USB 2.0 A/B Cable (M/M), 6-ft.
Highlights
MODEL NUMBER: U022-006-R
Meets or exceeds USB 2.0
specifications
Supports faster data transfer
rate (1.5 to 480 Mbps) for low
speed and high speed devices,
including multimedia
applications.
Premium double-shielded
cables with tinned copper braid
and aluminum mylar foil feature
twisted 28AWG data lines, and
24AWG power lines.
Gold-plated connectors provide
superior conductivity
Make the connection between a USB device and your computer's USB port. This USB 2.0 A/B Gold
Device Cable assures that you get maximum performance from USB 2.0 devices (e.g. printers, external
hard drives). It supports fast data transfer rates of up to 480 Mbps, and is backward compatible with USB
1.1.
Comes in retail packaging
System Requirements
Any device requiring a USB
Description
cable (USB 2.0 performance
Tripp Lite's 6-ft. gold USB 2.0 A/B device cable meets or exceeds USB 2.0 specifications. Connects a
only when used with USB 2.0
USB device to a USB port on a computer or hub. Backward compatible - can be used with older USB 1.1
device and USB controller)
applications as well. All Tripp Lite USB 2.0 cabling include superior foil shielding for reliable, error-free
data communications. The significantly faster data transfer rates of USB 2.0 (up to 480 Mbps) make them
perfect for multimedia applications. Features gold plated connectors and gold plated copper contacts for
superior conductivity. the cable is manufactured with molded connectors and integral strain relief for extra
durability and long life. Clamshell retail packaging.
Features
Meets or exceeds USB 2.0 specifications
Supports faster data transfer rate (1.5 to 480 Mbps) for low speed and high speed devices including
Premium double-shielded cables with tinned copper braid and aluminum Mylar foil
Gold-plated connectors and gold-plated copper contacts for superior conductivity
Molded connectors and integral strain relief for extra durability and long life
Specifications
OVERVIEW
UPC Code
037332116512
1/2
Package Includes
6-ft. USB 2.0 Gold Cable USB-A
to USB-B
Technology
USB 2.0 (High Speed); USB
PHYSICAL
Color
Black
Cable Length (ft.)
6
Cable Length (m)
1.8
Shipping Dimensions (hwd / cm)
2.54 x 13.97 x 16.51
Shipping Dimensions (hwd / in.)
1.00 x 5.50 x 6.50
Shipping Weight (kg)
0.14
Shipping Weight (lbs.)
0.30
CONNECTIONS
Side A - Connector 1
USB A (MALE)
Side B - Connector 1
USB B (MALE)
WARRANTY
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2021 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“U022-006-R”相匹配的价格&库存,您可以联系我们找货
