1000 Eaton Boulevard
Cleveland, OH 44122
United States
4-Port HDMI Switch with Remote Control - 4K 60
Hz, UHD, 4:4:4, HDR, 3D
MODEL NUMBER: B119-004-UHD
Highlights
Switch between 4 source
devices with included remote for
ultimate convenience
Supports UHD resolutions up to
4K @ 60 Hz (4:4:4) for crystalclear video
Supports High Dynamic Range
(HDR) for richer contrast and
expanded color accuracy
Delivers full, rich DTS-HD,
Dolby TrueHD and 7.1-channel
surround sound audio
Plug-and-play operation with no
software required for easy,
immediate installation
Applications
Connects 4 HDMI audio/video sources to one 4K HDMI TV, monitor or projector, and allows you to switch
between them.
Features
4-Port HDMI Switch with Remote Connects 4 Sources to One 4K HDMI DisplayAn excellent addition
to your home theater, the B119-004-UHD allows you to connect four separate HDMI audio/video sources
to your 4K television, projector or monitor’s HDMI input and switch between them. For instance, connect a
cable box, Blu-ray player, Xbox and audio receiver to your 4K HDTV, and use the manual pushbutton or
included remote control to switch manually from one input to another.
Transmits Crystal-Clear 4K Video with HDR and 4:4:4 ColorThis four-port HDMI switch supports Ultra
HD 4K video resolutions at 60 Hz, as specified in HDMI 2.0, as well as 48-bit True Color and HDR video,
providing a wide range of vibrant colors with richer contrast, brighter whites and deeper blacks that pop on
your 4K display. HDCP 2.2 compliance allows you to stream 4K Amazon and Netflix content with no
complications. This adapter supports 4:4:4 chroma subsampling for top-level PC gaming or using your
HDTV as a PC monitor. DTS-HD, Dolby TrueHD and 7.1-channel surround sound ensure your ears
receive the same treat as your eyes.
Ready to Use Right from the Package, So You Can Plug and Play ImmediatelyThe compact metal
switch requires no extra software to download and install. Connect your devices to the HDMI ports with
user-supplied HDMI cables (such as Tripp Lite’s P569-Series), and plug the included external power
supply into an AC power source. A red LED indicates the unit is receiving power, and green LEDs indicate
connected HDMI inputs. When the currently used source is powered off, the unit automatically switches to
the next powered-on source.
Specifications
OVERVIEW
UPC Code
037332191342
1/4
Switch between your cable box,
Blu-ray player, video game
console, Roku or other HDMI
sources in your home theater
Connect multiple desktop
computers and laptops to one
monitor to save desk space
Monitor the premises with as
many as 4 security cameras
connected to a single display
Create up to 4 different digital
signage messages to appear at
various times on a 4K HDMI
display
System Requirements
Up to 4 source devices with
HDMI output
Display device with HDMI input
Package Includes
B119-004-UHD 4-Port HDMI
Switch
Remote control
External power supply (Input:
100–240V, 50/60 Hz, 0.3A;
Output: 5V 1A)
Owner’s manual
Cleveland, OH 44122
United States
Technology
HDMI; IR
VIDEO
Max Supported Video Resolution
4K @ 60Hz 4:4:4
Max Supported Color Depth
48-bit Deep Color
HDR Support
Yes
3D Video Supported
Yes
AUDIO
Audio Specification
DTS-HD, Dolby TrueHD and 7.1 Channel Surround Sound
INPUT
Voltage Compatibility (VAC)
100; 110; 120; 125; 127; 200; 208; 220; 230; 240
Bus Powered
No
Product Length (in.)
4.84
Product Length (ft.)
0.4
POWER
Power Source Type
AC Adapter
External Power Supply Plug(s)
NEMA 1-15P North America; CEE 7/16 Schuko; BS 1363 UK; AS/NZS 3112 Australia
External Power Supply Input Specs
(V / Hz / A)
100-240V / 50/60Hz / 0.3A
External Power Supply Output
Specs (V / A)
5V / 1A
External Power Supply Cord Length
(ft.)
5.0
(m.)
1.5
AC Adapter
Input: 100-240V, 50/60Hz, 0.35A; Output: 5V, 2A, 4 ft.
DC Barrel Plug
OD: 5.5 x 2.1 x 10mm, Positive Pin, Negative Sleeve
Power Consumption (Watts)
1.75
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
Red (Power), Green (1, 2, 3, 4)
PHYSICAL
Color
Black
Material of Construction
Steel
Rackmountable
No
Shipping Dimensions (hwd / in.)
3.00 x 5.20 x 7.10
2/4
Cleveland, OH 44122
United States
Shipping Dimensions (hwd / cm)
7.62 x 13.21 x 18.03
Shipping Weight (lbs.)
1.00
Shipping Weight (kg)
0.45
Unit Dimensions (hwd / in.)
0.800 x 4.800 x 2.000
Unit Packaging Type
Box
Unit Weight (lbs.)
0.33
Unit Weight (kg)
0.15
ENVIRONMENTAL
Operating Temperature Range
32 to 104 °F (0 to 40 °C)
Storage Temperature Range
14 to 176 °F (-10 to 80 °C)
BTUs
6 BTU/Hr
Operating Humidity Range
10% to 85 % RH, Non-Condensing
Storage Humidity Range
5% to 90% RH, Non-Condensing
COMMUNICATIONS
Port Control
Push Buttons
EDID Compatible
Yes
Consumer Electronics Control (CEC)
Supported
Yes
CONNECTIONS
Number of Ports
4
Side A - Connector 1
(4) HDMI (FEMALE)
Side B - Connector 1
HDMI (FEMALE)
FEATURES & SPECIFICATIONS
Port Selection
Pushbutton; Remote Selector
HDCP Specification
2.2
Driver Required
No
STANDARDS & COMPLIANCE
External Power Supply Certifications
CE; ETL; UL
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
3/4
Cleveland, OH 44122
United States
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
