1000 Eaton Boulevard
Cleveland, OH 44122
United States
VGA over Cat5/Cat6 Extender, Wallplate
Receiver, 1920x1440 at 60Hz, Up to 1000-ft., TAA
Highlights
Works with a B13 or B13 local
transmitter unit to extend a 1920
x 1440 (60Hz) video signal up to
500 ft., or a 1024 x 768 (60Hz)
video signal up to 1,000 ft.
24Awg, Solid Wire Cat5e/6
cable, such as Tripp Lite's
N022-01K-GY (Cat5) and N22201K-GY (Cat6), is required to
achieve maximum distance and
resolution
For optimal image quality
between 500 and 1,000 ft., use
Zero-Skew cable, such as Tripp
Lite P524-01K
RJ45 type wallplate allows you
to use standard patch cable,
eliminating the need for a 110
punchdown connection
Compliant with the Federal
Trade Agreements Act (TAA) for
GSA Schedule purchases
MODEL NUMBER: B132-100-WP-1
System Requirements
Description
Tripp Lite's B132-100-WP-1 works with a B132-002-2 or B132-004-2 local transmitter unit to extend a
1920 x 1440 (60Hz) video signal up to 500 ft., or a 1024 x 768 (60Hz) video signal up to 1,000 ft.. 24Awg,
Solid Wire Cat5e/6 cable, such as Tripp Lite's N022-01K-GY (Cat5) and N222-01K-GY (Cat6), is required
Package Includes
Extender remote (Receiver)
wallplate
Mini-Screwdriver for EQ/Gain
adjustment
Wallplate screws
External Power Supply with
NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.5A; Output:
5V, 2A, 5 ft.)
Owner’s Manual
to achieve maximum distance and resolution. For optimal image quality between 500 and 1,000 ft., use
Zero-Skew cable, such as Tripp Lite P524-01K. Features built-in Equalization and Gain controls to adjust
the video image. RJ45 type wallplate allows you to use standard patch cable, eliminating the need for a
110 punchdown connection. Ideal for digital signage situations, such as retail, schools, churches, etc.
Features
Works with a B13 or B13 local transmitter unit to extend a 1920 x 1440 (60Hz) video signal up to 500 ft.,
24Awg, Solid Wire Cat5e/6 cable, such as Tripp Lite's N022-01K-GY (Cat5) and N222-01K-GY (Cat6),
is required to achieve maximum distance and resolution
For optimal image quality between 500 and 1,000 ft., use Zero-Skew cable, such as Tripp Lite P52401K
Features built-in Equalization and Gain controls to adjust the video image
RJ45 type wallplate allows you to use standard patch cable, eliminating the need for a 110 punchdown
connection
Ideal for digital signage situations, such as retail, schools, churches, etc..
Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases
1 year limited waranty.
Specifications
OVERVIEW
1/3
Cleveland, OH 44122
United States
UPC Code
037332160072
Product Type
Cat5/Cat6 Receiver
Technology
VGA/SVGA
VIDEO
Max 720P Range (ft)
500
Max 1080P Range (ft)
500
Max 1920 x 1200 Range (ft)
500
Maximum Signal Range (ft)
1000
Maximum Signal Range (m)
305
POWER
AC Adapter
Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5 ft.
PHYSICAL
Color
White
Shipping Dimensions (hwd / in.)
2.20 x 6.20 x 7.20
Shipping Dimensions (hwd / cm)
5.59 x 15.75 x 18.29
Shipping Weight (lbs.)
0.80
Shipping Weight (kg)
0.36
Unit Dimensions (hwd / in.)
4.500 x 2.800 x 0.000
Unit Dimensions (hwd / cm)
11.43 x 6.99 x 2.54
Unit Weight (lbs.)
0.4
Unit Weight (kg)
0.18
COMMUNICATIONS
Max 1024 x 768 Range (ft)
1000
Max 480P Range (ft)
1000
Max 1440 x 900 Range (ft)
500
Max 1080i Range (ft)
500
Max 1920 x 1440 Range (ft)
500
Max 480i Range (ft)
1000
Max 640 x 480 Range (ft)
1000
Max 800 x 600 Range (ft)
1000
Max 1600 x 1200 Range (ft)
500
CONNECTIONS
2/3
Cleveland, OH 44122
United States
Number of Ports
1
Side A - Connector 1
RJ45 (FEMALE)
Side B - Connector 1
HD15 (FEMALE)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
