Serial ATA (SATA) Right-Angle Signal Cable
(7Pin/7Pin-Up), 19-in. (48.26 cm)
MODEL NUMBER: P941-19I
Highlights
Connect your high-speed Serial
ATA device to a Serial ATA
controller
Features 7Pin Straight and 7Pin
Right-Angle Up connectors
Angled connector ideal for
situations in which space is at a
premium, and reduces stress /
excessive bending on the cable
SATA III (6Gbps) / SATA II
(3Gbps) / SATA I (1.5Gbps)
Compliant
Cable is shielded to protect
against EMI/RFI
Applications
controller
Compatible with Serial ATA
Hard Drives, Blu-ray/DVD/CD
Drives and other Serial ATA
devices
Features
System Requirements
Connect your high-speed Serial ATA device to a Serial ATA controller
Support data transfer rates of up to 6.0 Gbps
Serial ATA device
Narrow cables design: 1) simplifies cable routing and installation 2) improves air flow within CPU (no
more big ribbons blocking air movement)3) right-angle design for tight spaces
Meets Serial ATA 1.0 standards, including Errata 029
Cable is shielded to protect against EMI/RFI
Package Includes
Specifications
OVERVIEW
UPC Code
037332120069
Technology
SATA/eSATA
PHYSICAL
Color
Red
Cable Jacket Color
Red
Wire Gauge (AWG)
26
Cable Length (ft.)
1.6
Cable Length (m)
0.49
1/2
19-in. Serial ATA Right Angle
(SATA) Signal Cable 7Pin/7Pin,
Straight/Up
Cable Length (in.)
19
Cable Length (cm)
48.26
Shipping Dimensions (hwd / in.)
5.31 x 3.94 x 0.50
Shipping Dimensions (hwd / cm)
13.49 x 10.01 x 1.27
Shipping Weight (lbs.)
0.14
Shipping Weight (kg)
0.06
CONNECTIONS
Side A - Connector 1
7 PIN SATA (MALE)
Side B - Connector 1
7 PIN SATA (MALE) - RIGHT ANGLE UP
FEATURES & SPECIFICATIONS
IP68 Rated
No
IP20 Rated
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS
WARRANTY
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“P941-19I”相匹配的价格&库存,您可以联系我们找货
