Split Core Current Transformer
CR3100 Series
The CR3100 Series Split Core Current Transformer is
designed to provide a low cost method to monitoring electrical current. A unique hinge and locking snap allows attachment without interrupting the current-carrying wire. High
secondary turn will develop signals up to 10.0 VAC across a
burden resistor.
CR3110-3000
Current Transformers
CR3109-1500
F
Applications
Portable Instruments
Sub-Metering
Monitor Motor Loads
Features
Small Size
Low Cost
High Secondary Turns
Secure Locking Hinge
CR3111-3000
CR3113-2000
Specifications
Maximum Continuous Primary Current
Insulation Voltage
Storage Temp.
Operating Temp.
PART NUMBERS
CR3109
CR3110
CR3111
CR3113
1500
3000
3000
2000
30 AMP
75 AMP
100 AMP
150 AMP
4 X Ir
3500 Vac/1min
-45°C thru +85°C
-40°C thru +65 °C
Regulatory Agencies
SPLIT CORE CURRENT TRANSFORMERS
Part Number
CR3109-1500
CR3110-3000
CR3111-3000
CR3113-2000
Imax
30
75
100
150
Vmax RMS
5
15
19
16
DCR Ω
187
440
390
58
Te (typ.)
1510
3100
3150
2125
Frequency
20 - 1 KHz
20 - 1 KHz
20 - 1 KHz
20 - 1 KHz
CR3110-3000 ONLY
Ir = Maximum Input Current to be linearly sensed
Vmax = Maximum Voltage (Saturation) CT will develop
Te = Effective turns ratio including losses (All Specifications tested at 60 Hz)
I
DCR
R
OUTLINE DRAWING
A
B
D
E
VL = Vmax
C
I x DCR
Te
V=
V
IxR
Te
For best linearity, choose R such that V < 0.8 VL
F
VL
Part Number
CR3109-1500
CR3110-3000
CR3111-3000
CR3113-2000
The Professional
Energy Monitoring
Company
M N TI
ISO 9001:2008 Quality Management System
A
B
C
D
E
F
0.76
(19.2)
1.00
(25.5)
1.24
(31.4)
2.68
(68.7)
0.19
(4.90)
0.40
(10.2)
0.62
(15.7)
0.98
(24.9)
1.24
(31.5)
1.57
(40.0)
1.77
(45.0)
2.56
(65.0)
6.10
(1.55)
5.91
(150)
6.10
(155)
118
(3000)
0.82
(20.8)
1.04
(26.5)
1.22
(31.0)
0.72
(18.4)
0.20
(5.08)
0.24
(6.10)
0.20
(5.08)
0.20
(5.08)
I
3500 Scarlet Oak Blvd. St. Louis MO USA 63122 V: 636-343-8518 F: 636-343-5119
Web: http://www.crmagnetics.com
102
E-mail: sales@crmagnetics.com
很抱歉,暂时无法提供与“CR3111-3000”相匹配的价格&库存,您可以联系我们找货
