LF13WBJ-20S
LF13WBJ-20S
    HRS(广濑)
LF13WBJ-20S 数据手册
Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. LF Series Shielded Small Waterproof Connector Sep. 2022 LF Series/Shielded Small Waterproof Connector Features 1. Small, Robust Design Straight 0.7-2 (43.1) ⌀7.3 Small, robust design with metal shell (42) Right Angle Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (33.6) Low Profile Right Angle (35.5) (27) * Illustrations are different from actual sizes. * The dimensions are different when it is mated with the rear mount type. Dimensions Example ( LF10 Plug Mated with Front Mount Receptacle) 2. Bayonet Lock Mating : Insert the plug, and then turn the locking collar clockwise, as indicated by the coupling direction marking. User- friendly lock with superior vibration resistance. ② ① Locking Collar Plug Coupling Direction Marking Un-mating : Turn the locking collar counter-clockwise then pull off the plug. ① ② Coupling Direction Marking Lock Design 3. Waterproof : IP67/ IP68* Compliant IP67/ IP68 waterproof performance when mated. * IP67 : Left at a water depth of 1 meters for 30 minutes in mated condition. IP68 : Left at a water depth of 2 meters for 14 days in mated condition. 2 LF Series/Shielded Small Waterproof Connector 4. Easy Shielding Termination Shield Cable The cable shield is easily connected to the connector shell by attaching the metal clamp to the cable sheath. 1 Braided shield is clamped with ground terminal. 2 Braided shield contacts plug housing via contact spring. Plug Receptacle Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3 Tip of the plug contacts receptacle shell via contact spring. Panel Shield Connection Phase Diagram 5. Easy Assembly Plug Shield Cable Shell Waterproof performance and shielding of the plug are attained just by tightening the ring. The plug design reduces component and assembly costs. Ground Terminal (Crimp Ring) ◆ Shielded Spring and ground terminal are in contact. Clamp Spring Gasket Cable Tightening Clamp Ring ◆ Clamped (Fixed) Cable Clamp ◆ Cable Clamp Sealed with Gasket 6. Wide Variety of Configurations ・2 types of cable assembly: solder and crimp ・Hybrid type with power and signal contacts in a single shell for space- saving ・Plug with easy to grip sleeve that prevents slipping for enhanced operability ・2 receptacle mounting options: front mount and rear mount 7. High Speed Transmission Supports Cat. 5e( 1Gbps) high speed Ethernet * Based on EtoE Standard Class D 3- Conn E3 * Characteristics depend on pin assignment, cable specifications and cable assembly conditions. Please check prior to use. * Please contact a Hirose representative for questions on the recommended pin assignment. 8. Suited for Long- Term Outdoor Use Sunshine weather meter test performed for 2, 000 hours. 3 LF Series/Shielded Small Waterproof Connector 9. Safety Standard Certified The 4 position variation meets TÜ V safety standards at a current of 10A. The 3 position and 4 position variations also meet UL safety standards. 10. RoHS2 Compliant Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Product Specifications Rated Current 3pos. : 5A 4pos. : 10A 6, 12, 20pos. : 2A Hybrid 6pos. : Power 2pos. 4A, Signal 4pos. 1A Hybrid 11pos. : Power 4pos. 10A, Signal 7pos. 2A Operating Temperature (Note 1) -25 to +85℃ Rated Voltage 3pos. : 125V AC / 175V DC 4pos. : 125V AC/DC 6, 12, 20pos. : 30V AC / 42V DC Hybrid 6pos. : Power 2pos. 60V AC/DC, Signal 4pos. 60V AC/DC Hybrid 11pos. : Power 4pos. 125V AC/DC, Signal 7pos. 30V AC / 42V DC Storage Temperature Range -10 to +60℃ Items Specifications Conditions 3, 6, 12, 20, Hybrid 6pos. : 15m Ω Max. 4pos. : 5m Ω Max. Hybrid 11pos. : Power 4pos. 5m Ω Max., Signal 7pos. 15m Ω Max. Measured at 1A DC 1000M Ω Min. 3, 4pos. : Measured at 500V DC 3, 6, 12, 20, Hybrid 6pos. : Measured at 100V DC Hybrid 11pos. : Power 4pos. : Measured at 500V DC, Signal7pos. : Measured at 100V DC No flashover and insulation breakdown 3, 4pos. : 1250V AC for 1 min. 3, 6, 12, 20, Hybrid 6pos. : 300V AC for 1 min. Hybrid 11pos. : Power 4pos. 1250V AC, Signal 7pos. : 300V AC for 1 min. 3, 6, 12, 20, Hybrid 6pos. : 30m Ω Max. 4pos. : 10m Ω Max. Hybrid 11pos. : Power 4pos. 10m Ω Max., Signal 7pos. 30m Ω Max. 1000 times Vibration Resistance No electrical interruption of 10μ s or more. No damage, cracks or parts dislocation. Frequency : 10 to 55 to 10Hz/cycle Half amplitude 0.75mm, 5 minutes/cycle 10 cycles each in 3 axis directions Shock Resistance No electrical interruption of 10μ s or more. No damage, cracks or parts dislocation. Acceleration : 490m/s2, duration : 11ms, 3 times each in 3 axis directions Humidity Resistance (Normal Condition) Insulation resistance : 10M Ω Min. (at high humidity condition) 100M Ω Min. (at dry condition) Temperature : 40℃ , relative humidity : 90 to 95%, left for 96 hours Temperature Cycle Insulation resistance : 100M Ω Min. No damage, cracks or parts dislocation. -55℃ for 30 minutes → Room temperature for 2 to 3 minutes → +85℃ for 30 minutes → Room temperature for 2 to 3 minutes, Repeated for 5 cycles. Water Resistance No water intrusion inside connector At a water depth of 1.8 meters for 48 hours in mated condition. Contact Resistance Insulation Resistance Withstand Voltage Mating Durability Note 1 : Includes temperature rise caused by current flow. Note 2 : Depending on the cable construction and specifications, the cable clamp force, rotational force, waterproof performance, etc. may differ. Please use after confirming in advance. 4 LF Series/Shielded Small Waterproof Connector Materials / Finish Component Material Finish / Remarks UL Zinc Alloy Nickel Plating - PPS Resin Brown UL94V-0 Insulator PPS Resin Black UL94V-0 Contact Copper Alloy Partial Gold Plating Over Nickel Underplating - Gasket, O-ring Chloroprene Rubber Black - Outer Shell Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ● Connector LF 07 W B P# - 6 S# - A (##) ❶ ❷ ❸  ❹ ❺ ❻ ❼ ❽ ❾ ❶ Series Name LF ❻ No. of Pos. ❷ Shell Size 07, 10, 13 ❼ Contact Gender ❸ Specialty W : Waterproof Type ❽ Difference in Contact Arrangement Added when contact arrangement differs from the standard type. A : Contact Arrangement Difference ❹ Lock Mechanism B : Bayonet Lock ❾ ❺ Other Specifications ❶ Shell Type ● Crimp P : Plug LP : Right Angle Plug R : Receptacle J : Jack (Changed specifications for products of the same category.) P : Male Contact S : Female Contact (Changed specifications for products of the same category.) to ❽ # two-digit character is added to indicate other specifications as needed. Contact HR10 - P C - 1 1 1 ❶ ❷ ❸  ❹ ❺ ❻ HR12 - S C - 1 1 1 ❶ ❷ ❸  ❹ ❺ ❻ ❶ Series Name HR10 HR12 ❹ Contact Shape 1 : Loose Piece Contact 2 : Reel Contact ❷ Contact Gender P : Male Contact S : Female Contact ❺ Design 1 : If the design of contacts of the same size differs, 1, 2, 3 etc. are added to distinguish them ❸ Contact Assembly C : Crimp ❻ Contact Area Plating 1 : Gold Plated Note : The LF Series uses the contacts from the existing HR10/HR12 Series. 5 LF Series/Shielded Small Waterproof Connector Straight Plug φC (Cable Outer dia.) Solder Type φA B Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (Example of product appearance.) Unit : mm Part No. HRS No. LF07WBP-3S(31) CL0136-0003-7-31 LF07WBP-3P(31) CL0136-0004-0-31 LF07WBP-6S(31) CL0136-0001-1-31 LF07WBP-6P(31) CL0136-0002-4-31 LF07WBP-6S-A(31) CL0136-0029-0-31 LF07WBP-6P-A(31) CL0136-0016-0-31 LF10WBP-4S(31) CL0136-0005-2-31 LF10WBP-4P(31) CL0136-0006-5-31 LF10WBP-12S(31) CL0136-0007-8-31 LF10WBP-12P(31) CL0136-0008-0-31 LF13WBP-11S CL0136-0011-5-00 LF13WBP-11P CL0136-0012-8-00 LF13WBP-20S CL0136-0009-3-00 LF13WBP-20P CL0136-0010-2-00 No. of Pos. Shell Size φA B φC Weight 12.3 35.8 5.0 11g 12.3 35.8 5.0 11g Purchase Unit 3 LF07 6 Hybrid 6pos. (Note 1) LF07-A 4 LF10 14.8 41.8 7.3 12 17g 16g Hybrid 11pos. (Note 2) LF13 17.9 20 Note 1 : Power 2pos.+ Signal 4pos. Note 2 : Power 4pos.+ Signal 7pos. 6 51.9 8.7 29g 50pcs per tray LF Series/Shielded Small Waterproof Connector φC (Cable Outer dia.) Easy Lock Solder Type φA B Unit : mm Part No. HRS No. LF07WBPD-6S(31) CL0136-0020-6-31 LF10WBPD-4S(31) CL0136-0014-3-31 LF10WBPD-4P(31) CL0136-0017-1-31 LF10WBPD-12S(31) CL0136-0015-6-31 LF10WBPD-12P(31) CL0136-0018-4-31 Shell Size No. of Pos. φA B φC Weight LF07 6 14.3 35.8 5.0 12g 16.8 41.8 7.3 19g 4 LF10 Purchase Unit 50pcs per tray 12 φC (Cable Outer dia.) Crimp Type B φA Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (Example of product appearance.) (Example of product appearance.) Unit : mm Part No. HRS No. LF10WBP-12SC CL0136-0041-0-00 LF13WBP-20PC CL0136-0040-0-00 LF13WBP-20SC CL0136-0044-0-00 Shell Size No. of Pos. φA B φC Weight LF10 12 14.8 41.8 7.3 17g LF13 20 17.9 51.9 8.7 27g 7 Purchase Unit 50pcs per tray LF Series/Shielded Small Waterproof Connector Right Angle Plug φD(Cable Outer dia.) Solder Type Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. B C φA (Example of product appearance.) Unit : mm Part No. HRS No. LF07WBLP-6PA(31) CL0136-0022-1-31 LF10WBLP-12SA(31) CL0136-0013-0-31 LF10WBLP-12PA(31) CL0136-0025-0-31 LF13WBLP-11PA CL0136-0023-4-00 LF13WBLP-20PA CL0136-0031-0-00 Shell Size No. of Pos. φA B C φD Weight LF07 6 12.3 28.2 34.5 5.0 20g LF10 12 14.8 32.3 42.0 7.3 31g LF13 Hybrid 11pos. (Note) 17.9 33.6 53.4 8.7 20 Note : Power 4pos. + Signal 7pos. 8 Purchase Unit 20pcs per bag 49g 1pc per bag 50g 10psc per bag LF Series/Shielded Small Waterproof Connector φD(Cable Outer dia.) Low Profile Solder Type B C Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. φA (Example of product appearance.) Unit : mm Part No. LF10WBLPA-12P HRS No. CL0136-0039-0-00 Shell Size No. of Pos. φA B C φD Weight Purchase Unit LF10 12 14.8 25.1 35.5 7.3 34g 50pcs per tray 9 LF Series/Shielded Small Waterproof Connector Receptacle (Front Mount) Solder Type C (Connector Total Length) φB φA D E F(HEX) Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (Example of product appearance.) Unit : mm Part No. HRS No. LF07WBR-3P CL0136-1003-2-00 LF07WBR-3S CL0136-1004-5-00 LF07WBR-6P CL0136-1001-7-00 LF07WBR-6S CL0136-1002-0-00 LF10WBR-4P CL0136-1005-8-00 LF10WBR-4S CL0136-1006-0-00 LF10WBR-12P CL0136-1007-3-00 LF10WBR-12S CL0136-1008-6-00 LF13WBR-11P CL0136-1011-0-00 LF13WBR-11S CL0136-1012-3-00 LF13WBR-20P CL0136-1009-9-00 LF13WBR-20S CL0136-1010-8-00 Shell Size No. of Pos. φA φB 3 LF07 13.0 6 E F 7.65 M9 × 0.75 11.0 Weight Purchase Unit 15.05 4g 15.25 4 60pcs per tray 19.05 12.8 15.3 17.25 Hybrid 11pos. (Note) 19.05 15.9 20 18.3 10 M11× 0.75 13.0 5g 6g 9g 7.75 17.25 Note : Power 4pos. + Signal 7pos. 6g 7.75 12 LF13 D 16.55 10.3 LF10 C M14× 0.75 17.0 10g 9g 10g 50pcs per tray LF Series/Shielded Small Waterproof Connector Through Hole Type C (Connector Total Length) φB φA D E F(HEX) Unit : mm Part No. HRS No. LF13WBR-20SD CL0136-1017-7-00 No. of Shell Size Pos. LF13 20 φA φB C D E F 15.9 18.3 17.5 7.75 M14× 0.75 17.0 Weight Purchase Unit 9g 50pcs per tray Crimp Type C (Connector Total Length) D φB φA Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (Example of product appearance.) F (HEX) E (Example of product appearance.) Unit : mm Part No. HRS No. LF10WBR-12PC CL0136-0042-0-00 No. of Shell Size Pos. LF10 12 φA φB C D E F 12.8 15.3 14.25 7.75 M11× 0.75 13.0 11 Weight Purchase Unit 6g 50pcs per tray LF Series/Shielded Small Waterproof Connector Receptacle (Rear Mount) Solder Type C φA φB D(HEX) E Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (Example of product appearance.) Unit : mm HRS No. Shell Size No. of Pos. φA φB C D E LF07WBRB-6S CL0136-0054-0-00 LF07 6 10.3 15 17.25 13 M11× 0.75 LF10WBRB-4P CL0136-1118-4-00 LF10WBRB-4S CL0136-1123-0-00 LF10WBRB-12P CL0136-1013-6-00 LF10WBRB-12S CL0136-1014-9-00 LF13WBRB-11P CL0136-1024-0-00 LF13WBRB-11S CL0136-1019-2-00 LF13WBRB-20P CL0136-1023-0-00 LF13WBRB-20S CL0136-1018-0-00 Part No. 4 LF10 18.3 12 17 M14× 0.75 17.25 11g 15g 15.9 20 Note : Power 4pos. + Signal 7pos. 12 21.5 19.25 50pcs per tray 10g Hybrid 11pos. (Note) LF13 8g 10g 19.05 12.8 Weight Purchase Unit 20 M17× 0.75 16g 10pcs per bag 20pcs per tray LF Series/Shielded Small Waterproof Connector Through Hole Type C φA φB D(HEX) E Unit : mm Part No. HRS No. LF07WBRB-3SD(31) CL0136-1025-0-31 LF07WBRB-6SD(31) CL0136-1026-0-31 LF07WBRB-6PD-A(31) CL0136-1021-0-31 LF07WBRB-6SD-A(31) CL0136-1022-0-31 LF10WBRB-12PD CL0136-1015-1-00 LF10WBRB-12SD CL0136-1016-4-00 LF13WBRB-20SD CL0136-1027-0-00 Shell Size No. of Pos. φA φB C D 3 LF07 E Weight Purchase Unit 13.0 6 10.3 15.0 20.0 M11 × 0.5 8g LF07-A Hybrid 6pos. (Note) LF10 12 12.8 18.3 17.5 17.0 M14× 0.75 10g LF13 20 15.9 21.5 20.0 20.0 M17× 0.75 16g - 50pcs per tray Note : Power 2pos. + Signal 4pos. Crimp Type φA C (Connector Total Length) φB Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (Example of product appearance.) D (HEX) E (Example of product appearance.) Unit : mm Part No. HRS No. LF13WBRB-20SC CL0136-1033-0-00 LF13WBRB-20PC CL0136-1124-0-00 No. of Shell Size Pos. LF13 20 φA φB C D E 15.9 21.5 16.5 20.0 M17 × 0.75 13 Weight 15g 14g Purchase Unit 20pcs per bag LF Series/Shielded Small Waterproof Connector Jack φD(Cable Outer dia.) Solder Type Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. φB φA C (Example of product appearance.) Unit : mm Part No. HRS No. LF07WBJ-3P CL0136-2003-8-00 LF07WBJ-3S CL0136-2004-0-00 LF07WBJ-6P CL0136-2001-2-00 LF07WBJ-6S CL0136-2002-5-00 LF10WBJ-4P CL0136-2005-3-00 LF10WBJ-4S CL0136-2006-6-00 LF10WBJ-12P CL0136-2007-9-00 LF10WBJ-12S CL0136-2008-1-00 LF13WBJ-11P CL0136-2011-6-00 LF13WBJ-11S CL0136-2012-9-00 LF13WBJ-20P CL0136-2009-4-00 LF13WBJ-20S CL0136-2010-3-00 Shell Size No. of Pos. φA φB C φD Weight 10.3 11.5 36.3 5.0 11g 12.8 13.8 42.4 7.3 16g Purchase Unit 3 LF07 6 4 LF10 12 29g Hybrid 11pos. (Note) LF13 15.9 20 Note : Power 4pos. + Signal 7pos. 14 16.9 52.4 8.7 30g 29g 30g 50pcs per tray LF Series/Shielded Small Waterproof Connector Crimp Contact Male Contact 1 A 1.15 1.2 A Type Part No. HRS No. Loose Contact HR10-PC-111 CL0110-0515-6-00 Reel Contact HR10-PC-211 CL0110-0516-9-00 Applicable Connector LF13WBP-20PC LF10WBR-12PC LF13WBRB-20PC Applicable Cable 26-30 AWG Outer Dia. φ 1 Max. Purchase Unit 100pcs per bag 10,000pcs per reel Female Contact A 10 Type Part No. HRS No. Loose Contact HR12-SC-111 CL0112-0410-0-00 Reel Contact HR12-SC-211 CL0112-0407-6-00 Applicable Connector LF10WBP-12SC LF13WBP-20SC LF13WBRB-20SC Note : The LF Series uses the contacts from the existing HR10/HR12 Series. 15 1.15 1.2 1 Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 10 A Applicable Cable 26-30 AWG Outer Dia. φ 1 Max. Purchase Unit 100pcs per bag 10,000pcs per reel LF Series/Shielded Small Waterproof Connector Cap Metal Receptacle Cap φ 3. 3 100 C B Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. φ6 φA (Example of product appearance.) Unit : mm Type Part No. LF07WBR-C LF10WBR-C HRS No. Applicable Connector φA CL0136-3008-7-00 LF07WBR-3P LF07WBR-3S LF07WBR-6P LF07WBR-6S LF07WBRB-6S LF07WBRB-3SD(31) LF07WBRB-6SD(31) LF07WBRB-6PD-A(31) LF07WBRB-6SD-A(31) 12.3 CL0136-3001-8-00 LF10WBR-4P LF10WBR-4S LF10WBR-12P LF10WBR-12S LF10WBR-12PC LF10WBRB-4P LF10WBRB-4S LF10WBRB-12P LF10WBRB-12S LF10WBRB-12PD LF10WBRB-12SD Without Chain LF13WBR-C With Chain LF13WBR-C1 CL0136-3003-3-00 CL0136-3006-1-00 LF13WBR-11P LF13WBR-11S LF13WBR-20P LF13WBR-20S LF13WBR-20SD LF13WBRB-11P LF13WBRB-11S LF13WBRB-20P LF13WBRB-20S LF13WBRB-20SD LF13WBRB-20PC LF13WBRB-20SC LF13WBR-11P LF13WBR-11S LF13WBR-20P LF13WBR-20S LF13WBR-20SD LF13WBRB-11P LF13WBRB-11S LF13WBRB-20P LF13WBRB-20S LF13WBRB-20SD LF13WBRB-20PC LF13WBRB-20SC 16 B C Weight Purchase Unit 4g 8.8 14.8 5g - 20pcs per bag 17.9 8.75 17.9 - 7g 14.5 12g LF Series/Shielded Small Waterproof Connector Rubber Receptacle Cap C φD Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. B φE φA (Example of product appearance.) Unit : mm Part No. LF07WBR-C2 LF10WBR-C2 LF13WBR-C2 HRS No. φA B C φD φE Weight CL0136-3005-9-00 LF07WBR-3P LF07WBR-3S LF07WBR-6P LF07WBR-6S LF07WBRB-6S LF07WBRB-3SD(31) LF07WBRB-6SD(31) LF07WBRB-6PD-A(31) LF07WBRB-6SD-A(31) 13.0 6.55 38.0 10.0 - 1g CL0136-3007-4-00 LF10WBR-4P LF10WBR-4S LF10WBR-12P LF10WBR-12S LF10WBR-12PC LF10WBRB-4P LF10WBRB-4S LF10WBRB-12P LF10WBRB-12S LF10WBRB-12PD LF10WBRB-12SD 15.5 6.85 38.0 15.0 12.5 CL0136-3011-0-00 Applicable Connector Purchase Unit 20pcs per bag 2g LF13WBR-11P LF13WBR-11S LF13WBR-20P LF13WBR-20S LF13WBR-20SD LF13WBRB-11P LF13WBRB-11S LF13WBRB-20P LF13WBRB-20S LF13WBRB-20SD LF13WBRB-20PC LF13WBRB-20SC 18.6 17 6.55 40.0 15.5 - LF Series/Shielded Small Waterproof Connector Applicable Tools Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Termination Tools (Example of product appearance.) Part No. HRS No. Applicable Connector LF07BP-T01 CL0150-0232-0-00 LF07WBP-## LF07BJ-T01 CL0150-0233-3-00 LF07WBJ-## LF10BP-T01 CL0150-0235-9-00 LF10WBP-## LF10BJ-T01 CL0150-0236-1-00 LF10WBJ-## LF13BP-T01 CL0150-0237-4-00 LF13WBP-## LF13BJ-T01 CL0150-0238-7-00 LF13WBJ-## Purchase Unit 1pc per bag Note 1 : The applicable alphanumeric is added in place of ## based on the pin count. (Example: 6S) Note 2 : Use the termination tool as a base for termination or assembly. Cable Crimp Tool Item Part No. Manual Crimp Tool HRS No. LF Series Applicable Cable Dia. HR10A-TC-02 CL0150-0041-2-00 φ 5mm (Note) LF-TC-01 CL0150-0234-6-00 φ 7.3mm・φ 8.7mm Note : Please note that while the applicable cable diameters for the HR10A-TC-02 crimp tool are φ 5mm and φ 7mm, the applicable cable diameter of the LF Series is φ 5mm only. Crimp Contact Tool Item Automatic Manual Type Part No. HRS No. Applicable Contact Applicable Cable Automatic Crimp Press CM-105C CL0901-0001-0-00 - - Applicator AP105-HR12-1 CL0901-2015-9-00 HR10-PC-211 HR12-SC-211 26-30 AWG Outer Dia. φ 1 Max. Manual Crimp Tool HT802/HR12-SC-1 CL0150-0400-3-00 HR10-PC-111 HR12-SC-111 26-30 AWG Outer Dia. φ 1 Max. RP6-SC-TP CL0150-0039-0-00 HR10-PC-211 HR10-PC-111 - HR12-SC-TP CL0150-0050-3-00 HR12-SC-211 HR12-SC-111 - Contact Extraction Tool 18 LF Series/Shielded Small Waterproof Connector Panel Cut-Out Dimensions 5 .0 +0 0 A Mating Guide Position B +0.05 0 Unit : mm Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Type Front Mount Rear Mount Shell Size Applicable Connector φA B Panel Thickness LF07 LF07WBR-## 9.05 8.1 LF10 LF10WBR-## 11.05 10.2 LF13 LF13WBR-## 14.05 13.1 LF07 LF07WBRB-## 11.05 10.5 0.7 to 4.0 LF10 LF10WBRB-## 14.05 13.1 0.7 to 2.0 LF13 LF13WBRB-## 17.05 16.1 0.7 to 4.8 Note : The applicable alphanumeric is added in place of ## based on the pin count. (Example: 6S) 19 0.7 to 2.0 LF Series/Shielded Small Waterproof Connector Contact Arrangement and Main Specifications LF07 Shell Size Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Contact Arrangement 3 LF07ーA 1 6 1 5 2 3 2 4 B 3 4 A 1 2 No. of Pos. Withstanding Voltage 3 6 Power/Signal Hybrid 6pos. 1250V AC 300V AC 300V AC Current Rating 5A 2A Power 2pos. Signal 4pos. Insulation Resistance Contact Resistance Solder Pot Inner Diameter 15MΩ φ1.15 Power 2pos. Signal 4pos. φ0.8 φ1.15 φ0.8 LF10 LF13 1 9 1 8 3 2 7 12 11 3 6 5 4 10 B 2 4 4 12 Withstanding Voltage 1250V AC 300V AC Current Rating 10A 2A No. of Pos. 1A 1000MΩ Shell Size Contact Arrangement 4A Insulation Resistance 1 C 2 A D 1 2 3 4 5 6 7 6 4 8 5 9 20 300V AC Power 4pos. Signal 7pos. 2A 20 300V AC 2A 1000MΩ Contact Resistance 5mΩ 15mΩ Solder Pot Inner Diameter φ1.7 φ0.8 Power 4pos. Signal 7pos. 5mΩ 15mΩ Power 4pos. Signal 7pos. φ1.7 φ0.8 Note 1 : The contact arrangements are from the view of the female contact connector mating face. Note 2 : The ▼ symbol in the above diagrams indicates the mating guide position. Note 3 : The withstanding voltage values in the above tables are tested values. 20 10 16 17 18 19 Power 4pos. Signal 7pos. 10A 7 11 12 13 14 15 Power/Signal Hybrid 11pos. 1250V AC 3 15mΩ φ0.8 LF Series/Shielded Small Waterproof Connector Cable Specifications (Reference) No. of Pos. 3pos. 4pos. 6pos. Material Size (mm) Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Insulator Tin Plated Soft Copper Wire φ 0.16 φ 0.16 φ 0.16 φ 0.26 φ 0.16 20 / φ 0.18 20 / φ 0.26 7 / φ 0.16 7 / φ 0.16 7 / φ 0.16 26 / φ 0.26 7 / φ 0.16 Size (AWG) 20 16 26 26 26 16 26 Sectional Area (mm2) 0.5 1.25 0.14 0.14 0.14 1.25 0.14 Diameter (mm) φ 0.98 φ 1.5 φ 0.48 φ 0.48 φ 0.48 φ 1.5 φ 0.48 Diameter (mm) φ 1.5 (Standard) φ 2.1 φ 0.88 (Standard) φ 0.9 φ 0.9 φ 2.1 φ 0.95 0.26 0.3 0.2 0.21 0.21 0.3 0.24 Material Jacket 11pos. φ 0.26 Thickness (mm) Shield 20pos. φ 0.18 Construction Conductor 12pos. Density (%) Tin Plated Soft Copper Wire 85% 80% Min. 85% 80% Min. 80% Min. 80% Min. Diameter (mm) φ 3.6 φ 5.5 φ 3.4 φ 4.2 φ 5.1 φ 6.7 Diameter (mm) φ 5 ± 0.2 φ 7.3 ± 0.2 φ 5 ± 0.2 φ 7.3 ± 0.2 φ 8.7 ± 0.2 φ 8.7 ± 0.2 Note 1 : The cable specifications in the above table satisfy UL requirements. Note 2 : Use a cable without empty space inside. If there is empty space in the cable, clamping and waterproof performance may not be maintained. Connector Usage Precautions 1. When assembling the connector and installing to equipment, refer to the separate procedure manual and drawings. Please also make sure to use the specified tightening torque. If the torque is too low or high, it may result in   loosening or product damage. In addition, apply Loctite 263 which is manufactured by Henkel Japan Ltd. to male screw part in order to prevent looseness. ( Contact a Hirose sales representative for the procedure manual. ) 2. Once mated, pull lightly on the cable to confirm the mated status and that the connector does not come off. 3. Excessive external force applied to the connector may cause deformation or damage, resulting in poor conduction or   waterproofing performance issues. Please avoid forceful insertion/ removal, impact and pulling, routing or twisting of   the cables. Also, when routing inside equipment, make sure to provide sufficient slack to the cable so that a load   is not applied directly to the connector such as through excessive cable bending or tension on the cable. 4. Damage of the waterproof seal or waterproof surface may result in issues with the waterproof performance, so please   refrain from using a damaged product. While Taking into Consideration Specifications mentioned in this catalog are reference values. When considering to order or use this product, please confirm the Drawing and Product Specifications sheets. Use an appropriate cable when using the connector in combination with cables. If considering usage of a non- specified cable, please contact your sales representative. If assembly process is done by jigs & tools which are not identified by Hirose, assurance will not be given. If considering usage for below mentioned applications, please contact your sales representative. In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given. 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN        https://www.hirose.com ※ The contents of this catalog are current as of date of 9/ 2022. Contents are subject to change without notice for the purpose of improvements. 21
LF13WBJ-20S 价格&库存
很抱歉,暂时无法提供与“LF13WBJ-20S”相匹配的价格&库存,您可以联系我们找货
