USB-C to DVI Adapter with PD Charging, White
Highlights
Supports USB DisplayPort
Alternate Mode for transmitting
video
Supports DVI video resolutions
up to 1920 x 1080 (1080p) @ 60
Hz
USB-C PD charging port
supports power input up to 20V
3A (60W)
Reversible USB-C plug
connects in either direction
Plug-and-play operation with no
software or drivers required
MODEL NUMBER: U444-06N-D-C
Applications
Connect to a DVI display via the
USB-C port on your laptop,
computer or tablet
Charge the host computer with
up to 20V/3A (60W) of power
Adds DVI and USB-C PD charging ports to the USB-C or Thunderbolt 3 port on your tablet, laptop,
notebook, MacBook, Chromebook, smartphone or PC.
System Requirements
Description
The U444-06N-D-C USB 3.1 Gen 1 USB-C to DVI Adapter expands the potential of your tablet, laptop,
Chromebook, MacBook, smartphone or PC’s USB-C or Thunderbolt 3 port. It’s ideal for transmitting
1080p video to a large display and powering and charging a PD Charging-compliant mobile device—all at
the same time.
With a source device that also supports USB DisplayPort Alternate Mode, you can extend video from your
primary display to another, duplicate the same video on both displays, or change the second display to
your primary.
The plug-and-play U444-06N-D-C requires no software, drivers or external power. Connect the reversible
USB-C plug to your source device’s USB-C or Thunderbolt 3 port. The fumble-free USB-C plug connects
in either direction to ensure fast, easy connection every time.
To send HD video to a DVI television, projector or monitor, connect the DVI port to the display using a DVI
cable (sold separately). The port supports DVI single-link video resolutions up to 1920 x 1080 (1080p) at
60 Hz and DVI digital transfer rates up to 6.75 Gbps (2.25 Gbps per channel).
The USB-C Power Delivery (PD) port provides power and charging to the PD Charging-compliant device
(such as a MacBook or Chromebook) the U444-06N-D-C is connected to. Connect the device’s AC wall
charger to the USB-C PD port, which supports power input up to 20V 3A (60W).
Features
Turn Your Device's USB-C Port into a Multiport WorkstationIdeal for transmitting video to a large
display and powering and charging a PD Charging-compliant mobile device simultaneouslyPlug-and-play
operation with no software, drivers or external power requiredSmaller than a credit card for easy carrying
in a pocket, purse or laptop bag
Transmit Crystal-Clear 1080p Video to DVI DisplayCompatible with USB-C or Thunderbolt 3 source
devices that support USB DisplayPort Alternate ModeSupports DVI single-link video resolutions up to
1920 x 1080 (1080p) @ 60 HzSupports DVI digital transfer rates up to 6.75 Gbps (2.25 Gbps per
channel)Extends video from your primary display to anotherDuplicates the same video on 2
displaysConverts a secondary display to your primary display
Charge a Connected DeviceUSB-C PD port connects to wall charger to power and charge the
connected PD Charging-compliant USB-C/Thunderbolt 3 deviceSupports power input up to 20V 3A
(60W)Note: USB-C PD port does not support Quick Charge (QC).
1/4
Source device with USB-C or
Thunderbolt 3 port that supports
Mode
Display device with DVI input
(DVI port)
Package Includes
Owner’s manual
Specifications
OVERVIEW
UPC Code
037332193896
Technology
DVI
Host Connector
USB C (MALE)
VIDEO
Video Input
USB C (MALE)
Video Output
DVI-I DUAL LINK (FEMALE)
Number of Monitors Supported
1
Video Ports
Resolutions Supported
1920 X 1080 (1080P) @ 60HZ
Supported Resolutions
1920x1080 (1080p)
Max Supported Video Resolution
HDR Support
No
3D Video Supported
No
AUDIO
Audio Specification
Pass-through audio
INPUT
Built-In Cable Length (ft.)
0.36
Built-In Cable Length (m)
11.0
Built-In Cable Length (in.)
4.33
Bus Powered
Yes
Product Length (in.)
6
Product Length (cm.)
15.24
Product Length (ft.)
0.5
Product Length (m.)
0.15
BATTERY
Battery Charging (5V/1.5A Port)
No
POWER
USB Power Delivery (PD) Charging
Support
Yes
2/4
Specification
2.0
CHARGING
Number of Charging Ports
1
Total Charging Watts
60
Charging Method
AC
Charging Port Type
USB C (FEMALE)
Charging Ports Details
Charge the host PC with up to 20V/3A (60W) of power
Charging Ports
USB-C: 60W (20V 3A) Power Delivery (PD 2.0)
Charging Ports / Amps
3A
Charging Amps per Port
3
PHYSICAL
Color
White
Material of Construction
PVC, ABS
Cable Jacket Rating
VW-1
Number of Displays
1
Shipping Dimensions (hwd / cm)
2.03 x 9.91 x 12.19
Shipping Dimensions (hwd / in.)
0.80 x 3.90 x 4.80
Shipping Weight (kg)
0.14
Shipping Weight (lbs.)
0.30
Unit Dimensions (hwd / in.)
0.55 x 2.3 x 1.6
Unit Packaging Type
Box
Unit Weight (lbs.)
0.07
Unit Weight (kg)
0.03
ENVIRONMENTAL
Operating Temperature Range
32 to 113 F (0 to 45 C)
Storage Temperature Range
14 to 158 F (-10 to 70 C)
BTUs
2.1 BTU/Hr
Power Consumption (Watts)
0.6
Operating Humidity Range
10% to 85% RH, Non-Condensing
Storage Humidity Range
5% to 90% RH, Non-Condensing
Power Provided to Connected
Device(s)
20V/3A (60W) Host PC Charging
CONNECTIONS
3/4
Ports
2
Side A - Connector 1
USB C (MALE)
Side B - Connector 1
Side B - Connector 2
USB C (FEMALE)
Connector Plating
Nickel
FEATURES & SPECIFICATIONS
HDCP Specification
1.2
USB Specification
USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps)
Driver Required
No
Multi-Resolution Support
No
STANDARDS & COMPLIANCE
Certifications
CE, FCC, RoHS, REACH
WARRANTY
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2021 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
4/4
很抱歉,暂时无法提供与“U444-06N-D-C”相匹配的价格&库存,您可以联系我们找货
