P002-002
P002-002
    TRIPPLITE
    CABLE IEC TO AC CONVERTER 2'
P002-002 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States NEMA 5-15R to C14 Computer AC Power Cable 13A, 125V, 16 AWG, 2 ft. (0.61 m), Black MODEL NUMBER: P002-002 Highlights ● Recommended for powering computers, printers and other peripherals ● Adds 2-ft. (0.61 m) to your existing power connection to provide flexibility in placing devices ● NEMA 5-15R to C14 extension cord is ideal replacement for worn-out or missing cable ● Can connect a C13 peripheral to a PC's switched source to save energy and free up an outlet on your surge protector or PDU Applications ● Connect devices like computers, printers and monitors to a PDU up to 2-ft. (0.61 m) away in your workstation ● Extend an existing power connection up to 2-ft. (0.61 m) to more easily place a device or reach a power source ● Provide a high-quality replacement for a worn-out or missing power cord ● Power your monitor through a switched source on your PC to free up an outlet on your surge protector or PDU Computer AC power cable allows you to connect your PC or other device with a NEMA 5-15P plug to a PDU or UPS with a C13 power inlet. Features Computer AC Power Cable Connects Computers, Monitors and Other EquipmentThis computer AC power cable is designed for low-voltage data center, server room or home/office applications. It converts a NEMA 5-15P plug into a C14 connector. You can use it to connect a computer, monitor, printer or other device with a NEMA 5-15P plug to a surge protector, UPS system or PDU with C13 power outlets. You can also connect your C13 printer or monitor to a switched source on your PC, allowing you to turn both devices on and off at the same time. The 2-ft. (0.61 m) length helps reduce cable clutter. Package Includes ● Specifications OVERVIEW UPC Code 037332013361 Device Compatibility Computer; Monitor/HDTV; Printer; UPS; PDU; Server Country/Region North America INPUT Maximum Input Amps 13 Voltage Compatibility (VAC) 125 1/3 P002-002 NEMA 5-15R to C14 Computer AC Power Cable, 2-ft. (0.61 m), Black 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Plug Color Black Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Power Cord Jacket Type SJT Cable Outer Diameter (OD) 8.5mm Number of Conductors 3 Wire Gauge (AWG) 16 Wire Gauge (OD - mm²) 1.31 Cable Length (ft.) 2 Cable Length (m) 0.61 Shipping Dimensions (hwd / in.) 10.00 x 7.10 x 0.50 Shipping Dimensions (hwd / cm) 25.40 x 18.03 x 1.27 Shipping Weight (lbs.) 0.30 Shipping Weight (kg) 0.14 ENVIRONMENTAL Operating Temperature Range -4 F TO 140 F (-20 C TO 60 C) Storage Temperature Range -4 F TO 140 F (-20 C TO 60 C) Operating Humidity Range 10 TO 65% RH Storage Humidity Range 10 TO 65% RH CONNECTIONS Side A - Connector 1 IEC-320-C14 Side B - Connector 1 NEMA 5-15R FEATURES & SPECIFICATIONS High Voltage No Locking Plug No Antibacterial No Angled Plug No Coiled Power Cord No STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL Listed 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P002-002 价格&库存
很抱歉,暂时无法提供与“P002-002”相匹配的价格&库存,您可以联系我们找货
P002-002
    • 1+42.85377
    库存:6
