1000 Eaton Boulevard
Cleveland, OH 44122
United States
NEMA 5-15R to C14 Computer AC Power Cable 10A, 125V, 18 AWG, 2 ft. (0.61 m), Black
MODEL NUMBER: P002-002-10A
Highlights
Recommended for powering
computers, printers and other
peripherals
2-ft. (0.61 m) length allows
flexibility in placing devices,
while avoiding cable clutter
Ideal replacement for worn-out
or missing NEMA 5-15R to C14
extension cord
Can connect a C13 peripheral to
a PC's switched source to save
energy
Applications
Computer AC power cable allows you to connect your PC or other device with a NEMA 5-15P plug to a
PDU or UPS with a C13 power outlet.
Features
Computer AC Power Cable Connects Computers, Monitors and Other EquipmentThis computer AC
power cable is designed for low-voltage data center, server room or home/office applications. This NEMA
5-15R to C14 cord converts a NEMA 5-15P plug into a C14 connector. You can use it to connect a
computer, monitor, printer or other device with a NEMA 5-15P plug to a surge protector, UPS system or
PDU with C13 power outlets. You can also connect your C13 printer or monitor to a switched source on
your PC, allowing you to turn both devices on and off at the same time. The 2-ft. (0.61 m) length helps
reduce cable clutter.
Specifications
OVERVIEW
UPC Code
037332180384
Device Compatibility
Computer; Monitor/HDTV; Printer; UPS; PDU; Server
Country/Region
North America
INPUT
Maximum Input Amps
10
Voltage Compatibility (VAC)
125
PHYSICAL
1/3
Connect devices like computers,
printers and monitors to a PDU
up to 2-ft. (0.61 m) away in your
workstation
Extend an existing power
connection up to 2-ft. (0.61 m) to
more easily place a device or
reach a power source
Provide a high-quality
replacement for a worn-out or
missing power cord
Power your monitor through a
switched source on your PC,
thus freeing up an outlet on your
surge protector or PDU
Package Includes
P002-002-10A NEMA 5-15R to
C14 Computer AC Power Cable,
2-ft. (0.61 m), Black
Cleveland, OH 44122
United States
Plug Color
Black
Cable Jacket Color
Black
Cable Jacket Material
PVC
Cable Jacket Rating
FT2
Power Cord Jacket Type
SJT
Cable Outer Diameter (OD)
7.7mm
Number of Conductors
3
Wire Gauge (AWG)
18
Wire Gauge (OD - mm²)
0.82
Cable Length (ft.)
2
Cable Length (m)
0.61
Shipping Dimensions (hwd / in.)
10.00 x 7.70 x 0.10
Shipping Dimensions (hwd / cm)
25.40 x 19.56 x 0.25
Shipping Weight (lbs.)
0.26
Shipping Weight (kg)
0.12
ENVIRONMENTAL
Operating Temperature Range
-4 TO 140 F (- 20° TO 60°C)
Storage Temperature Range
Operating Humidity Range
20-80% RH
Storage Humidity Range
20-80% RH
CONNECTIONS
Side A - Connector 1
IEC-320-C14
Side B - Connector 1
NEMA 5-15R
FEATURES & SPECIFICATIONS
High Voltage
No
Locking Plug
No
Antibacterial
No
Angled Plug
No
Coiled Power Cord
No
STANDARDS & COMPLIANCE
Product Certifications
cUL Listed; UL Listed
Product Compliance
RoHS
2/3
Cleveland, OH 44122
United States
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“P002-002-10A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+37.47735
- 10+33.95728
