1000 Eaton Boulevard
Cleveland, OH 44122
United States
HDMI over Dual Cat5/6 Extender Kit, In-Line
Transmitter/Receiver for Video/Audio, IR, Up to
100 ft. (30 m), TAA
Highlights
Supports high-definition video
resolutions up to 1080p (@ 60
Hz)
Supports 7.1-channel surround
sound, DTS-HD and Dolby
TrueHD
Supports EDID passthrough,
HDCP and 3D video
USB Micro-B cable supplies
power to either unit
Plug and play—no software,
drivers or external power
supplies
MODEL NUMBER: B125-101-60-IRU
System Requirements
Computer, Blu-ray player or
other source with HDMI port
Display with HDMI port
NOTE
Transmitter and receiver work in tandem to extend HDMI audio/video and IR control signals via Cat5/6
cable to a display up to 100 ft. Ideal for digital signs, schools, retail settings and trade show presentations.
Features
Extends HDMI Video/Audio and IR Control Signals to an HDMI DisplayExtends an HD 1920 x 1080
(1080p) signal up to 100-ft. (30.5 m) via 24 AWG solid-wire Cat5e/6 cableIdeal for digital signs, trade
shows, presentations, classrooms, churches and retail settingsTransmitter and receiver connect with dual
Cat5e/6 cables (for best results, use Tripp Lite's N202-Series)Supports 7.1-channel surround sound, DTSHD and Dolby TrueHD audioSupports EDID pass-through and HDCPIR remote control functionality lets
you control Blu-ray player with its remote while standing at remote monitor
Easy to Set Up and UsePlug-and-play engineering—no software, drivers or external power
supplyPowered via included USB Micro-B cableUnits connect quickly to source and display with HDMI
cables (such as Tripp Lite's P568-Series)LEDs indicate when units are receiving power and a signal from
the sourceWorks with all operating systems and HDMI sources
TAA CompliantCompliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases
Specifications
OVERVIEW
UPC Code
037332190468
Product Type
Extender Kit
Technology
HDMI; IR; Cat5/5e; Cat6
VIDEO
Video Input
HDMI (FEMALE)
1/4
Package Includes
Transmitter unit
Receiver unit
IR-TX cable, 5-ft. (1.52 m)
IR-RX cable, 5-ft. (1.52 m)
USB Micro-B cable, 3-ft. (0.91
m)
Owner's manual
Cleveland, OH 44122
United States
Video Output
HDMI (FEMALE)
Max Supported Video Resolution
1920x1080 (1080p @ 60Hz)
Max 720P Range (ft)
100
Max 1080P Range (ft)
100
Max 1280 x 720 (720p) Range (ft)
100
Max 1920 x 1080 (1080p) Range (ft)
100
Transmitter Video Input
HDMI
Transmitter - Number of Video
Outputs
1
Receiver/Transceiver Video Output
HDMI
Receiver - Number of Video Outputs
1
Recommended Cabling
N202-Series Cat6 Patch Cable
Max Supported Color Depth
24-bit True Color
HDR Support
No
3D Video Supported
Yes
Chroma Sub Sampling
4:4:4
Maximum Signal Range (ft)
100
Maximum Signal Range (m)
30
Maximum Signal Range Details
Extend a 1080p @ 60Hz HDMI audio/video and IR control signals via Cat5/6 cable to a display up to 100 ft.
AUDIO
Audio Input
HDMI
Audio Output
HDMI
Audio Specification
Pass-through audio
INPUT
Bus Powered
No
POWER
Power Source Type
USB
Power Source
Transmitter or Receiver (Included)
Power Over Cable (PoC) Support
No
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
Green (Connected), Orange (Activity)
PHYSICAL
Color
Black
2/4
Cleveland, OH 44122
United States
Number of Displays
1
Form Factor/Mounting Options
Box
Receiver Unit Dimensions (hwd / in.)
2.4 x 0.94 x 2.04
Receiver Unit Weight (lbs.)
0.05
Shipping Dimensions (hwd / in.)
7.87 x 5.59 x 1.73
Shipping Dimensions (hwd / cm)
19.99 x 14.20 x 4.39
Shipping Weight (lbs.)
0.62
Shipping Weight (kg)
0.28
Transmitter Unit Dimensions (hwd /
in.)
2.4 x 0.94 x 2.04
Transmitter Unit Weight (lbs.)
0.05
0.000 x 0.000 x 0.000
Unit Packaging Type
Box
Housing
Plastic
ENVIRONMENTAL
Operating Temperature Range
32 to 104 °F (0 to 40 °C)
Storage Temperature Range
5 to 122 °F (-15 to 50 °C)
Relative Humidity
0% to 85% RH, Non-Condensing
COMMUNICATIONS
Max 1024 x 768 Range (ft)
100
Max 480P Range (ft)
100
Max 1440 x 900 Range (ft)
100
Max 1080i Range (ft)
100
Max 480i Range (ft)
100
Max 640 x 480 Range (ft)
100
Max 800 x 600 Range (ft)
100
Max 1600 x 1200 Range (ft)
100
EDID Compatible
Yes
IR Remote Extension Support
Yes
RS-232 Serial Extension Support
No
Consumer Electronics Control (CEC)
Supported
Yes
USB Extension Support
No
CONNECTIONS
3/4
Cleveland, OH 44122
United States
Number of Ports
1
Side A - Connector 1
HDMI (FEMALE)
Side A - Connector 2
(2) RJ45 (FEMALE)
Side A - Connector 3
MICRO-USB B (FEMALE)
Side B - Connector 1
HDMI (FEMALE)
Side B - Connector 2
(2) RJ45 (FEMALE)
Side B - Connector 3
FEATURES & SPECIFICATIONS
HDCP Specification
1.4
Driver Required
No
10/100 Ethernet Extension Support
No
Built-In Equalizer
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“B125-101-60-IRU”相匹配的价格&库存,您可以联系我们找货
