1000 Eaton Boulevard
Cleveland, OH 44122
United States
Power Cord Adapter, NEMA L5-20P to NEMA 520R - Heavy-Duty, 20A, 125V, 12 AWG, 6-in.
(15.24 cm), Black
Highlights
Recommended for powering
computers, servers and other
network devices
Heavy-duty cord replaces or
upgrades standard power cord
provided by manufacturer
Thick 12 AWG wire gauge
manages high power levels
required for larger equipment
Locking connector maintains
secure link to avoid loss of
power and costly downtime
MODEL NUMBER: P046-06N
Applications
Connect devices like computers,
servers and monitors to a PDU
in your data center
Update or replace the standard
power cord provided by a
device’s original manufacturer
Package Includes
Heavy-duty extension cord connects your computer or other device with a NEMA 5-20P plug to a NEMA
L5-20R outlet.
Features
Heavy-Duty Extension Cable for Network Devices That Require a Heavy-Gauge ConnectionThis sixinch cord features 12 AWG wire suitable for high power connections, making it a reliable solution for large
server applications that require a higher-rated, heavier-gauge cable. It can be used to connect a
computer, server or other device with a NEMA 5-20P plug to a wall outlet, PDU or UPS system with a
NEMA L5-20R outlet. The short length helps reduce cable clutter.
Locking Connector Helps Prevent Accidental Disconnection and Expensive DowntimeHaving a
cable come loose accidentally can mean the loss of power and costly downtime. The locking connector
helps you avoid such danger, protecting critical equipment by maintaining a secure link without failure.
The locking cable is also invaluable when moving equipment in a rack or removing equipment from tight
areas, ensuring the power cord always stays connected.
Specifications
OVERVIEW
UPC Code
037332158321
Device Compatibility
Computer; Monitor/HDTV; Server; UPS; PDU
Country/Region
North America
INPUT
Maximum Input Amps
Voltage Compatibility (VAC)
125
1/3
P046-06N L5-20P to 5-20R
Heavy-Duty Extension Cord, 6
in., Black
Cleveland, OH 44122
United States
PHYSICAL
Plug Color
Black
Cable Jacket Color
Black
Cable Jacket Material
PVC
Cable Jacket Rating
FT2
Power Cord Jacket Type
SJT
Cable Outer Diameter (OD)
11mm
Number of Conductors
3
Wire Gauge (AWG)
12
Wire Gauge (OD - mm²)
3.31
Cable Length (ft.)
0.5
Cable Length (m)
0.15
Cable Length (cm)
15.24
Shipping Dimensions (hwd / in.)
10.00 x 7.10 x 0.50
Shipping Dimensions (hwd / cm)
25.40 x 18.03 x 1.27
Shipping Weight (lbs.)
0.40
Shipping Weight (kg)
0.18
ENVIRONMENTAL
Operating Temperature Range
-4 TO 140 F (- 20° TO 60°C)
Storage Temperature Range
Operating Humidity Range
20-80% RH
Storage Humidity Range
20-80% RH
CONNECTIONS
Side A - Connector 1
NEMA L5-20P
Side B - Connector 1
NEMA 5-20R
FEATURES & SPECIFICATIONS
High Voltage
Yes
Locking Plug
No
Antibacterial
No
Angled Plug
No
Coiled Power Cord
No
STANDARDS & COMPLIANCE
2/3
Cleveland, OH 44122
United States
Product Certifications
cUL Listed; UL Listed
Product Compliance
RoHS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“P046-06N”相匹配的价格&库存,您可以联系我们找货
