HARTING
Smart patch cable IP 20 Cat. 6
Han® 24Ha-VIS
HPR enlarged
Ha-VIS Smart patch cable
IP 20 Cat. 6
Advantages
General
• Easy and fast illuminated detection of patch
cables
• Easy to use
• Suitable for Gigabit Ethernet 1000 Mbit/s
• Transmission performance in acc. with Cat. 6
ISO/IEC 11 801
• Compact and space saving plug by dual boot
design
• Capable for multiport applications
• Very robust locking lever protection and
unlocking latch
• Good shielding against EMC influence
• Flame retardant and halogen-free
• Colour coding option
• RFID option
• GHMT certified
This RJ45 patch cable comes with illuminated RJ45 Ethernet
plugs. The plugs are very easy and comfortable to identify
each other over distances up to 100 meters, e.g. in clusters
of racks in data centres facilitate enormously the allocation
of ports.
Description
Order number
Each RJ45 connector has an integrated LED which is illuminated by a detector. It works in anyway if the connectors
are plugged in or not. That function has no influence on the
Ethernet data transmission.
The new Smart patch cables expand HARTING’s Automation
IT generic cabling system. The family is marked by an unique
design of the two part boot, called dual-boot design. This offers a very easy robust handling and bending protection.
Drawing
RJ45 acc. to IEC 60 603-7
Boot grey
Locking lever protection and unlocking latch
Cable S/FTP AWG 27
LSZH chemical resistant cable
jacket, yellow
Wiring: 1:1 TIA/EIA-568-B, 8-wire
100 % electrical tested
Ha-VIS Smart Patch cable Cat. 6
(further lengths on request)
1.0 m
2.0 m
5.0 m
7.0 m
10.0 m
09 47 474 7201
09 47 474 7203
09 47 474 7206
09 47 474 7208
09 47 474 7211
All data given are in line with the actual state of the art and therefore not binding.
HARTING reserves the right to modify designs without giving the relevant reasons.
HARTING Ha-VIS Smart patch cable IP 20 Cat. 6
Technical characteristics
Cat. 6 / Class E acc. to ISO/IEC 24 702 resp. ISO/IEC 11 801,
IEC 61 935-2
Performance
Mechanical Characteristics
Bending protection
Electrical Characteristics
Characteristic Impedance
Wiring
EMC
100 Ω
1:1 TIA/EIA-568-B
Fully shielded (aluminised foil and tinned copper braid)
Environmental Characteristics
Protection class
Halogen-free
Flame retardant
Low smoke density
Lead free
IP 20
IEC 60 754-2
IEC 60 332-3
IEC 61 034
LSZH and RoHS compliant
Thermal Characteristics
Operating temperature
Mobile:
Stationary:
0 °C ... +50 °C
-20 °C ... +60 °C
Printing
HARTING Ha-VIS Smart Patch Cat. 6 FRNC
Packaging
One piece in poly-bag labelled
HARTING Ha-VIS Smart patch cable Detector
Detector
Description
• Metal housing
• Protection cover for the
contacts
• 4 batteries type LR4 included
and available as spare parts
at specialized trade
• Operating modes:
1. light on
2. fast flash light
3. slow flash light
4. light off
Order number
General
Make sure that the detector is switched off when not in use.
otherwise the batteries will be discharged. It is obligatory
to use only this detector with HARTING Ha-VIS Smart patch
cables. Otherwise the cables could be damaged.
09 47 900 0001
HARTING RJ Industrial® 10G colour clips
colour clips
Description
Order number
Colour clips
white
grey
yellow
magenta
red
blue
green
brown
09 45 850 0001
09 45 850 0002
09 45 850 0003
09 45 850 0005
09 45 850 0007
09 45 850 0008
09 45 850 0009
09 45 850 0010
General
These clips are suitable for colour coding of the HARTING
Ha-VIS Smart patch cable as well as RJ Industrial® 10G.
The colour clips provide an RFID option for automatic
detection and storage of the patch cable ID. Every order
number contains a package of 50 pieces.
HARTING Electric GmbH & Co. KG
Wilhelm-Harting-Straße 1 | D-32339 Espelkamp | Postfach 14 73 | D-32328 Espelkamp
Tel.: +49 5772 47-97100 | Fax: +49 5772 47-688 | electric@HARTING.com | www.HARTING.com
2010-09-09
很抱歉,暂时无法提供与“09474747203”相匹配的价格&库存,您可以联系我们找货
