FDE-S
FDE-S
    HRS(广濑)
FDE-S 数据手册
The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. FD TYPE CONNECTOR FOR RIBBON CABLE (1.27-millimeter pitch for standard ribbon cable) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. General The FD Series connectors are designed for ribbon cable IDC termination. Connecting wires are grouped, so the FD Series are useful for labor-saving in connection work and enhancing wiring reliability. Being compatible with 1.27-mm (standard) ribbon cables, the FD Series are general-purpose, high-performance connectors that are capable of being interacing with connectors for other types of ribbon cables. 9, 15, 25 and 37-contact models available. Features (1) Compact and sturdy due to metal shell. (2) Can be mounted on the front or back of a panel or chasis as necessary. (3) Fixes the cable securely by fixing the ribbon cable clamp with a metal plate in the connector. (4) Can be easily connected to a standard ribbon cable, having a cable IDC pitch of 1.27mm (standard). (5) Easy to connect cables by following the same IDC termination and connecting procedures as those for our other ribbon cable connectors. Application Most suitable for modems in communications equipment such as computers, peripherals and terminals, control equipment, and measuring instruments, and export equipment. 67 04/2009 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. Electrical and Environmental Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Electrical and Environmental Characteristics Current rating 1A Voltage rating 200V AC Insulation resistance 1,000MΩ min. at 500V DC Contact resistance 25mΩ max. at 100mA DC Withstand voltage 650Vr.m.s. AC for 1 minute Material and Finish Shell Steel Nickel plating Insulator PBT(GE Valox) Black Contacts Copper alloy Nickel-plating + Gold plating Cable specifications Ordering Informations FD B − 25 (1) (2) P (1) (2) (3) (4) Series Name FD: Insulation displacement termination Shell Size E.A.B.C. No. of Pin 9, 15, 25, 37 Type of contacts P: Male contact S: Female contact (5) Shell dimpled (male connector only) (6) Specification contents (05) : Nickel-plated shell F (05) (3) (4) (5) (6) D Subminiature IDC Male FDB-25P(05) Unit: mm 68 HRS No No.of pin Part No. A CL211-0143-8-05 9 FDE-9P(05) 30.81 CL211-0145-3-05 CL211-0135-0-05 CL211-0147-9-05 15 25 37 FDA-15P(05) FDB-25P(05) FDC-37P(05) B C D 16.9 24.99 17.6 39.14 25.24 33.32 25.8 53.04 39.01 47.04 39.6 69.32 55.47 63.5 56.14 E F G H I J 19 19.28 5.99 1.2 24.39 2.7 27.2 41.4 57.9 27.55 41.28 57.71 5.99 5.87 5.87 1.2 1.3 1.4 24.39 24.37 24.47 2.7 3.2 3.2 RoHS YES 04/2009 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. D Subminiature IDC, Male with Grounding Dimples FDB-25PF(05) Unit: mm HRS No No.of pin Part No. CL211-0721-2-05 CL211-0722-5-05 CL211-0723-8-05 9 15 25 FDE-9PF(05) FDA-15PF(05) FDB-25PF(05) CL211-0724-0-05 37 FDC-37PF(05) A B C D E F G H I J 30.81 16.9 24.99 39.14 25.24 33.32 53.04 39.01 47.04 17.6 25.8 39.6 19 27.2 41.4 19.28 27.55 41.28 5.99 5.99 5.87 1.2 1.2 1.3 24.39 24.39 24.37 2.7 2.7 3.2 69.32 55.47 56.14 57.9 57.71 5.87 1.4 24.47 3.2 63.5 RoHS YES 69 04/2009 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. D Subminiature IDC, Male with Grounding Dimples FDB-25S(05) Unit: mm HRS No No.of pin Part No. A B C D E F G H I J CL211-0144-0-05 9 FDE-9S(05) 30.81 16.4 24.99 17.6 19 19.28 6.17 1.2 24.37 2.7 CL211-0146-6-05 CL211-0136-2-05 15 25 FDA-15S(05) FDB-25S(05) 39.14 24.59 33.32 53.04 38.3 47.04 25.8 39.6 27.2 41.4 27.55 41.28 6.17 6.17 1.2 1.2 24.37 24.37 2.7 3.2 CL211-0148-1-05 37 FDC-37S(05) 69.32 54.76 56.14 57.9 57.71 6.17 1.2 24.37 3.2 63.5 RoHS YES Connector Mounting Method and Mounting Dimensions sConnector mounted on the face of the panel (front mounting) Unit: mm Shell size A1 B1 E 24.99 22 A 33.32 30.3 B 47.04 44 C 63.5 60.5 sConnector mounded on the back of the panel (rear mounting) Unit: mm 70 Shell size A2 B2 E 24.99 20.2 A 33.32 28.6 B 47.04 42.5 C 63.5 59.2 04/2009 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. sConnecting Type Male Connector Female Connector Pin No. Pin No. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. A Type Cable mark Cable mark B Type C Type D Type 71 04/2009 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. Tools Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Hi-Flex Connecting Press Powered by TCPDF (www.tcpdf.org) Guide Plate HRS No HRS No Part No. 550-0082-2 Hi-Flex connecting press Height Width Pressure Blook (For Plug) 72 Depth Weight 440mm 160mm 350mm 13kg Part No. 902-0008-9 FDE-GP 902-0011-3 902-0005-0 FDA-GP FDB-GP 902-0014-1 FDC-GP Pressure Blook (For Socket) HRS No Part No. HRS No Part No. 902-0006-3 902-0009-1 902-0003-5 FDE-P pressure block FDA-P pressure block FDB-P pressure block 902-0007-6 902-0010-0 902-0004-8 FDE-S pressure block FDA-S pressure block FDB-S pressure block 902-0012-6 FDC-P pressure block 902-0013-9 FDC-S pressure block 04/2009
FDE-S 价格&库存
很抱歉,暂时无法提供与“FDE-S”相匹配的价格&库存,您可以联系我们找货
