FLYER
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
TM-DS
Series
FCC Standard, THT Type Modular Jack Connector
Features
1 Complies with US FCC Standard requirements
2 Space-saving 8 pin x 4-port type available
3 Compact with a mounted height of 11.7mm from
the board surface, 14mm width and 17mm depth
4 Shielded type uses the same connector housing,
making board pattern changes unnecessary
(When switching to the shielded type is required make sure
to use the pattern for the shielded type)
Application Examples
●Industrial PC, LAN, HUB, Interphone,
Computer, etc.
Mating Port Size and Contact Count (6pos. Size)
The relationship between the jack connector mating port
size and the number of contacts is shown below.
Model 66
Model 64
Model 62
Models 64 and 62 are obtained by
removing 1 pin and 2 pins, respectively,
from both sides of model 66.
Please check the drawing for details.
Specifications
Rated Current
0.5A
Rated Voltage
125V AC
Operating
Temperature
-55 to +85°C*
Contact
Resistance
230mΩ Max. (100 mA DC)
Withstanding
Voltage
500V AC for 1 min.
Insulation
Resistance
100MΩ Min. (100V DC)
Mating
Durability
200 times
*Includes the temperature rise due to current flow.
- RoHS compliant
MKT-E-21071F Issued: May 10, 2022 © 2022 HIROSE ELECTRIC CO., LTD. All rights reserved. Specifications herein are subject to change without notice. Contact Hirose for latest specifications, drawings, or availabilities.
很抱歉,暂时无法提供与“TM2REA-1212”相匹配的价格&库存,您可以联系我们找货
