Technical Data
Materlal:
Pin(outer sleeve):Brass,machined CuZn38Pb2
Plating(outer sleeve):
Tin Plated:2 μm/80μ"NI,5μm/200μ"Sn
Gold Plated:2 μm"/80μ"Ni,0.8 μ" gold
Plating(Contact ):2 μm/80μ"NI,gold or Tin plated
Insulator:PPS UL94V-0
Cllp(Contact 4 Flnger):Beryllium copper,heat teated
Mating pin∅:0.40mm/0.66mm
1
2
3
Electrical:
Current rating:3Amps/contact max.
Contact resistance:≤4m Ω/contact
Insulation resistance:≥1000M Ω at V=100V
Dleiectric Withstanding Voltage:1000V AV Min
Operaling voltage:60VAC/DC
6
5
4
Mechanical:
-Insertion:0.7N typ
-Withdrawal:0.4N typ
Mechanical lige:min 500 cycle
Operaling temperature:-40 °C to+105°C
Soldering temperature:+255 °C
Critical Dimensions: *
P.C.B LAYOUT
2.00mm Machined Female Header
MF200V-11-XX-0740
很抱歉,暂时无法提供与“MF200V-11-40-0740”相匹配的价格&库存,您可以联系我们找货
