1000 Eaton Boulevard
Cleveland, OH 44122
United States
HDMI over Cat5/6 Extender Kit,
Transmitter/Receiver for Video/Audio, USB
Powered, Up to 125 ft. (38 m), TAA
Highlights
Supports high-definition video
resolutions up to 1080p (@ 60
Hz)
Supports stereo audio and
HDCP
Works with all operating
systems and HDMI sources
Built-in cable includes latching
HDMI connector for a more
secure connection
Plug and play—no software,
drivers or external power supply
Built-in equalization control lets
you adjust monitor image
MODEL NUMBER: B126-1A1-U
System Requirements
Computer, Blu-ray™ player or
other source with HDMI port
Display with HDMI port
Package Includes
Transmitter and receiver work in tandem to extend an HDMI audio/video signal via Cat5e/6 cable to an
HDMI display up to 125 ft. Ideal for digital signs, schools, retail settings and trade show presentations.
Transmitter unit
Receiver unit
(2) USB Micro-B to USB-A
cables, 3-ft. (0.91 m)
Screwdriver for adjusting
equalization
Owner's manual
Description
The B126-1A1-U HDMI over Cat5/Cat6 Active Extender Kit includes a transmitter unit and a receiver unit
that work in tandem to extend an HDMI audio/video signal to an HDMI projector, monitor or television. The
kit is ideal for digital signs, trade shows, presentations, classrooms, churches, retail settings and other
applications where the video source is located farther than conventional cables allow. A latching HDMI
connector on the built-in cable provides a more secure connection
The transmitter's built-in HDMI cable connects to the audio/video source, and the receiver's built-in HDMI
cable connects to the display. Cat5e/6 cable connects the two units (for best results, use 24 AWG solidwire Cat5e/6 cable, such as Tripp Lite's N202-Series). Each unit is powered by an included USB Micro-B
to USB-A cable, which must be connected between the unit and a USB port on the source device, display
or USB wall charger. You can also connect an optional HDMI monitor to the transmitter's local port with a
user-supplied HDMI cable, such as Tripp Lite's P568-Series.
The B126-1A1-U can extend a 1080p (@ 60 Hz) signal up to 125-ft. (38.1 m) with full, rich stereo. Built-in
RJ45 LEDs indicate the units are receiving power and a signal from the source. Built-in equalization
control lets you fine-tune the image quality at each remote display. Easy to set up with no software or
drivers to install. Works with all operating systems and HDMI sources.
Features
Extends HDMI Audio/Video Signals to an HDMI Display
● Extends a 1080p (@ 60 Hz) signal up to 125-ft. (38.1 m)
Ideal for digital signs, trade shows, presentations, classrooms, churches and retail settings
Transmitter and receiver connect with one Cat5e/6 cable (for best results, use 24 AWG solid-wire
Supports stereo audio and HDCP
Built-in equalization control lets you adjust the image on the remote display
Easy to Set Up and Use
● Plug-and-play engineering—no software, drivers or external power supply
Powered via included USB cables
1/5
Cleveland, OH 44122
United States
Units connect quickly to source and display with built-in HDMI cables
Built-in cable includes latching HDMI connector for a more secure connection
Optional local HDMI monitor connects to transmitter with user-supplied HDMI cable
LEDs indicate when units are receiving power and a signal from the source
TAA-Compliant
● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases
Specifications
OVERVIEW
UPC Code
037332190260
Product Type
Extender Kit
Technology
HDMI; Cat5/5e; Cat6
VIDEO
Max Supported Video Resolution
1920x1080 (1080p @ 60Hz)
Max 1280 x 720 (720p) Range (ft)
125
Max 1920 x 1080 (1080p) Range (ft)
125
Transmitter Video Input
HDMI
Transmitter - Number of Video
Outputs
1
Transmitter - Local Display Output
HDMI
Receiver/Transceiver Video Output
HDMI
Receiver - Number of Video Outputs
1
Range Extension using other Tripp
Lite product
175ft @ 1080i 125ft @ 1080p
Recommended Cabling
N202-Series Cat6 Patch Cable
Other Tripp Lite product used to
extend range
B126-110
Max Supported Color Depth
24-bit True Color
HDR Support
No
3D Video Supported
Yes
Chroma Sub Sampling
4:4:4
Maximum Signal Range (ft)
125
Maximum Signal Range (m)
38
AUDIO
2/5
Cleveland, OH 44122
United States
Audio Input
HDMI
Audio Output
HDMI
Audio Specification
Stereo Audio
INPUT
Bus Powered
No
Product Length (in.)
8.4
POWER
Power Source Type
USB
Power Source
Transmitter and Receiver (Included)
Power Over Cable (PoC) Support
No
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
TX & RX: Green (Power), Orange (Activity)
PHYSICAL
Color
Black
Material of Construction
Polycarbonate
Number of Displays
1
Form Factor/Mounting Options
Pigtail
Rackmountable
No
Receiver Unit Dimensions (hwd /
cm.)
2.4 x 6.1 x 5.2
Receiver Unit Dimensions (hwd / in.)
0.9 x 2.4 x 2
Receiver Unit Weight (kg)
0.07
Receiver Unit Weight (lbs.)
0.15
Shipping Dimensions (hwd / in.)
1.70 x 7.80 x 5.60
Shipping Dimensions (hwd / cm)
4.32 x 19.81 x 14.22
Shipping Weight (lbs.)
0.50
Shipping Weight (kg)
0.23
Transmitter Unit Dimensions (hwd /
cm.)
2.4 x 6.1 x 5.2
in.)
0.9 x 2.4 x 2
Transmitter Unit Weight (kg)
0.07
Transmitter Unit Weight (lbs.)
0.15
0.000 x 0.000 x 0.000
3/5
Cleveland, OH 44122
United States
Unit Packaging Type
Box
Housing
Plastic
ENVIRONMENTAL
Operating Temperature Range
32 to 104 °F (0 to 40 °C)
Storage Temperature Range
5 to 122 °F (-15 to 50 °C)
Relative Humidity
0% to 85%, Non-Condensing
COMMUNICATIONS
Signal Range (ft.)
125
Signal Range (m)
38
EDID Compatible
Yes
IR Remote Extension Support
No
RS-232 Serial Extension Support
No
Consumer Electronics Control (CEC)
Supported
Yes
USB Extension Support
No
CONNECTIONS
Side A - Connector 1
HDMI (MALE)
Side A - Connector 2
MICRO-USB B (FEMALE); RJ45 (FEMALE)
Side A - Connector 3
HDMI (FEMALE)
Side B - Connector 1
HDMI (MALE)
Side B - Connector 2
Connector Plating
Gold
FEATURES & SPECIFICATIONS
HDCP Specification
1.4
Driver Required
No
Recommended Category Cable
Cat5/Cat5e/Cat6 Cables
10/100 Ethernet Extension Support
No
Built-In Equalizer
Yes
STANDARDS & COMPLIANCE
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
4/5
Cleveland, OH 44122
United States
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
很抱歉,暂时无法提供与“B126-1A1-U”相匹配的价格&库存,您可以联系我们找货
