Customer Specification
PART NO: AR0800103
M12-A Female
Issue: 1 Issue Date: 7/29/2016 Effective Date: 7/29/2016
Drawings
Technical Data
Cordage Construction
Cordage Part Number
Component 1
a) Conductor
b) Insulation
Insulation Colors
Jacket
a) Color(s)
Cord Configuration
End 1
End 2
Insert
Mold Color
Contact
O-Ring
Coupling Nut
Available Lengths
Diameters (In)
103
8 COND
24 (19/36) AWG Bare Copper
0.011” Wall, Nom. SR-PVC
White, Brown, Green, Yellow, Grey, Pink,
Blue & Red
0.032” Wall, Nom. PVC
SLATE
0.025
0.047
0.244
M12-A Female
Cut End
Black TPU
Black TPU
Copper Alloy, Gold plated
FKM
Copper Alloy, Nickel plated
0.6, 1, 3, 5, 10, 15, 20 Meters
Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207
www.alphawire.com | 1-800-52 ALPHA
1
PART NO: AR0800103
M12-A Female
Applicable SpecificationsCable
UL
CSA International
Applicable SpecificationsCord Set
UL
CSA
Nominal Voltage
Rated Voltage
Ingress Protection
Environmental Compliance
CE
REACH Regulation (EC
1907/2006)
Physical & Mechanical
Properties
Temperature Range, Cord
Temperature Range,
Connector
Bend Radius
Pull Tension
Current Rating
Ordering Information
AR0800103 SL355
AR0800103 SL356
AR0800103 SL357
AR0800103 SL358
AR0800103 SL359
AR0800103 SL400
AR0800103 SL401
Standard Package
AWM/STYLE 2661
C(RU) AWM I/II A/B FT1
105°C / 300 V RMS
105°C / 300 V RMS
ANSI/UL 2238, Cable Assembly Extension
RU, UL File Number E485156
CSA-C22.2 No. 182.3, Special Use
Attachment Plugs, Receptacles and
Connectors
cRU, UL File Number E485156
30 V
36 V
IP67/NEMA 6P
All materials used in the manufacture of
this part meet the requirements of
European Directive 2011/65/EU regarding
the restriction of use of certain hazardous
substances in electrical and electronic
equipment. Exemption used; 6a.
This product does not contain Substances
of Very High Concern (SVHC) listed on the
European Union’s REACH candidate list in
excess of 0.1% mass of the item.
-40 to 105°C(static), -15 to 105°C (dynamic)
-25°C to +80°C
7X Cable Diameter (static), 10X Cable
Diameter (dynamic)
30 Lbs, Maximum
1.4 Amps @ 50°C
0.6 Meters
1.0 Meters
3.0 Meters
5.0 Meters
10.0 Meters
15.0 Meters
20.0 Meters
Each
www.alphawire.com
| 1-800-52
ALPHA
Although Alpha Wire (“Alpha”) makes every
reasonable effort to ensure
their accuracy
at the time of this publication, information and
2
specifications described herein are subject to error or omission and to change without notice, and the listing of such information and
specifications does not ensure product availability. Alpha provides the information and specification herein on an “AS IS” basis, with no
representations or warranties, whether express, statutory or implied. In no event will Alpha be liable any damages (including consequential,
很抱歉,暂时无法提供与“AR0800103SL358”相匹配的价格&库存,您可以联系我们找货
