1000 Eaton Boulevard
Cleveland, OH 44122
United States
Switch - 4-Port Desktop KVM Switch (PS/2)
Highlights
KVM Switches control multiple
computers with 1 keyboard,
monitor and mouse console.
Simple plug-and-play setup. Full
compatibility will all major
operating systems and support
for most keyboards and mice
Adapters allow you to control
Mac or SUN computers through
any Tripp Lite PS/2 KVM Switch
Console Extender Kits keep a
keyboard/monitor/mouse
console highly accessible and a
KVM Switch and connected
computers highly secure,
located up to 500 ft. away.
Accepts two consoles: local
(primary) and remote
(secondary)
Simple to use switches and
adapters require no software or
system configurations
MODEL NUMBER: B004-004-R
Description
Tripp Lite's 4-port KVM Switch is the optimal solution for controlling up to 4 computers from one keyboard,
mouse and monitor. Switch between computers simply by entering an easy hot key combination on the
keyboard or by pushing the selector switch on the unit itself. The compact desktop design allows you to
put the switch within easy view so that you can see the status LEDs. Installation is a snap - just connect
the PCs to the switch using KVM cables. No software or complicated set-up procedures are required. The
switch will function without external power in most cases, however an AC power supply has been provided
in case additional power is needed (may be needed with a laptop PC). This PS/2 switch can be use to
control a USB, Sun or Mac computer when adding the appropriate adapter. Retail Box.
Features
Control up to 4 computers (combination of PS/2, Mac, Sun, & USB) from a single keyboard, mouse, and
monitor
Compact desktop design
Monitor connectors (HD15); Keyboard/Mouse ports (MiniDIN6)
Supports VGA, SVGA, or Multisync monitor
Does not require software or complicated set-up procedures
AC power supply provided for the few installations where external power is needed (usually when being
used with a notebook computer).
See "KVM Switch Cable Kits" for
required cables
Retail Packaging
Select computer directly from keyboard or by selector switch on the unit
Offers autoscan feature
Offers compatibility with most mice; including scrolling mice and wireless mice/keyboards
LEDs per port indicate which computer has been selected
Supports all current video resolutions.
Macintosh, SUN, and USB compatibility by connecting appropriate Tripp Lite console converter or
adapter
System Requirements
PS/2 mouse (or a USB mouse
with USB-to-PS/2 adapter)
PS/2 keyboard (or a USB or AT
keyboard with a PS/2 adapter)
PS/2 computer (or a Mac, Sun
or USB computer with
appropriate adapter).
1 x P753-006, P753-010, P754006, P754-010, or P754-015
KVM cable kit per port.
Package Includes
Specifications
OVERVIEW
UPC Code
037332116499
Product Rear View
B004-004-R-rear.pdf
PHYSICAL
1/2
B004-002-R 4-Port KVM Switch
AC Power Adapter
Manual
Cleveland, OH 44122
United States
Color
Black
Shipping Dimensions (hwd / in.)
3.50 x 11.25 x 7.75
Shipping Dimensions (hwd / cm)
8.89 x 28.58 x 19.68
Shipping Weight (lbs.)
2.50
Shipping Weight (kg)
1.13
CONNECTIONS
Number of Ports
4
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“B004-004-R”相匹配的价格&库存,您可以联系我们找货
