TM3RA1X-64(50)
TM3RA1X-64(50)
    HRS(广濑)
TM3RA1X-64(50) 数据手册
FLYER Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. TM-DSA Series FCC Standard, Straight THT Type Modular Jack Connector Features 1 Complies with US FCC Standard requirements 2 Solder mounted perpendicular to PCB 3 Gold plated contact has excellent environmental durability. The insulation is made of flame retardant (UL-94V-0) material. 4 Port types available in 6 pins and 1 to 4 ports Application Examples ●Industrial PC, LAN, HUB, Interphone, Computer, etc. Specifications Mating Port Size and Contact Count (6pos. Size) The relationship between the jack connector mating port size and the number of contacts is shown below. Model 66 Model 64 Model 62 Models 64 and 62 are obtained by removing 1 pin and 2 pins, respectively, from both sides of model 66. Please check the drawing for details. Rated Current 0.5A Rated Voltage 125V AC Operating Temperature -55 to +85°C* Contact Resistance 230mΩ Max. (100 mA DC) Withstanding Voltage 500V AC for 1 min. Insulation Resistance 100MΩ Min. (100V DC) Mating Durability 200 times *Includes the temperature rise due to current flow. - RoHS compliant MKT-E-21072F Issued: Jun. 16, 2022 © 2022 HIROSE ELECTRIC CO., LTD. All rights reserved. Specifications herein are subject to change without notice. Contact Hirose for latest specifications, drawings, or availabilities.
TM3RA1X-64(50) 价格&库存
很抱歉,暂时无法提供与“TM3RA1X-64(50)”相匹配的价格&库存,您可以联系我们找货
