1000 Eaton Boulevard
Cleveland, OH 44122
United States
Cat6 Gigabit Snagless Molded (UTP) Ethernet
Cable (RJ45 M/M), PoE, Blue, 12 ft. (3.66 m)
MODEL NUMBER: N201-012-BL
Highlights
Meets Category 6 cabling
standards
Meets most current industry
standards including IEEE
802.3ab, IEEE 802.5,
ANSI/EIA/TIA 568, ISO/IEC
11801, and ETL (Category 6,
draft 11)
Drastically reduce impedance &
structural return loss compared
to standard 100Mhz wire
Snagless boots protect the
locking tabs on the RJ45
connectors from being damaged
during installation
Feature molded connectors with
integral strain relief. Rated for
550 MHz/1 Gbps
communication
Package Includes
12-ft. Cat6 Blue Gigabit Patch Cord
Snagless Molded
Features
Meets category 6 cabling standards
Premium cabling for category 6, category 5e and category 5 applications
Length: 12 ft./Color: Blue/Connectors: RJ45 male
Drastically reduce impedance & structural return loss compared to standard 100MHz wire
High-quality copper wire and a staggered-pin plug design to keep near-end crosstalk levels to a
minimum
Feature molded connectors with integral strain relief
Snagless design protects the locking tabs on the RJ45 connectors from being damaged or snapped off
during installation
PVC 4-pair stranded UTP
Specifications
OVERVIEW
UPC Code
037332172877
Technology
Cat6
PHYSICAL
Cable Jacket Color
Blue
Cable Jacket Material
PVC
Cable Jacket Rating
CM
Cable Shielding
UTP
1/3
Cleveland, OH 44122
United States
Cable Outer Diameter (OD)
6.0 mm
Number of Conductors
4 Pair
Conductor Material
Stranded Copper
Conductor Gauge
24 AWG
Cable Length (ft.)
12
Cable Length (m)
3.66
Cable Length (in.)
144
Cable Length (cm)
365.8
Shipping Dimensions (hwd / in.)
10.00 x 8.00 x 0.50
Shipping Dimensions (hwd / cm)
25.40 x 20.32 x 1.27
Shipping Weight (lbs.)
0.28
Shipping Weight (kg)
0.13
ENVIRONMENTAL
Operating Temperature Range
14 to 122 F (-10 to 50 C)
Storage Temperature Range
5 to 140 F (-15 to 60 C)
Operating Humidity Range
0% to 90% RH, Non-Condensing
Storage Humidity Range
COMMUNICATIONS
Bandwidth per TIA Standard
250 MHz
Maximum Bandwidth as Tested
500 MHz
Network Compatibility
1 Gbps (Gigabit)
IEEE Standards Supported
802.3an; 802.3at
CONNECTIONS
Side A - Connector 1
RJ45 (MALE)
Side B - Connector 1
RJ45 (MALE)
Crossover Wiring
No
Contact Plating
Gold
PoE Type
Type 2 PoE+ (30W, IEEE 802.3at)
Connector Type
Snagless; Molded
Wiring Configuration
EIA/TIA 568B
Angled Connector
No
FEATURES & SPECIFICATIONS
IP68 Rated
No
2/3
Cleveland, OH 44122
United States
Snagless Connector
Yes
Antibacterial
No
STANDARDS & COMPLIANCE
Product Certifications
UL Listed; cUL Listed
Product Compliance
CE (Europe); RoHS; IEEE 802.3an 10GBase-T; IEEE 802.3at PoE+; REACH; UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N201-012-BL”相匹配的价格&库存,您可以联系我们找货
