TD-CPU-192
TD-CPU-192
    TELCODIUM
    TELCODIUMCPUMODULEFORMONITOR
TD-CPU-192 数据手册
P O W E R S U P P LY T E C H N O L O G Y CPU MODULE TD-CPU-192 Technical Specifications Universal controller for Telcodium High Efficiency Modules FEATURES • Low profile, small size • Vertical or horizontal mount PRODUCT OVERVIEW The Telcodium CPU module integrates the software required to manage all the functions of a all Telcodium High Efficiency Modules. Both input and output current and voltage, are monitor by the CPU, the led, sensor and fan are also monitor by the CPU and this information are available with the PMBUS interface to the optional redundant feed control (patented technology). APPLICATIONS • • • • • Power supply design using HEM modules from Telcodium High efficiency equipment design Convection cooling equipment High end power supply with PMBUS interface Power Supply with monitoring and Datalogging ! Preliminary and subject to change without notice www.telcodium.com ©2017 TELCODIUM INC. P O W E R S U P P LY T E C H N O L O G Y SPECIFICATIONS PARAMETERS MIN TYP MAX UNITS NOTES 3.1 -40 -45 3.3 - 3.6 70 125 Vdc C C VCC_3V3_CPU 20 10 - 95 95 % % RH RH 3.1 - 3.3 3.6 tbd Vdc A VCC_3V3_CPU Vdc Vdc A A Vdc Vdc Vdc Vdc Vdc VCC_12V VCC_5V_EARLY INPUT_CURRENT 12V_CURRENT Isolated voltage input sense positive Isolated voltage input sense negative Power good internal feature (TDBuck)** TTL output power good signal Fan Tach input signal Absolute maximum rating Input voltage (DC) Continuous Operating temperature Storage temperature Humidity (non condensing) Operating Non-Operating Input characteristic Operating input voltage DC power input voltage DC Input current Input pin Vout sense Vcc early Input current sense Output current sense Sense Feed 1P,2P Sense Feed 1N,2N PGOOD1 ,2 APWRG TACH_IN 3.1 0 3.3 3.5 3.3 Output pin PMBUS1_CTRL,PMBUS2_CTRL LEDA1,A2,A3,A4 ENA#12V ENA_LLC SW_FEED1 APWR_ON PWM_OUT OUT_SUPPLY 1,2 - 3.3 0 0 0 3.3 PMBUS internal control (TDBuck**) 3.3V led output control Enable (active low) auxiliary power (-12V) Enable (active low) LLC and PFC module TD redundant feed module (***) Fan speed control TTL 0-5.0V logic level static output COM PORT I2C_SCL I2C_SDA I2C_SCL_5VA I2C_SDA_5VA - Preliminary and subject to change without notice Internal I2C clock , 3V3 Internal I2C Data , 3V3 External I2C clock , 5.0V protected * External I2C Data , 5.0V protected * www.telcodium.com ©2017 TELCODIUM INC. 2 P O W E R S U P P LY T E C H N O L O G Y DEBUG PORT ADEBUG_TXD0 ADEBUG_RXD0 - - - Vdc Vdc Digital interface 115200 Baud Digital interface 115200 Baud OTHER *not high voltage isolated, ** To be use with TDBuck module , *** To be use with TBRedundancy Table 1 OUTLINE DRAWING Figure 1. Top View Isometric View ✓ See design guide PCB layout for proper clearance and trace width routing ✓ Connector, 0.1" (2.54mm) dual row Preliminary and subject to change without notice www.telcodium.com ©2017 TELCODIUM INC. 3 P O W E R S U P P LY T E C H N O L O G Y Top View Pinout Symbol Figure 2. ELECTRICAL CONNECTIONS Pinout description • • • • • • • • • • • • • Pin1: VCC_12V, input Pin3: VCC_5V_EARLY, input Pin2,4 : Internal I2C, SCL, SDA interface 3.3V Pin6,8: External I2C, SCL, SDA interface 5.0V not isolated with I/O protection ESD Pin7,9: Sense Feed1P, 1N, high precision differential voltage input sense Pin11,13: Sense Feed2P, 2N, high precision differential voltage input sense Pin10: 12V output current sense Pin12: Main input (AC) isolated with external device, current sense Pin15,17: PMBUS1, 2 Control pin used with TDBuck module Pin14: Enable -12V, external I/O used for standard ATX -12V (See TDCPU manual) Pin16: ENA_LCC, use to enable both PFC and LLC HEM Module Pin17,19: PGOOD1, 2, power good input from TDBuck module Pin18: SW_FEED1, use with TDRedundancy module option to switch active feed Preliminary and subject to change without notice • Pin21-27: Led output 3.3V, bicolor led control • Pin20: APWRG, input from ATX compliant device for power status • Pin22: APWR_ON, output to activate power ATX • Pin24: PMW_OUT, Fan speed control output • Pin26: TACH_IN, Fan speed monitoring • Pin28,30: TTL 5.0V static output signal • Pin29,34,36: Module GND • Pin31: Module power input 3.3V • Pin32: Spare1, configurable I/O , 3.3V pin • Pin33: ADEBUG_TXD0, RS232, 3.3V, N8,1, 115200 Baud • Pin35: ADEBUG_RXD0, RS232, 3.3V, N8,1, 115200 Baud ✓ See CPU document for complete I/O and function description www.telcodium.com ©2017 TELCODIUM INC. 4 P O W E R S U P P LY T E C H N O L O G Y RoHS COMPLIANCE The EU led RoHS (Restriction of Hazardous Substances) Directive bans the use of Lead, Cadmium, Hexavalent Chromium, Mercury, Polybrominated Biphenyls (PBB), and Polybrominated Diphenyl Ether (PBDE) in Electrical and Electronic Equipment. Telcodium product is 6/6 RoHS compliant. For more information please refer to the Telcodium website RoHS addendum. Preliminary and subject to change without notice www.telcodium.com ©2017 TELCODIUM INC. 5 P O W E R S U P P LY T E C H N O L O G Y HEADQUARTERS TELCODIUM INC. 91 De la Barre, Boucherville, Quebec Canada J4B 2X6 Telephone: 1 450-274-6170 info@telcodium.com www.telcodium.com High-Efficiency Power Modules AC Power Supplies DC Power Supplies Telcodium logos are trademarks and service marks of Telcodium Inc. ©2017 TELCODIUM INC. 6
TD-CPU-192 价格&库存
很抱歉,暂时无法提供与“TD-CPU-192”相匹配的价格&库存,您可以联系我们找货
