREF=0V
0.05
0.5
uA
Dynamic Impedance
ZKA
VKA=VREF, IKA=1mA to100mA
f≤1.0KHz
0.2
0.5
Ω
Deviation of Reference Input Current
Over Full Temperature Range
6 / 11
mV/V
www.run-ic.com
RS431/ RS432
TYPICAL APPLICATIONS CIRCUIT
R3
VIN
VOUT
VOUT= (1+R1/R2)*VREF
R1
VREF
RS431
R2
Figure 1. Shunt Regulator
VIN
VOUT
R3
R4
R1
VREF
RS431
R2
Figure 2. High Current Shunt Regulator
VIN
R2
IOUT
R1
IOUT= VREF/R2+IKA
RS431
Figure 3. Current Source or Current Limit
7 / 11
www.run-ic.com
RS431/ RS432
140
120
100
80
60
40
-40
-60
VKA=VREF
TA=25℃
-1
Cathode Current(μA)
Cathode Current(mA)
TYPICAL PERFORMANCE CHARACTERISTICS
2
1200
1000
800
600
400
200
-400
-600
VKA=VREF
TA=25℃
IKA(min)
-1
3
2
3
Cathode Voltage (V)
Cathode Voltage (V)
Figure 4. Cathode Current vs Cathode Voltage
Figure 5. Cathode Current vs Cathode Voltage
TA=25℃
Input
2V/ div
IKA=10mA
TA=25℃
-5
-10
-15
-20
-25
Output
1V/ div
Change In Reference Input
Voltage (mV)
-35
-40
10
15
30
35
100us/ div
40
Cathode Voltage (V)
Figure 6. Change in Reference Input Voltage vs
Cathode voltage
Figure 7. Pulse Response
100
70
Voltage Amplification (dB)
Impedance (Ω)
IKA=1mA~100mA
TA=25℃
10
1
0.1
IKA=10mA
TA=25℃
60
50
40
30
1K
10K
100K
1M
10M
1K
Frequency (Hz)
Figure 8. Dynamic Impedance vs Frequency
10K
100K
1M
10M
Frequency (Hz)
Figure 9. Small Signal Voltage Amplification vs
Frequency
8 / 11
www.run-ic.com
RS431/ RS432
100
90 A VKA=VREF
B V =5V
80 C VKA =10V
KA
70 D VKA=15V
60
50
A
40
30
Stable
0.01
2.505
Reference Voltage VREF (V)
IKA-Cathode Current (mA)
TYPICAL PERFORMANCE CHARACTERISTICS (Continued)
TA=25℃
B
C
Stable
D
2.495
2.49
2.485
2.48
2.475
0.1
1
-40 -20
10
20 40 60 80 100 120 140
Temperature (℃)
CL-Load Capacitance (uF)
Figure 10. Cathode Current vs Load
Capacitance
Reference Input Current IREF (uA)
VKA=VREF
IKA= 10mA
2.5
Figure 11. Reference Voltage vs Ambient
Temperature
4
VKA=VREF
IKA= 10mA
3.5
3
2.5
2
1.5
1
0.5
Temperature (℃)
Figure 12. Reference Input Current vs Ambient
Temperature
9 / 11
www.run-ic.com
RS431/ RS432
PACKAGE OUTLINE DIMENSIONS
SOT23
D
1.90
b
2.29
E1
E
0.76
0.95
0.76
e
e1
RECOMMENDED LAND PATTERN (Unit: mm)
0.2
A A2
c
θ
L
A1
Dimensions In Millimeters
Dimensions In Inches
Symbol
Min
Max
Min
Max
A
0.900
1.150
0.035
0.045
A1
0.000
0.100
0.000
0.004
A2
0.900
1.050
0.035
0.041
b
0.300
0.500
0.012
0.020
c
0.080
0.150
0.003
0.006
D
2.800
3.000
0.110
0.118
E
1.200
1.400
0.047
0.055
E1
2.250
2.550
0.089
0.100
e
0.950 (BSC)
0.037 (BSC)
e1
1.800
2.000
0.071
0.079
L
0.300
0.500
0.012
0.020
θ
0°
8°
0°
8°
10 / 11
www.run-ic.com
RS431/ RS432
TAPE AND REEL INFORMATION
REEL DIMENSIONS
TAPE DIMENSION
Reel
Diameter
Reel Width(W1)
DIRECTION OF FEED
NOTE: The picture is only for reference. Please make the object as the standard.
KEY PARAMETER LIST OF TAPE AND REEL
Package Type
SOT23
Reel
Diameter
7’’
Reel Width
(mm)
9.5
A0
(mm)
3.15
B0
(mm)
2.77
11 / 11
K0
(mm)
1.22
P0
(mm)
4.0
P1
(mm)
4.0
P2
(mm)
2.0
W
(mm)
8.0
Pin1
Quadrant
Q3
www.run-ic.com
很抱歉,暂时无法提供与“RS431AYSF3”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.34841
- 20+0.31767
- 100+0.28693
- 500+0.25619
- 1000+0.24184
- 2000+0.23159
- 国内价格
- 1+3.79577
- 10+3.07362
- 25+2.81435
- 100+2.09407
- 250+1.89794
- 500+1.57003
- 1000+1.17766
