1000 Eaton Boulevard
Cleveland, OH 44122
United States
8-Port 10/100/1000 Mbps Desktop Gigabit
Ethernet Unmanaged Switch
MODEL NUMBER: NG8P
Highlights
8 auto-negotiable 10/100/1000
Mbps RJ45 ports
Supports auto MDI/MDIX crossover function
Consumes very little input
power—just 1W
2 Gbps switching capacity per
port with full duplex
Plug and play with no
configuration required
Package Includes
Energy-efficient unmanaged switch sets up in seconds with no configuration required. Provides a Gigabit
network connection for multiple devices. Ideal for home or small offices, workgroups and creative
production environments.
Description
The NG8P 8-Port 10/100/1000 Mbps Desktop Gigabit Ethernet Unmanaged Switch adds 10/100/1000
Mbps Ethernet capacity to your home office, small office, workgroup or creative production environment.
Share large bandwidth-intensive files, such as CAD drawings and videos, at Gigabit speeds, improving
efficiency and cutting costly downtime.
This desktop switch features eight twisted-pair RJ45 Gigabit Ethernet ports that support auto-negotiable
10/100/1000 Mbps and auto MDI/MDIX cross-over detection functions for convenient plug-and-play
capability. No configuration is required, so you can have your Gigabit network up and running
immediately. Easy-to-read LEDs indicate connection and activity status for each port. IEEE 802.3x flow
control allows smooth transmission of large files.
The NG8P supports IEEE 802.3az Energy Efficient Ethernet standards by putting unused ports into a lowpower state without interrupting network connections. It consumes very little input power—just a single
watt. The detachable five-foot input cord with NEMA 1-15P plug connects to a protected UPS, generator
or mains input AC source.
Features
Unmanaged Network Switch for Home/Small Offices or Workgroups8 twisted-pair RJ45 Gigabit
Ethernet portsAuto-negotiable 10/100/1000 MbpsAutomatic MDI/MDIX cross-over detection16 Gbps
switching capacity (2 Gbps per port with full duplex)Easy-to-read LEDs indicate connection and activity
status for each portSupports 9k jumbo framesMAC address table capacity of up to 4k addresses with
automatic learning and agingSupports 802.3x flow control (full duplex) and back pressure (half duplex)
Compliant with IEEE 802.3az Energy Efficient Ethernet StandardsAutomatically shifts unused ports to
low-power state without interrupting network connectionConsumes very little input power—just 1WAlso
meets IEEE 802.3ab, 802.3i, 802.3u and 802.3 standards
Durable HousingFanless design for silent operationDetachable 5 ft. AC power cord with NEMA 1-15P
plugPlug-and-play—no configuration necessary
Works with the Most Popular Web Browsers
The NG8P is browser-based and works independently from the connected computer's operating system.
Because switch compatibility is based on common hardware standards, rather than system software
dependencies, the NG8P accommodates most platforms. Preferred web browsers include Google
1/4
Unmanaged Switch
External power supply w/NEMA
1-15P plug and 5 ft. cord
Owner’s manual
Cleveland, OH 44122
United States
Chrome (on both Windows and macOS) and Microsoft Edge (Windows only).
Specifications
OVERVIEW
UPC Code
037332194749
Product Type
Unmanaged Switch
INPUT
Electrical Consumption (Max)
1W
Nominal Input Voltage Description
Included 5V DC output power adapter accepts 100-240V AC nominal input
Plug Type
Power adapter includes NEMA 1-15P non-polarized input plug
Voltage Compatibility (VAC)
100-240
Input Plug Type
NEMA 1-15P
Input Cord Length (ft.)
5
Input Cord Length (m)
1.52
POWER
Power Consumption (Watts)
1
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
Power LED (Green for Power On); One LED per RJ45 port (Green, LEDs flash to indicate port activity)
PHYSICAL
Primary Form Factor
Desktop
Color
Black
Material of Construction
Plastic
Form Factors Supported
Desktop
Shipping Dimensions (hwd / in.)
3.10 x 3.00 x 5.10
Shipping Dimensions (hwd / cm)
7.87 x 7.62 x 12.95
Shipping Weight (lbs.)
0.53
Shipping Weight (kg)
0.24
Unit Dimensions (hwd / in.)
0.870 x 2.560 x 4.920
Unit Dimensions (hwd / cm)
2.2 x 12.5 x 6.5
Unit Weight (lbs.)
.25
Unit Weight (kg)
0.11
Rack Units
Cleveland, OH 44122
United States
ENVIRONMENTAL
Storage Temperature Range
14 to 158F (-10 to 70C)
Relative Humidity
10 to 90% (non-condensing)
Operating Temperature
32 to 104F (0 to 40C)
COMMUNICATIONS
Network Compatibility
1 Gbps (Gigabit)
Network Compatibility Details
Auto-negotiable
Switching Capacity
16 Gbps
Switching Capacity Details
CONNECTIONS
Number of Ports
8
RJ45 Ports
8
RJ45 Ports Detail
8x 10/100/1000BASE-T
SFP Uplink Ports
PoE Supported Ports
Network Switch Ports
(8) 10/100/1000 (RJ45)
FEATURES & SPECIFICATIONS
Fans (Type/Quantity)
Fanless
MAC Addresses
4000
Jumbo Frames
9000
Console Port
No
MAC Auto Learning
No
RMON
No
SNMP
No
Storm Control
No
DHCP Snooping
No
Auto MDI/MDIX Crossover Detection
Yes
STANDARDS & COMPLIANCE
Product Certifications
EN 55022; EN 55024; EN 60950-1; NOM (Mexico)
Product Compliance
RoHS; IEEE 802.3 Auto-Negotiation; IEEE 802.3ab 1000Base-T; IEEE 802.3az (Energy Efficient Ethernet); IEEE
802.3i 10Base-T; IEEE 802.3u 100Base-TX/FX; IEEE 802.3x Flow Control; FCC Part 15 Class B (USA)
WARRANTY & SUPPORT
3/4
Cleveland, OH 44122
United States
Product Warranty Period
(Worldwide)
5-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“NG8P”相匹配的价格&库存,您可以联系我们找货
