FX1-216P-1.27DSA(71) 数据手册
1.27mm Pitch Connector
FX1 Series
Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
DIN duplex density mount has been achieved.
(DIN 96 contacts and FX1 192 (96x2)
Photo 1
Figure 2
Sequence Structure
(Pin contact sequence)
The alignment of the mating area in 4-row allows to duplex the
number of contacts in the nearly equivalent mount square as for
the conventional DIN connector.(Refer to photo (1).)
C2
C1
B2
2. High Current and High Voltage
2.5
1.8
Considering insertion/extraction in active power mode and
maintenance on the end user side, the FX1 series is designed in
a mechanism that can afford the time different contact at two
steps. (For details, refer to Figure (2) as shown on the right.)
(Effective contact length)
10
2.8
A2
A1
2.2
1
3. Sequence Structure
(Contact start position)
B1
Two-thirds of total contact numbers are used for half pitch
signaling contact, while the other one-third thereof is used for the
power ground contact. Power ground contact corresponds to
high current (1A) and high voltage (250V).
24.4
1. High density and space saved-DIN Duplex Mount Achieved
13.69
■Features
C2 C1 B2 B1 A2 A1
4. Mis-insertion Prevent
Provide the insertion guide on both ends of connector, and widen
an inductive area in order to prevent mis-insertion.
*FX1 Series (2 step sequence)
1
Row B
2
Row A, row C
Setting row B to ground, if active cable insertion and
extraction are performed as power supply, arc will
occur between contact and contact. The row B
contact structure is constructed to separate arc
occurrence point a and normal contact point b, and
minimizes affects on the contact.
A78
FX1 Series●1.27mm Pitch Connector
■Product Specifications
Current rating
Voltage rating
0.5A Signal Contact:
125V AC Operating Temperature Range-55 to 85ç (Note 1) Storage Temperature Range -10 to +60ç(Note 2)
Rating Signal Contact:
Power Supply Contact: 1A Power Supply Contact: 250V AC Operating Humidity Range -40 to 80%
Operating Humidity Range -40 to 70% (Note 2)
Item
Specification
1. Insulation Resistance
1000M ohms min.
2. Withstanding Voltage
No flashover or insulation breakdown.
Condition
250V DC
1 minute
Signal contact
Power supply contact
300V AC
600V AC
3. Contact Resistance
60m ohms max. (conductor resistance included)
100mA
4. Vibration
No electrical discontinuity of 1μs or more
Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions.
5. Humidity (Steady state)
Contact resistance: 70m ohms max.
Insulation resistance: 1000M ohms min.
96 hours at temperature of 40ç and humidity of 90% to 95%
6. Temperature Cycle
(-55ç: 30 minutes→15- to 35ç: 5 minutes max.→
(-85ç: 30 minutes→15- to 35ç: 5 minutes max.) 5 cycles
7. Durability (Mating/un-mating) Contact resistance: 70 m ohms max.
500 cycles
Note 1: Includes temperature rise caused by current flow.
Note 2: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and
Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation.
Note 3: Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for
a specific part number shown.
■Material
●FX1 Series
Parts
Insulator
Contact
Material
Header
PPS
Receptacle
PPS/ PTB
Straight header
Right angle header
Brass
Phosphor bronze
Receptacle
Phosphor bronze
Prefixed pin
Phosphor bronze
Finish
Remarks
Black
UL94V-0
Contact area:Tin plated
Lead area:Tin plated
Tin plated
________
________
A79
■Ordering Information
●FX1 Series
FX1
- 192 P - 1.27 DSA L
q
q Series Name
w
: FX1
w Number of contacts: 144, 192, 216
e Connector type : P-header
: S-receptacle
e
r
t
y
r Contact pitch: 1.27mm
t Contact type: DS : Right angle
DSA : Straight
y L: Board prefixed pin
Note: The cleaning type only is applied on the header side to FX1 series.
BApplication Pattern
A80
FX1 Series
■Receptacle : Right Angle Type
BPCB mounting pattern Applicable board thickness t=1.6mm
Unit: mm
Part Number
CL No.
FX1-144S-1.27DS(71)
571-0003-7-71
FX1-144S-1.27DSL(71)
571-0053-5-71
FX1-192S-1.27DS(71)
571-0004-0-71
FX1-192S-1.27DSL(71)
571-0054-8-71
FX1-216S-1.27DS(71)
571-0005-2-71
FX1-216S-1.27DSL(71)
571-0055-0-71
Number of Contacts
A
B
C
144
73.29
68.08
59.69
192
93.61
88.4
80.01
216
103.77
98.56
90.17
D
____
67.31
____
RoHS
YES
87.63
____
97.79
A81
■Header : Straight Type
Unit: mm
Part Number
A82
CL No.
FX1-144P-1.27DSA(71)
571-0303-0-71
FX1-144P-1.27DSAL(71)
571-0353-9-71
FX1-192P-1.27DSA(71)
571-0304-3-71
FX1-192P-1.27DSAL(71)
571-0354-1-71
571-0305-6-71
FX1-216P-1.27DSAL(71)
571-0355-4-71
Number of Contacts
A
B
144
73.29
59.69
192
93.61
80.01
216
103.77
90.17
C
____
69.85
____
90.17
____
100.33
RoHS
YES
■Header : Right Angle Type
Part Number
CL No.
FX1-144P-1.27DS(71)
571-0203-6-71
FX1-144P-1.27DSL(71)
571-0253-4-71
Number of Contacts
RoHS
144
YES
A83
BPrecautions
1. Soldering
(1)In the case of manual soldering, complete services under the condition of soldering iron bit temperature below 360ç for
5 seconds max. Please be sure to coat the contacts with solder so that no force is given.
(2)In the case of dip soldering bath, complete service under the condition of soldering iron bit temperature below 260ç for
10 seconds max.
2. Prefixed function
If the prefixed function is required, please use to the board prefixed pin type.
A84
FX1-216P-1.27DSA(71) 价格&库存
很抱歉,暂时无法提供与“FX1-216P-1.27DSA(71)”相匹配的价格&库存,您可以联系我们找货
