USB-A to RS232 (DB9) Serial Adapter Cable (M/M), 5 ft. (1.52 m)
MODEL NUMBER: U209-000-R
Highlights
5-ft. (1.52 m) Length
No external power required
Compatible with Windows, Mac
and Linux computers, and
Android Tablets / Phones (See
System Requirements for
details)
Need drivers? Click on the
Support Page link on the left
System Requirements
Connect devices with a 9-pin RS-232 serial port, such as modems, digital cameras, PDAs and ISDN
terminals, to the USB Type-A port on your computer or laptop.
Description
The U209-000-R USB-to-Serial Adapter Cable allows you to connect a 9-pin RS-232 serial device to a
computer or laptop with a USB Type-A port. It works with modems, digital cameras, PDAs, ISDN terminals
and other devices with a serial port. The U209-000-R supports data transfer speeds up to 230
Kbps—twice as fast as a built-in serial port. No external power is required, and the compact 5-ft. (1.52 m)
cable tucks away conveniently in your backpack or laptop bag for easy travelling. Doubled-shielded
design with gold-plated contacts, tinned copper braid and aluminum Mylar foil shield eliminates crosstalk
and reduces EMI/RFI interference. Compatible with Windows 2000, XP, Server 2003, Vista, 7, Server
2008, 8, 8.1, Server 2012, 10 and 11; Mac OS X 10.6 through 12.4; and Linux Redhat 7.3, 8.0 and 9.0.
Features
Connect a RS-232 Serial device to the USB port on your computer
Connectors: USB-A male/DB9 male
Portable design is ideal for use with a PDA or digital camera
Does not require external power
Supports data transfer rates up to 230 kbps
Premium double-shielded cable with tinned copper braid and aluminum Mylar foil shield that eliminates
cross-talk and reduces EMI/RFI interference
Compatible with Windows, Mac and Linux computers
Prolific PL2303RA Chipset
Specifications
OVERVIEW
UPC Code
037332095640
Technology
Serial; USB
1/3
up to 11
Compatible with Mac OS X 10.6
through 12.4
Compatible with Linux Redhat
7.3, 8.0 and 9.0 (Linux Kernel
2.4.31 and above already
includes built-in drivers)
Package Includes
U209-000-R USB-A to Serial
Adapter (DB9) - (M/M), 5-ft.
(1.52 m)
Owner's Manual
Host Connector
USB A (MALE)
INPUT
Bus Powered
No
PHYSICAL
Color
Black
Material of Construction
PVC
Cable Jacket Color
Black
Cable Jacket Material
PVC
Cable Outer Diameter (OD)
5.0 +/- 0.15
Cable Length (ft.)
4.9
Cable Length (m)
1.49
Shipping Weight (lbs.)
0.24
Shipping Weight (kg)
0.11
Unit Dimensions (hwd / in.)
4.920 x 1.210 x 0.490
Unit Dimensions (hwd / cm)
150 x 3.08 x 1.25
Unit Packaging Type
Box
Unit Weight (lbs.)
0.1984
Unit Weight (kg)
0.09
ENVIRONMENTAL
Operating Temperature Range
32 to 140F (0 to 60C)
Storage Temperature Range
-4 to 176F (-20 to 80C)
Relative Humidity
0 to 80% RH
CONNECTIONS
Number of Ports
1
Side A - Connector 1
USB A (MALE)
Side B - Connector 1
DB9 (MALE)
Connector Plating
Gold
FEATURES & SPECIFICATIONS
USB Specification
USB 2.0 (up to 480 Mbps)
Driver Required
No
Remote Wakeup Support
No
2/3
STANDARDS & COMPLIANCE
Product Certifications
EN 55024; EN 55032
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
3/3
很抱歉,暂时无法提供与“U209-000-R”相匹配的价格&库存,您可以联系我们找货
