1000 Eaton Boulevard
Cleveland, OH 44122
United States
2-Port VGA over Cat5/6 Splitter/Extender, BoxStyle Transmitter for Video, Up to 1000 ft. (305
m), TAA
MODEL NUMBER: B132-002-2
Highlights
Splits a single VGA signal into 2
EDID copy feature ensures
optimal display compatibility
Extends a 1920 x 1440 (60Hz)
signal up to 500 ft., or a 1024 x
768 (60Hz) signal up to 1,000
ft., when using 24Awg, Solid
Wire Cat5e/6 cable, such as
Tripp Lite's N022-01K-GY
(Cat5) and N222-01K-GY (Cat6)
Can further expand the range
and number of monitors by
adding B132-110A repeaters
For optimal image quality
between 500 and 1,000 ft., use
Zero-Skew cable, such as Tripp
Lite P524-01K
Compliant with the Federal
Trade Agreements Act (TAA) for
GSA Schedule purchases
System Requirements
Features
Package Includes
A B132-100-1 or B132-100-WP-1 remote receiver unit is required for each connected monitor
Extends a 1920 x 1440 (60Hz) signal up to 500 ft., or a 1024 x 768 (60Hz) signal up to 1,000 ft., when
using 24Awg, Solid Wire Cat5e/6 cable, such as Tripp Lite's N022-01K-GY (Cat5) and N222-01K-GY
(Cat6)
Can further expand the range and number of monitors by adding B132-110A repeaters
EDID copy feature ensures optimal display compatibility
Connect up to 4 remote units in a repeater chain (3 repeaters and 1 receiver), with a monitor at each
location
A 1920 x 1440 (60Hz) signal can be extended up to 500 ft. from the first repeater in the chain to the last
receiver. A 1024 x 768 (60Hz) signal can be extended up to 1,000 ft. from the first repeater in the chain
to the last receiver.
For optimal image quality between 500 and 1,000 ft., use Zero-Skew cable, such as Tripp Lite P52401K
Includes mounting hardware that allows unit to be wall mounted, rack mounted or pole mounted.
Ideal for digital signage situations, such as retail, schools, churches, etc.
Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases
Specifications
OVERVIEW
UPC Code
037332178404
Product Type
Transceiver
Technology
VGA/SVGA; Cat5/5e; Cat6
1/3
2 Port Extender/Splitter local
(Transmitter) unit
Mounting hardware
External Power Supply with
NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.5A; Output:
5V, 2A, 5 ft.)
Owner's Manual
Cleveland, OH 44122
United States
VIDEO
Max 720P Range (ft)
500
Max 1080P Range (ft)
500
HDR Support
No
3D Video Supported
No
Maximum Signal Range (ft)
1000
Maximum Signal Range (m)
305
INPUT
Bus Powered
No
POWER
Power Over Cable (PoC) Support
No
AC Adapter
Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5 ft.
PHYSICAL
Color
Black
Number of Displays
2
Form Factor/Mounting Options
Box
Shipping Dimensions (hwd / in.)
2.00 x 6.20 x 7.20
Shipping Dimensions (hwd / cm)
5.08 x 15.75 x 18.29
Shipping Weight (lbs.)
1.10
Shipping Weight (kg)
0.50
Unit Dimensions (hwd / in.)
1.000 x 2.500 x 3.625
Unit Dimensions (hwd / cm)
2.54 x 6.35 x 9.40
Unit Weight (lbs.)
0.45
Unit Weight (kg)
0.20
COMMUNICATIONS
Max 1024 x 768 Range (ft)
1000
Max 480P Range (ft)
1000
Max 1440 x 900 Range (ft)
500
Max 1080i Range (ft)
500
Max 1920 x 1440 Range (ft)
500
Max 480i Range (ft)
1000
Max 640 x 480 Range (ft)
1000
2/3
Cleveland, OH 44122
United States
Max 800 x 600 Range (ft)
1000
Max 1600 x 1200 Range (ft)
500
EDID Compatible
No
IR Remote Extension Support
No
RS-232 Serial Extension Support
No
Consumer Electronics Control (CEC)
Supported
No
USB Extension Support
No
CONNECTIONS
Number of Ports
2
Side A - Connector 1
HD15 (FEMALE)
Side B - Connector 1
(2) RJ45 (FEMALE)
FEATURES & SPECIFICATIONS
Driver Required
No
10/100 Ethernet Extension Support
No
Built-In Equalizer
No
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“B132-002-2”相匹配的价格&库存,您可以联系我们找货
