SPR01L-15
SPR01L-15
    OTHER
SPR01L-15 数据手册
SPR01 1W DC-DC Regulated Single Output Converter series ■ Features : 1000VDC I/O isolation Internal SMD technology Built-in EMI filter Cooling by free air convection Non-conductive plastic case Single in line package 100% burn-in test Low cost / High reliability Approvals: FCC / CE 2 years warranty SELECTION GUIDE ORDER NO. SPR01L-05 DC OUTPUT VOLTAGE 5V OUTPUT CURRENT RANGE 0 ~ 200mA EFFICIENCY 57% 65% 62% 62% ORDER NO. SPR01L-12 SPR01M-12 SPR01N-12 SPR01O-12 DC OUTPUT VOLTAGE 12V OUTPUT CURRENT RANGE 0 ~ 84mA EFFICIENCY 58% SPR01M-05 SPR01N-05 SPR01O-05 SPR01L-09 SPR01M-09 SPR01N-09 SPR01O-09 57% 60% 60% 56% SPR01L-15 SPR01M-15 SPR01N-15 SPR01O-15 9V 0 ~ 100mA 15V 0 ~ 67mA 60% 60% 58% 60% 62% 60% 58% 10.8 ~ 13.2V 12V 21.6 ~ 26.4V 24V 43.2 ~ 52.8V 48V 4.5 ~ 5.5V 5V 10.8 ~ 13.2V 12V 21.6 ~ 26.4V 24V 43.2 ~ 52.8V 48V 141mA 67mA 35mA 350mA 141mA 67mA 35mA 15mA 10mA 6mA 32mA 15mA 10mA 6mA SPECIFICATION RATED POWER 1W RIPPLE & NOISE (max.) Note.2 100mVp-p LINE REGULATION ±1.0% LOAD REGULATION ±2.0%(Typ.) SWITCHING FREQUENCY 50KHz min. VOLTAGE RANGE NORMAL VOLTAGE 4.5 ~ 5.5V 5V Full load 350mA No load 32mA INPUT CURRENT INPUT Note.3 ±1.0% VOLTAGE ACCURACY FILTER Capacitor type PROTECTION Fuse recommended OVERLOAD >110% rated output power Protection type : Hiccup mode, recovers automatically after fault condition is removed PROTECTION (Note. 4) All output equipped with short circuit SHORT CIRCUIT WORKING TEMP. Protection type : Hiccup mode, recovers automatically after fault condition is removed -25 ~ +71℃ (Refer to "Derating Curve") WORKING HUMIDITY 20% ~ 90% RH non-condensing ENVIRONMENT STORAGE TEMP., HUMIDITY TEMP. COEFFICIENT VIBRATION SAFETY STANDARDS WITHSTAND VOLTAGE SAFETY & ISOLATION RESISTANCE EMC ISOLATION CAPACITANCE EMC EMISSION EMC IMMUNITY MTBF OTHERS DIMENSION WEIGHT -25 ~ +105℃, 10 ~ 95% RH ±0.03% / ℃ (0 ~ 50℃) 10 ~ 500Hz, 2G 10min./1 cycle, period for 60min. each along X, Y, Z axes EAC TP TC 004 approved I/P-O/P:1KVDC I/P-O/P: 100M Ohms / 500VDC / 25℃/ 70% RH 80pF max. Compliance to EN55032 Class B, FCC part 15 Class B, EAC TP TC 020 Compliance to EN61000-4-2,3,4,5,6,8, light industry level, criteria A, EAC TP TC 020 700khrs min. MIL-HDBK-217F(25℃) 19.6*7.1*10.2mm or 0.77"*0.28"*0.40" inch (L*W*H) 2.3g Unit: mm (inch) 10.14 (0.40) 19.6 (0.77) 3.81 (0.15) 0.5 (0.02) FRONT VIEW 0.5 (0.02) 2.2 (0.09) 2.54 5.08 5.08 (0.10) (0.20) (0.20) 7.1 (0.28) 1 2 4 Derating Curve Pin Configuration Mechanical Specification 6 1.2 (0.05) NOTE ±3.0%(max.) Pin No. Output 1 +Vin 2 4 -Vin -Vout 6 +Vout 100 LOAD (%) OUTPUT 80 BOTTOM VIEW -25 0 25 50 60 71 100 Ta (℃) 1.All parameters are specified at normal input, rated load, 25℃ 70% RH ambient. 2.Ripple & noise are measured at 20MHz by using a 12" twisted pair terminated with a 0.1uf & 47uf capacitor. 3.Load regulation is measured from 10% to 100% rated load. 4.Please prevent the converter from operating in overload or short circuit condition for more than 30 seconds. File Name: SPR01-SPEC 2018-01-15
SPR01L-15 价格&库存
很抱歉,暂时无法提供与“SPR01L-15”相匹配的价格&库存,您可以联系我们找货
