1000 Eaton Boulevard
Cleveland, OH 44122
United States
OM3 can support 40GBASE-SR4 / 100GBASE-SR10 in applicable parallel optics networks
MTP/MPO Patch Cable with Push/Pull Tabs, 12
Fiber, 40GbE, 40GBASE-SR4, OM3 Plenum-Rated
- Aqua, 1M (3 ft.)
MODEL NUMBER: N844-01M-12-P
Highlights
Hi-density MTP/MPO 12-fiber
connectors for reduced cabling
Push/Pull tab connectors offer
maximum accessibility in high
density installations; install /
remove with one hand
OM3 rated 50/125 Multimode
Supports to 40GbE speeds
Package Includes
Features
MTP / MPO Push-Pull Connectors for Quick Fiber Optic connections
Push/Pull tab connectors offer maximum accessibility in high density installations; install / remove with
one hand
12 times the density of SC style connectors
High Density design cuts down on installation costs
50/125 OM3 Rated Multimode Fiber, 850nm
Plenum rated jacket
Unique cable ID label for Quality Control and Traceability
Each cable 100% tested for low insertion loss and back reflection
Test data supplied with each cable
Custom lengths available
Specifications
OVERVIEW
UPC Code
037332173713
Technology
Multimode
Optical Mode
OM3
PHYSICAL
Cable Jacket Color
Aqua
1/3
1 Meter MTP / MPO Patch
Cable, 12 Fiber, 40GbE Aqua
OM3 Plenum
Cleveland, OH 44122
United States
Connector Color
Aqua; Black
Cable Jacket Material
PVC
Cable Jacket Rating
OFNP
Clad Diameter (microns)
125
Core Diameter (microns)
50
Number of Fibers
12
Cable Length (ft.)
3.3
Cable Length (m)
1.01
Cable Length (in.)
39.4
Minimum Bend Radius
20MM (Dynamic); 10MM (Static)
Shipping Dimensions (hwd / in.)
7.00 x 0.50 x 9.00
Shipping Dimensions (hwd / cm)
17.78 x 1.27 x 22.86
Shipping Weight (lbs.)
0.05
Shipping Weight (kg)
0.02
ENVIRONMENTAL
Operating Temperature Range
-4 to 140 °F (-20 to 60 °C)
Storage Temperature Range
Operating Humidity Range
5% to 85% RH, Non-Condensing
Storage Humidity Range
35% to 65% RH, Non-Condensing
COMMUNICATIONS
Network Compatibility
40 Gbps; 100 Gbps; 400 Gbps
Attenuation @ 850NM
3.0dB/Km
Insertion Loss
0.35dB
CONNECTIONS
Side A - Connector 1
12-STRAND MTP/MPO (FEMALE)
Side B - Connector 1
Endface Polish
PC
FEATURES & SPECIFICATIONS
Push/Pull Tabs
Yes
Breakout
No
Trunk
No
STANDARDS & COMPLIANCE
2/3
Cleveland, OH 44122
United States
Product Compliance
RoHS; REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N844-01M-12-P”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+792.883081+95.82860
