TD-DIODE-1000
TD-DIODE-1000
    TELCODIUM
    TELCODIUMIDEALDIODEBRIDGEHEM
TD-DIODE-1000 数据手册
P O W E R S U P P LY T E C H N O L O G Y Ideal Diode MODULE TD-DIODE-1000 Technical Specification Up to 1000W AC-DC Full Bridge Rectifier FEATURES • • • • • Universal AC Input 85-265Vrms Low loss mosfet rectifier Low profile, small size Vertical or horizontal mount Conduction cooling PRODUCT OVERVIEW The Telcodium diode module provides a full wave rectified DC voltage output from a wide range of AC input source from 85Vrm to 265Vrms, with a very low lost compared to traditional diode bridge rectifiers. The ideal diode module uses a patented technology to take the AC source and fully rectifies the output. This module draws 10 times less power than a traditional diode bridge rectifier and doesn’t need a heat sink or fan. APPLICATIONS • • • • Power supply design front end Any DC full wave rectifier requirement up to 1000W, 265Vac rms High efficiency equipment design Convection cooling equipment ! Preliminary and subject to change without notice www.telcodium.com ©2017 TELCODIUM INC. P O W E R S U P P LY T E C H N O L O G Y Figure 1. SPECIFICATIONS PARAMETERS MIN TYP MAX UNITS NOTES -40.00 -45.00 - 100.00 125.00 C C 20.00 10.00 - 95.00 95.00 % % RH RH 85.00 45.00 11.00 10.00 12.00 - 265.00 65.00 1000.00 12.00 17.00 20.00 Vrms Hz W A Vdc mA Vin>85Vrms Vin=85Vrms - 10.00 - 10^6 HRS Absolute maximum Rating Operating temperature Storage temperature Humidity (non condensing) Operating Non-Operating Input characteristic (L to N) Operating input voltage AC input continuous Operating input frequency Maximum input power Maximum input current Aux input voltage Aux input current Reliability Characteristics Calculated MTBF (MIL-217) MIL-HDBK-217F Standards Compliance UL 60950-1/R2011-12 CAN/CSA-C22.2 No. 60950-1/A1:2011 EN60950-1/A12:2011 CE marking Tb=70C Mechanical Size (WxHxL) Weight Table 1 Preliminary and subject to change without notice www.telcodium.com ©2017 TELCODIUM INC. 2 P O W E R S U P P LY T E C H N O L O G Y OUTLINE DRAWING Figure 2. Top View Isometric View ✓ See design guide PCB layout for proper clearance and trace width routing ✓ Connector TE 640385-5 , 0.156" (3.96mm) Preliminary and subject to change without notice www.telcodium.com ©2017 TELCODIUM INC. 3 P O W E R S U P P LY T E C H N O L O G Y ✓ See design guide for connection and AC input EMI FILTER design Symbol Top View Pinout Figure 3. ELECTRICAL CONNECTIONS Pinout description • • • • • Pin1: DC rectified output full wave rectified Pin2: AC line input Pin3: AC Neutral input Pin4: Ground none-isolated section Pin5: Auxiliary 12Vdc power source (20 mA max), see design guide ✓ See design guide for connections and AC input EMI FILTER design Telcodium logos are trademarks and service marks of Telcodium Inc. ©2017 TELCODIUM INC. 4 P O W E R S U P P LY T E C H N O L O G Y RoHS COMPLIANCE The EU led RoHS (Restriction of Hazardous Substances) Directive bans the use of Lead, Cadmium, Hexavalent Chromium, Mercury, Polybrominated Biphenyls (PBB), and Polybrominated Diphenyl Ether (PBDE) in Electrical and Electronic Equipment. Telcodium product is 6/6 RoHS compliant. For more information please refer to the Telcodium website RoHS addendum. Preliminary and subject to change without notice www.telcodium.com ©2017 TELCODIUM INC. 5 P O W E R S U P P LY T E C H N O L O G Y HEADQUARTERS TELCODIUM INC. 91 De la Barre, Boucherville, Quebec Canada J4B 2X6 Telephone: 1 450-274-6170 info@telcodium.com www.telcodium.com High-Efficiency Power Modules AC Power Supplies DC Power Supplies Telcodium logos are trademarks and service marks of Telcodium Inc. ©2017 TELCODIUM INC. 6
TD-DIODE-1000 价格&库存
很抱歉,暂时无法提供与“TD-DIODE-1000”相匹配的价格&库存,您可以联系我们找货
