USB 2.0 A to B Cable (M/M), 3 ft. (0.91 m)
Highlights
Includes superior foil shielding
for reliable, error-free data
communications
Features gold plated copper
contacts for superior
conductivity
Supports faster data transfer
rate (1.5 to 480 Mbps) for low
speed and high speed devices
including multimedia
applications
Molded connectors and integral
strain relief for extra durability
and long life
MODEL NUMBER: U021-003
System Requirements
Description
Tripp Lite's 3-ft. (0.91 m) USB2.0 A/B device cable has been tested meets or exceed the USB2.0
performance criteria. Connects a USB device to a USB port on a computer or hub. Backward compatible
— can be used with older USB1.1 applications as well. All Tripp Lite USB 2.0 cabling include superior foil
shielding for reliable, error-free data communications. The significantly faster data transfer rates of USB
2.0 (up to 480 Mbps) make them perfect for multimedia applications. Features gold plated copper contacts
for superior conductivity. The cable is manufactured with molded connectors and integral strain relief for
extra durability and long life.
Features
USB 2.0 Tested
Supports faster data transfer rate (1.5 to 480 Mbps) for low speed and high speed devices including
Premium double-shielded cables with tinned copper braid and aluminum Mylar foil
Gold plated copper contacts for superior conductivity
Molded connectors and integral strain relief for extra durability and long life
Specifications
OVERVIEW
UPC Code
037332119421
Technology
USB 2.0 (High Speed)
USB Cable Type
Passive
PHYSICAL
Cable Jacket Color
Gray
Cable Length (ft.)
3
1/2
Any USB device requiring a
USB cable
USB 2.0 performance only when
used with USB 2.0 device and
USB 2.0 controller
Cable Length (m)
0.91
Shipping Dimensions (hwd / in.)
9.00 x 7.00 x 0.09
Shipping Dimensions (hwd / cm)
22.86 x 17.78 x 0.24
Shipping Weight (lbs.)
0.09
Shipping Weight (kg)
0.04
ENVIRONMENTAL
Operating Temperature Range
14 to 122 F (-10 to 50 C)
Storage Temperature Range
5 to 140 F (-15 to 60 C)
Operating Humidity Range
0% to 90% RH, Non-Condensing
Storage Humidity Range
CONNECTIONS
Side A - Connector 1
USB A (MALE)
Side B - Connector 1
USB B (MALE)
STANDARDS & COMPLIANCE
Product Compliance
RoHS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“U021-003”相匹配的价格&库存,您可以联系我们找货
