1000 Eaton Boulevard
Cleveland, OH 44122
United States
2-Port DisplayPort to VGA Hub, DP1.2, TAA
Highlights
Supports video resolutions up to
1080p @ 60 Hz (1920 x 1080)
Included USB Micro-B cable
supplies power to unit
Works with all operating
systems
Compact enough for easy
carrying in backpack or laptop
bag
Plug and play—no software or
drivers required
MODEL NUMBER: B157-002-VGA
Package Includes
Converts and splits a DisplayPort video signal for display on two VGA monitors, projectors or televisions
at the same time. Ideal for offices, conference rooms, retail settings, trade shows and classrooms.
Description
The B157-002-VGA 2-Port DisplayPort to VGA Splitter converts and splits a DisplayPort video signal for
display on two VGA-enabled monitors, projectors or televisions at the same time. Ideal for offices,
conference rooms, retail settings, trade shows and classrooms, this compact splitter features a built-in
DisplayPort cable that connects to the source. It lets you use your existing VGA displays instead of buying
new DisplayPort monitors or docking stations.
The B157-002-VGA supports video resolutions up to 1080p @ 60 Hz (1920 x 1080), as well as HDCP,
EDID and DDC. Orange LEDs next to each output port indicate whether the splitter is powered on and
transmitting a signal to the connected displays. The splitter works with all operating systems and is small
enough to carry in your backpack or computer bag. Plug-and-play convenience means no software or
drivers are needed. An included USB Micro-B cable connects between the source and the splitter to
provide power, so no external power supply is required.
Features
Converts and Splits DisplayPort Signal to 2 VGA Displays SimultaneouslyIdeal for offices,
conference rooms, trade shows and classroomsBuilt-in DisplayPort cable connects to sourceIncluded
USB Micro-B cable supplies power to splitterSave money on new DisplayPort displays or docking stations
Top-Shelf PerformanceSupports video resolutions up to 1080p @ 60 Hz (1920 x 1080)Complies with
HDCP, EDID and DDCLEDs indicate whether splitter is powered on and transmitting signal to connected
displays
Easy to Use Almost AnywhereWorks with all operating systemsPlug and play—no software, drivers or
external power supply requiredCompact unit fits easily in backpack or computer bag
Specifications
OVERVIEW
UPC Code
037332191496
Technology
VGA/SVGA; DisplayPort
1/3
B157-002-VGA 2-Port
USB Micro-B cable, 3 ft.
Owner’s manual
Cleveland, OH 44122
United States
Host Connector
DISPLAYPORT (FEMALE)
VIDEO
Max Supported Video Resolution
Max Supported Color Depth
24-bit True Color
3D Video Supported
Yes
AUDIO
Audio Specification
2.0-channel surround sound audio
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
(x2) Orange (Monitor Signal)
PHYSICAL
Color
Black
Material of Construction
Metal
Wire Gauge (AWG)
28
Shipping Dimensions (hwd / in.)
1.70 x 7.90 x 5.60
Shipping Dimensions (hwd / cm)
4.32 x 20.07 x 14.22
Shipping Weight (lbs.)
0.60
Shipping Weight (kg)
0.27
Unit Dimensions (hwd / in.)
0.000 x 0.000 x 0.000
Unit Dimensions (hwd / cm)
2.55 x 6.15 x 7.6
Unit Dimensions (hwd / mm)
25.5 x 61.5 x 76
Unit Weight (lbs.)
0.154
Unit Weight (kg)
0.07
COMMUNICATIONS
EDID Compatible
Yes
CONNECTIONS
Number of Ports
2
Side A - Connector 1
DISPLAYPORT (MALE)
Side A - Connector 2
MICRO-USB B (FEMALE)
Side B - Connector 1
(2) HD15 (FEMALE)
Connector Plating
Nickel
FEATURES & SPECIFICATIONS
2/3
Cleveland, OH 44122
United States
Displayport Specification
1.2
HDCP Specification
1.3
MST Support
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“B157-002-VGA”相匹配的价格&库存,您可以联系我们找货
