USB 3.0 SuperSpeed to VGA Adapter, 512MB
SDRAM - 2048x1152,1080p
MODEL NUMBER: U344-001-VGA
Highlights
Add an additional VGA monitor
through a single USB 3.0 port
Up to six adapters can be added
to one computer
Features 512MB DDR2 SDRAM
of memory
Supports video resolutions up to
2048 x 1152 (60Hz), 1080p
(60Hz)
Windows and Intel Mac
compatible
Compatible with Ubuntu 14.04.2
System Requirements
Compatible with Windows 7 and
later. Supports both 32- and 64bit.
Supports Surface tablets
running non-RT Windows 8 and
8.1
Compatible with Intel Mac OS X
10.8.5 and later. Supports both
32- and 64-bit.
Reference the owner's manual
for system requirements when
using multiple adapters or when
using the add-on monitor for
DVD playback.
Description
Tripp Lite's U344-001-VGA USB 3.0 to VGA Multi Monitor External Video Adapter allows you to connect
an additional monitor or projector to a computer/laptop's USB 3.0 port. Up to six adapters can be used
simultaneously, allowing the user to connect up to six additional monitors to a single computer. Once the
installation is done, the computer screen appears on the add-on monitor(s) without the hassle of function
keys to swap to a second monitor. Supports video resolutions up to 2048 x 1152 (60Hz), 1080p (60Hz).
Windows and Intel Mac compatible.
Package Includes
Features
(1) U344-001-VGA USB 3.0 to
VGA Adapter
Use up to six adapters simultaneously, adding up to six additional monitors to a single computer
(1) Driver CD
View large spreadsheets across multiple screens by extending video amongst all monitors
(1) Owner's Manual
Play video on one monitor while working on another
Do multiple screen presentations from a laptop computer
Bus powered...no external power adapter needed
Features 512MB DDR2 SDRAM of memory
Compatible with Windows 7 and later. Supports both 32- and 64-bit.
Supports Surface tablets running non-RT Windows 8 and 8.1
Compatible with Intel Mac OS X 10.8.5 and later. Supports both 32- and 64-bit.
Uses DisplayLink DL3100 chipset
Add an additional VGA monitor through a single USB 3.0 port
Specifications
OVERVIEW
UPC Code
037332186355
1/3
Technology
VGA/SVGA
VIDEO
Max Supported Video Resolution
INPUT
Bus Powered
Yes
Product Length (in.)
8
POWER
Power Consumption (Watts)
1.3
PHYSICAL
Material of Construction
ABS, PVC
Color
Black
Cable Jacket Rating
VW-1
Shipping Dimensions (hwd / in.)
5.20 x 5.20 x 0.91
Shipping Weight (lbs.)
0.12
Unit Dimensions (hwd / in.)
0.6 x 1.7 x 2.5
Unit Packaging Type
Box
Unit Weight (lbs.)
0.06
Unit Weight (kg)
0.03
ENVIRONMENTAL
Operating Temperature Range
32 to 104 F (0 to 40 C)
Storage Temperature Range
-4 to 140 F (-20 to 60 C)
Relative Humidity
10% to 90 % RH, Non-Condensing
BTUs
4.4 BTU/Hr
CONNECTIONS
Side A - Connector 1
USB 3.0 A (MALE)
Side B - Connector 1
HD15 (FEMALE)
Connector Plating
Nickel
FEATURES & SPECIFICATIONS
USB Specification
USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps)
Driver Required
Yes
2/3
STANDARDS & COMPLIANCE
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA)
WARRANTY
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
3/3
很抱歉,暂时无法提供与“U344-001-VGA”相匹配的价格&库存,您可以联系我们找货
