CARA62805S07990
CARA62805S07990
    SWITCHCRAFT
    MINI-CON-X,2-METERCABLE,6PIN
CARA62805S07990 数据手册
ASS'Y P/N CARA62802S07990 CARA62803S07990 CARA62804S07990 CARA62805S07990 CARA62806S07990 CARA62807S07990 CARA62808S07990 CARA6280XSXXX90 NOTES: 1. FINISHED CABLE ASSEMBLY TO BE COILED 2. OVERMOLD BOOT MATERIAL: PVC, BLACK 3. ELECTRICAL TEST: 100% CONTINUITY NO. OF POS. 2 3 4 5 6 7 8 "X" DIM. 6 FT. 7 IN. 2 IN. [2M] CABLE LENGTH IN "INCHES" KEYWAY KEYWAY 2 1 1 2 CUSTOMER PRINT 3 FACE VIEW P/N: CARA62802SXXX90 KEYWAY KEYWAY FACE VIEW P/N: CARA62803SXXX90 5 1 4 1 2 4 2 3 KEYWAY 3 FACE VIEW FACE VIEW P/N: CARA62805SXXX90 P/N: CARA62804SXXX90 6 4 2 3 FACE VIEW P/N: CARA62806SXXX90 1 7 2 6 5 7 1 8 2 3 6 4 5 FACE VIEW P/N: CARA62807SXXX90 3 4 FACE VIEW P/N: CARA62808SXXX90 1.109 REF. [28.2mm] USE "BLANK: INSERT ASSY P/N CARA62802SXXX90 CABLE BLUNT CUT CARA62803SXXX90 COLOR CODE 2/20 AWG POS. 1 POS. 2 O.D. 0.215 REF WHT BLK 3/20 AWG POS. 1 POS. 2 POS. 3 O.D. 0.220 REF BLK WHT GRN 4/20 AWG POS. 1 POS. 2 POS. 3 POS. 4 O.D. 0.235 REF GRN RED BLK WHT 4 1 KEYWAY WIRE COLOR CODE 6/20 AWG CARA62806SXXX90 O.D. 0.275 REF POS. 1 POS. 2 POS. 3 POS. 4 POS. 5 POS. 6 BLU VIO GRN RED WHT BLK 7 8 6 END "A" 5 FACE VIEW P/N: CARA62808SXXX90 WIRE COLOR CODE 8/20 AWG POS. 1 POS. 2 POS. 3 POS. 4 POS. 5 POS. 6 POS. 7 O.D. 0.300 REF BLU GRY VIO GRN RED WHT BLK WIRE COLOR CODE CARA62808SXXX90 3 2 WIRE COLOR CODE 5/20 AWG POS. 5 CARA62805SXXX90 O.D. 0.255 REF POS. 1 POS. 2 POS. 3 POS. 4 BLU GRN RED WHT BLK CARA62807SXXX90 CABLE 20 AWG CONDUCTORS JACKET: PVC, BLACK 300V COUPLING RING MAT'L: THERMOPLASTIC O-RING MAT'L: RUBBER WIRE COLOR CODE CARA62804SXXX90 RIGHT ANGLE OVERMOLDED CABLE CONNECTOR, FEMALE MAT'L: THERMOPLASTIC (2-8) #20 SOCKET CONTACTS MAT'L: GOLD PLATED COPPER ALLOY CXA #6280-XSG COLOR CODE END "A" WIRE COLOR CODE CARA6280XSXXX90 1 "X" DIM. 1.375 REF. [34.9mm] PART NUMBER: 5 NO OF POSITIONS KEYWAY KEYWAY 8/20 AWG POS. 1 POS. 2 POS. 3 POS. 4 POS. 5 POS. 6 POS. 7 POS. 8 O.D. 0.300 REF BRN BLU GRY VIO GRN RED WHT BLK CUSTOMER APPROVAL THIS DOCUMENT CONTAINS CONFIDENTIAL INFORMATION PROPRIETARY TO CONXALL CORPORATION. ANY REPRODUCTION, DISCLOSURE, OR USE OF THIS DOCUMENT /INFORMATION IS EXPRESSLY PROHIBITED UNLESS AUTHORIZED IN WRITING BY CONXALL CORPORATION. APPROVED BY: DATE: A AN REV. INIT. 06-30-16 DATE ALL INFORMATION ILLUSTRATED IS THE PROPERTY OF "CONXALL CORPORATION." UNAUTHORIZED DUPLICATION OR DISTRIBUTION OF THIS DOCUMENT IS PROHIBITED. ALL UNITS ARE IN FEET, INCHES, FRACTION OF INCHES AND DECIMALS. DRAWING CREATED PER DOR 16-7414JP DESCRIPTION ORIG. DRAWN BY: AN RoHS COMPLIANT 601 E. WILDWOOD VILLA PARK, IL 60181 TITLE: APPROVED BY: NTS = CRITICAL CHARACTERISTIC FLAG PER SPEC. XXXX 05-26-16 CHECKED BY: SCALE DIMENSIONS IN BRACKET [ ] ARE METRIC. DATE: FILE: SIZE B CARA6280XSXXX90 SHEET 1 OF 1 CUSTOMER: DIRECTORY: PART NUMBER: SLW CABLE ASSEMBLY (2-8) #20 SOCKET CONTACTS MINI-CON-X, R. ANGLE STANDARD PRODUCT CARA6280XSXXX90 REV A
CARA62805S07990 价格&库存
很抱歉,暂时无法提供与“CARA62805S07990”相匹配的价格&库存,您可以联系我们找货
