1000 Eaton Boulevard
Cleveland, OH 44122
United States
Cat6 Gigabit Solid Conductor Snagless UTP
Ethernet Cable (RJ45 M/M), PoE, Blue, 50 ft.
(15.24 m)
MODEL NUMBER: N202-050-BL
Highlights
Meets Category 6 cabling
standards
Solid Conductor 4 Pair Cable for
long distance patch runs
Drastically reduce impedance
and structural return loss
compared to Stranded
Conductor patch cables
High-quality copper wire and a
shortened body plug design
Snagless boots protect the
locking tabs on the RJ45
connectors from being damaged
during installation
System Requirements
Package Includes
N202-050-BL, 50-ft. (15.24 m) Blue
Cat6 Solid Conductor Patch Cable
Features
50-ft. (15.24 m) Blue Cat6 Solid Conductor patch cable
Meets Category 6 cabling standards
Solid Conductor 4 Pair Cable for long distance patch runs
Drastically reduce impedance and structural return loss compared to Stranded Conductor patch cables
High-quality copper wire and a shortened body plug design
Snagless boots protect the locking tabs on the RJ45 connectors from being damaged during installation
Specifications
OVERVIEW
UPC Code
037332157409
Technology
Cat6
PHYSICAL
Cable Jacket Color
Blue
Cable Jacket Material
PVC
Cable Jacket Rating
CM
Cable Shielding
UTP
Cable Outer Diameter (OD)
6.0 mm
Number of Conductors
4 Pair
1/3
Cleveland, OH 44122
United States
Conductor Material
Solid Copper
Conductor Gauge
24 AWG
Cable Length (ft.)
50
Cable Length (m)
15.24
Cable Length (in.)
600
Cable Length (cm)
1524
Shipping Dimensions (hwd / in.)
12.00 x 10.00 x 0.50
Shipping Dimensions (hwd / cm)
30.48 x 25.40 x 1.27
Shipping Weight (lbs.)
1.27
Shipping Weight (kg)
0.58
ENVIRONMENTAL
Operating Temperature Range
14 to 122 F (-10 to 50 C)
Storage Temperature Range
5 to 140 F (-15 to 60 C)
Operating Humidity Range
0% to 90% RH, Non-Condensing
Storage Humidity Range
COMMUNICATIONS
Bandwidth per TIA Standard
250 MHz
Maximum Bandwidth as Tested
500 MHz
Network Compatibility
1 Gbps (Gigabit)
IEEE Standards Supported
802.3an; 802.3at
CONNECTIONS
Side A - Connector 1
RJ45 (MALE)
Side B - Connector 1
RJ45 (MALE)
Crossover Wiring
No
Contact Plating
Gold
PoE Type
Type 2 PoE+ (30W, IEEE 802.3at)
Connector Type
Snagless
Wiring Configuration
EIA/TIA 568B
Angled Connector
No
FEATURES & SPECIFICATIONS
IP68 Rated
No
Snagless Connector
Yes
Antibacterial
No
2/3
Cleveland, OH 44122
United States
STANDARDS & COMPLIANCE
Product Certifications
UL Listed; cUL Listed
Product Compliance
CE (Europe); RoHS; IEEE 802.3an 10GBase-T; IEEE 802.3at PoE+; REACH; UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N202-050-BL”相匹配的价格&库存,您可以联系我们找货
