CAB.721
CAB.721
    TAOGLASLIMITED
    HIROSE U.FL TO SMA(F) 100MM
CAB.721 数据手册
CAB.721 Description: Hirose U.FL to SMA(F) Bulkhead Straight Connector with 100mm Ø1.32mm cable Features: Semi-Rigid Cable Assembly SMA(F) Bulkhead ST connector Hirose U.FL 100mm Ø 1.32mm cable RoHS & Reach Compliant SPE-12-8-103-D 1. Introduction 3 2. Cable Specifications – 0.047” Semi-Rigid 4 3. Cable Insertion Loss 6 4. Mechanical Drawing 7 Changelog 8 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-12-8-103-D www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. The Taoglas CAB.721 is a 1.32mm coaxial cable of 100m length with SMA female bulkhead connector and Hirose U.FL. As one of a great range of Taoglas’ standard cables the CAB.721 is ideal for use by worldwide RF professionals. Taoglas also provides custom cables through our Cable and Connector Division. When a custom cable is required this is the perfect tool for building your own cable variant. Introduction 1. Taoglas provides customized length and connector variants subject to MOQ. Contact your regional Taoglas office for details. Introduction 1. Introduction 1. Introduction SPE-12-8-103-D www.taoglas.com 3 2. Cable Specifications – 0.047” Semi Rigid Cross Section 3. 2.1Antenna Characteristics2. Specifications 3. Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics2. 3. 2.2 Specifications Antenna Characteristics2. Structure and Dimensions Specifications 3. Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-12-8-103-D www.taoglas.com 4 2.3 Cable Specifications 1 Item: 32 AWG 2 Rating Temp Voltage: 105°C 30V UL 1979 3 Insulation Resistance: 1000 MEGA OHM-KM Min. 4 Conductor Resistance: 545 OHM/KM/20°C Max. 5 Dielectric Strength: AC 1.0 KV/minute 6 Spark test: 2.5 KV 7 UL Rating 8 Insulation 1581: VW-1 Unaged Tensile Strength Elongation 200% min. Aged Unaged Min 75%(168HRS*232°C) Tensile Strength Elongation 9 2500 PSI Min.(1.76Kg/mm²) Jacket Unaged Unaged Min 75%(168HRS*232°C) Tensile Strength 2500 PSI Min.(1.76Kg/mm²) Elongation 200% min. Aged Unaged Min 75%(168HRS*232°C) Tensile Strength Elongation Unaged Min 75%(168HRS*232°C) 10 Nom. Impedance 50  3 Ohms 11 Nom. Capacitance 96  3 pF/m 12 Nom. Vel. Of Prop. 69% 13 VSWR (0-6GHz) Max 1.3 14 Flame Test VW-1 OK 15 Attenuation (dB/1M) 2.0GHz 2.80 2.4GHz 3.10 3.0GHz 3.50 4.0GHz 4.00 5.0GHz 4.60 6.0GHz 5.10 SPE-12-8-103-D www.taoglas.com 5 3. 4. Cable Insertion Loss 3.1 Insertion Loss Antenna Radiation Patterns3.Antenna 0 Characteristics -2 4. Antenna Radiation Patterns 4. (dB) -4 Antenna Radiation Patterns3.Antenna -6 Characteristics CAB.721_S21 -8 4. Antenna Radiation Patterns3.Antenna -10 500 Characteristics 1500 2500 3500 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna 4500 5500 (MHz) Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-12-8-103-D www.taoglas.com 6 4. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-12-8-103-D Mechanical Drawing www.taoglas.com 7 Changelog for the datasheet SPE-15-8-019 – CAB.721 Revision: D (Current Version) Date: Changes: Changes Made by: 2019-01-17 Amended Spec table and format Jack Conroy Previous Revisions Revision: C Date: Changes: Changes Made by: 2017-07-10 PCN Jack Conroy Revision: B Date: Changes: Changes Made by: 2015-08-04 Added Mounting Hole Jack Conroy Revision: A (Original First Release) Date: 2012-08-14 Notes: Author: SPE-12-8-103-D Technical Writer www.taoglas.com 8 www.taoglas.com © Taoglas SPE-12-8-103-D www.taoglas.com 9
CAB.721 价格&库存
很抱歉,暂时无法提供与“CAB.721”相匹配的价格&库存,您可以联系我们找货
