1000 Eaton Boulevard
Cleveland, OH 44122
United States
OM3 can support 40GBASE-SR4 / 100GBASE-SR10 in applicable parallel optics networks
10Gb Duplex Multimode 50/125 OM3 LSZH Fiber
Patch Cable, (LC/LC) - Aqua, 50M (164 ft.)
MODEL NUMBER: N820-50M
Highlights
50 Meter LC/LC 10Gb Aqua
Fiber Patch cable...OM3 rated
Designed for 10-Gig Ethernet
applications
Backward compatible with
existing 50/125 fiber
Max 10Gb distance of 300
meters @850nm
Low-Smoke, Zero Halogen
(LSZH) Aqua jacket
Package Includes
Features
50 Meter LC/LC 10Gb Aqua Fiber Patch cable, OM3 rated
10gb Ethernet speed to 300 meters @850nm
Use with VCSEL and LED laser light sources
High-Speed, High-Bandwidth, Low-Cost
Backward compatible with legacy LAN's
Ideal for Fibre Channel (SAN) applications
IEEE 802.3ae and TIA LOMMF compliant
Specifications
OVERVIEW
UPC Code
037332149930
Technology
Multimode
Optical Mode
OM3
PHYSICAL
Cable Jacket Color
Aqua
Connector Color
White
Cable Jacket Material
LSZH
Cable Jacket Rating
OFNR
1/3
50 meter Duplex Multimode
50/125 Aqua OM3 Fiber Patch
Cable, LC/LC
Cleveland, OH 44122
United States
Clad Diameter (microns)
125
Core Diameter (microns)
50
Number of Fibers
2
Cable Length (ft.)
164
Cable Length (m)
50.00
Cable Length (in.)
1968.5
Minimum Bend Radius
20MM (Dynamic); 10MM (Static)
Shipping Dimensions (hwd / in.)
12.00 x 10.50 x 0.50
Shipping Dimensions (hwd / cm)
30.48 x 26.67 x 1.27
Shipping Weight (lbs.)
0.77
Shipping Weight (kg)
0.35
ENVIRONMENTAL
Operating Temperature Range
-4 to 140 °F (-20 to 60 °C)
Storage Temperature Range
Operating Humidity Range
5% to 85% RH, Non-Condensing
Storage Humidity Range
35% to 65% RH, Non-Condensing
COMMUNICATIONS
Network Compatibility
1 Gbps (Gigabit); 10 Gbps; 25 Gbps; 40 Gbps; 100 Gbps
Attenuation @ 850NM
3.0dB/Km
Insertion Loss
0.20dB
CONNECTIONS
Side A - Connector 1
LC DUPLEX (MALE)
Side B - Connector 1
LC DUPLEX (MALE)
Endface Polish
PC
FEATURES & SPECIFICATIONS
Push/Pull Tabs
No
Breakout
No
Trunk
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; REACH
WARRANTY & SUPPORT
2/3
Cleveland, OH 44122
United States
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N820-50M”相匹配的价格&库存,您可以联系我们找货
