Passive PoE Injector Cable Set
PRODUCT ID: 435
Description
Simplify your Internet of Things with a passive PoE injector cable. These are quite handy for
projects that have Ethernet connectivity and also need a power cable. Of course, you can get a
long Ethernet cable but then you have to figure out how to plug it in, making a mess of wires.
There is an official Power-over-Ethernet standard that allows devices and routers to activate a
48VDC power line on the unused Ethernet pins (4,5 and 7,8) but PoE is expensive, requiring a
special router and then a step-down converter to handle the high 48V line
For DIY projects, you may want to consider using these cables instead. One cable (the injector
half) has a Ethernet plug and port and a 2.1mm jack. When you plug in a power supply (say a
9VDC wall adapter), the injector merges the power adapter in so that pins 4 and 5 connect to the
power adapter ground and pins 7 and 8 have the positive 9VDC. The other cable (the extractor
half) does the opposite, splitting off pins 4,5 and 7,8 and bringing them to a 2.1mm DC barrel
plug. You can then use the DC plug to power your projects as if it was connected directly to the
wall adapter.
These are NOT official/standard "Power Over Ethernet" cables and you cannot use these to
provide power to an Arduino or other products from an official PoE host device (which will
supply 48VDC). They must be used a pair!
Note that Ethernet cables, especially long ones, will act like resistors as you get past 10 meter
spans. Most Ethernet cables are 24AWG, 0.085 ohms per meter (0.026 ohms per foot) so if you
want to draw say 500mA from your adapter, there will be a 1 Volt drop for every ~25 meters / 80
feet.
Because these cables use pins 4,5,7, and 8 to pass power you can't use these in gigabit Ethernet
situations (those pins would be used by the gigabit router), but your device and router should
back down to 10/100 megabit in such cases.
Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“435”相匹配的价格&库存,您可以联系我们找货
