1000 Eaton Boulevard
Cleveland, OH 44122
United States
HDMI over Cat5/6 Extender Kit, Box-Style
Transmitter/Receiver for Video/Audio, Up to 150
ft. (45 m), TAA
MODEL NUMBER: B126-1A1
Highlights
Supports high-definition video
resolutions up to 1080p (60 Hz)
Supports stereo and 7.1channel surround sound audio
Works with all operating
systems and HDMI video
sources
Plug and play—no software or
drivers to install
Built-in equalization control lets
you adjust monitor image
System Requirements
Package Includes
Transmitter and receiver work in tandem to extend an HDMI signal via Cat5e/6 cable to a projector,
monitor or television. Ideal for digital signs, schools and trade show presentations.
Description
The B126-1A1 HDMI over Cat5/Cat6 Active Extender Kit includes a transmitter unit and a receiver unit
that work in tandem to extend an HDMI signal to a projector, monitor or television. The kit is ideal for
digital signs, trade shows, presentations, classrooms, churches, retail settings and other applications
where the source is located farther than conventional cables allow.
HDMI cable (see Tripp Lite's P568-Series) connects a monitor and the audio/video source to the
transmitter's HDMI ports and another monitor to the receiver. Cat5e/6 cable connects the two units (for
best results, use 24 AWG solid-wire Cat5e/6 cable, such as Tripp Lite's N202-Series).
The B126-1A1 can extend a 1080i (60 Hz) signal up to 200-ft. (60.96 m), a 1080p (60 Hz) signal up to
150-ft. (45.72 m) and a 3D signal up to 125-ft. (38.1 m). You can also connect up to three B126-110
remote repeaters in the chain (using Cat5e/6 cable) for a total of five HDMI displays and full signal
extension of 700-ft. (213.36 m) (1080i), 500-ft. (152.4 m) (1080p) or 400-ft. (121.92 m) (3D).
In addition to crystal-clear video, the B126-1A1 delivers full, rich stereo and 7.1-channel surround sound
(multi-channel or PCM) audio. Built-in equalization control lets you fine-tune the image quality at each
remote display. Supports 24-bit True Color (8 bits per channel) and HDCP. Easy to set up with no
software or drivers to install. Mounts to a wall, rack or pole using the included hardware.
Features
Extends High-Definition Signals
● Extends a 1080i (60 Hz) signal up to 200-ft. (60.96 m), a 1080p (60 Hz) signal up to 150-ft. (45.72 m)
Connect up to 3 B126-110 remote repeaters in between the transmitter and receiver for maximum
signal range of 700-ft. (213.36 m) (1080i), 500-ft. (152.4 m) (1080p) and 400-ft. (121.92 m) (3D)
Transmitter and receiver connect with one Cat5e/6 cable (for best results, use 24 AWG solid-wire
Supports stereo and 7.1-channel surround sound (multi-channel or PCM) audio
Built-in equalization control lets you adjust the image on the local monitor
1/5
Transmitter unit
Receiver unit
Screwdriver for adjusting
equalization
(2) External Power Supplies with
NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.5A; Output:
5V, 2A, 5-ft. (1.52 m)
Mounting hardware
Owner's Manual
Cleveland, OH 44122
United States
Easy to Set Up and Use
● Plug-and-play engineering—no software or drivers to download and install
Works with all operating systems and HDMI video sources
Units connect quickly to monitors with HDMI cable, such as Tripp Lite's P568-Series
LEDs indicate at a glance when the unit is receiving power and a signal from the previous link in the
chain
Included mounting hardware lets you install the units on a wall, rack or pole
TAA-Compliant
● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases
Specifications
OVERVIEW
UPC Code
037332158925
Product Type
Extender Kit
Technology
HDMI; Cat5/5e; Cat6
VIDEO
Video Input
HDMI (FEMALE)
Video Output
HDMI (FEMALE)
Max Supported Video Resolution
1920x1080 (1080p @ 60Hz)
Max 1280 x 720 (720p) Range (ft)
150
Max 1920 x 1080 (1080p) Range (ft)
150
Transmitter Video Input
HDMI
Transmitter - Number of Video
Outputs
1
Transmitter - Local Display Output
HDMI
Receiver/Transceiver Video Output
HDMI
Receiver - Number of Video Outputs
1
Range Extension using other Tripp
Lite product
175ft @ 1080i 125ft @ 1080p
Recommended Cabling
N202-Series Cat6 Patch Cable
Other Tripp Lite product used to
extend range
B126-110
Max Supported Color Depth
24-bit True Color
HDR Support
No
3D Video Supported
Yes
Chroma Sub Sampling
4:4:4
2/5
Cleveland, OH 44122
United States
Maximum Signal Range (ft)
150
Maximum Signal Range (m)
46
Maximum Signal Range Details
200 ft @ 1080i150 ft @ 1080p
AUDIO
Audio Input
HDMI; 3.5mm
Audio Output
HDMI
Audio Specification
Stereo Audio
INPUT
Bus Powered
No
POWER
Power Source Type
AC Adapter
External Power Supply Plug(s)
NEMA 1-15P North America
External Power Supply Input Specs
(V / Hz / A)
100-240V / 50/60Hz / 0.5A
External Power Supply Output
Specs (V / A)
5V / 2A
External Power Supply Cord Length
(ft.)
4.5
(m.)
1.37
AC Plug Type
NEMA 1-15P
Power Source
Transmitter and Receiver (Included)
Power Over Cable (PoC) Support
No
AC Adapter
Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5 ft.
DC Barrel Plug
OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
TX & RX: Green (Power), Orange (Activity)
PHYSICAL
Color
Black
Material of Construction
Steel
Included Mounting Accessories
Wallmount
Number of Displays
1
Optional Mounting Accessory Notes
Can DIN Mount using Tripp Lite Bracket B110-DIN-02
Form Factor/Mounting Options
Box; Wall-mount
3/5
Cleveland, OH 44122
United States
Rackmountable
Yes
Receiver Unit Dimensions (hwd /
cm.)
2.6 x 9.2 x 6.4
Receiver Unit Dimensions (hwd / in.)
1 x 3.6 x 2.5
Receiver Unit Weight (kg)
0.09
Receiver Unit Weight (lbs.)
0.2
Shipping Dimensions (hwd / in.)
2.20 x 6.20 x 8.30
Shipping Dimensions (hwd / cm)
5.59 x 15.75 x 21.08
Shipping Weight (lbs.)
1.70
Shipping Weight (kg)
0.77
Transmitter Unit Dimensions (hwd /
cm.)
2.6 x 9.2 x 6.4
in.)
1 x 3.6 x 2.5
Transmitter Unit Weight (kg)
0.09
Transmitter Unit Weight (lbs.)
0.2
0.000 x 0.000 x 0.000
Unit Packaging Type
Box
Housing
Metal
ENVIRONMENTAL
Operating Temperature Range
32 to 104 °F (0 to 40 °C)
Storage Temperature Range
5 to 122 °F (-15 to 50 °C)
Relative Humidity
0% to 85%, Non-Condensing
COMMUNICATIONS
Signal Range (ft.)
200
Signal Range (m)
61
EDID Compatible
Yes
IR Remote Extension Support
No
RS-232 Serial Extension Support
No
Consumer Electronics Control (CEC)
Supported
Yes
USB Extension Support
No
CONNECTIONS
Side A - Connector 1
(2) HDMI (FEMALE); RJ45 (FEMALE)
Side A - Connector 2
3.5MM (FEMALE)
4/5
Cleveland, OH 44122
United States
Side B - Connector 1
HDMI (FEMALE)
Side B - Connector 2
RJ45 (FEMALE)
FEATURES & SPECIFICATIONS
HDCP Specification
1.4
Driver Required
No
Recommended Category Cable
Cat5/Cat5e/Cat6 Cables
10/100 Ethernet Extension Support
No
Built-In Equalizer
Yes
STANDARDS & COMPLIANCE
External Power Supply Certifications
FCC; PSE; TUV;RoHS; UL; cUL
Product Compliance
RoHS; REACH; FCC (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
很抱歉,暂时无法提供与“B126-1A1”相匹配的价格&库存,您可以联系我们找货
