AR1200125BK358
AR1200125BK358
    ALPHAWIRE(阿尔法电线)
    M12F90DEGTOCUT22AWG04POL
AR1200125BK358 数据手册
Customer Specification PART NO: AR1200125 M12-A Female Issue: 1 Issue Date: 7/29/2016 Effective Date: 7/29/2016 Drawings Technical Data Cordage Construction Cordage Part Number Component 1 a) Conductor b) Insulation Insulation Colors Jacket a) Color(s) Cord Configuration End 1 End 2 Insert Mold Color Contact Coupling Nut O-Ring Diameters (In) 346 12 COND 0,25mm² (32x 0,10mm) Bare Copper (24 AWG) 0.010” Wall, Nom. PP White, Brown, Green, Yellow, Grey, Pink, Blue, Red, Black, Violet, Grey/Pink & Red/Blue 0.028” Wall, Nom. PUR, Zero Halogen Black 0.047 0.252 M12-A Female Cut End Black TPU Black TPU Copper Alloy, Gold plated Copper Alloy, Nickel plated FKM ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 1 Customer Specification PART NO: AR1200125 M12-A Female Available Lengths Applicable SpecificationsCable UL 0.6, 1, 3, 5, 10, 15, 20 Meters AWM/STYLE 20549 80°C / 300 VRMS CSA International Applicable SpecificationsCord Set UL C(RU) AWM I/II A/B FT2 80°C / 300 VRMS Nominal Voltage Rated Voltage Ingress Protection Environmental Compliance CE REACH Regulation (EC 1907/2006) Physical & Mechanical Properties Temperature Range, Cord Temperature Range, Connector Bend Radius Pull Tension Current Rating Ordering Information AR1200125 BK355 AR1200125 BK356 AR1200125 BK357 AR1200125 BK358 AR1200125 BK359 AR1200125 BK400 AR1200125 BK401 Standard Package ANSI/UL 2238, Cable Assembly Extension RU, UL File Number E485156 30 V 36 V IP67/NEMA 6P All materials used in the manufacture of this part meet the requirements of European Directive 2011/65/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Exemption used; 6a. This product does not contain Substances of Very High Concern (SVHC) listed on the European Union’s REACH candidate list in excess of 0.1% mass of the item. -40 to 80°C(static), -25 to 60°C (dynamic) -25°C to +80°C 5X Cable Diameter (static), 10X Cable Diameter (dynamic) 45 Lbs, Maximum 0.8 Amps @ 50°C 0.6 Meters 1.0 Meters 3.0 Meters 5.0 Meters 10.0 Meters 15.0 Meters 20.0 Meters Each Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of this publication, information and ••••••••••••••••••••••••••••••••••••••• specifications described herein are subject error Lidgerwood or omission and Ave, to change without notice, and the listing of such information and Alpha Wireto| 711 Elizabeth, NJ 07207 specifications does not ensure product availability. Alpha provides the information and specification herein on an “AS IS” basis, with no www.alphawire.com | 1-800-52 ALPHA 2 representations or warranties, whether express, statutory or implied. In no event will Alpha be liable any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Alpha has been advised of the possibility of such damages, whether in an action under contact, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specification described herein.
AR1200125BK358 价格&库存
很抱歉,暂时无法提供与“AR1200125BK358”相匹配的价格&库存,您可以联系我们找货
