2-Port DB9 (RS-232) Serial PCI Card with 16550
UART, Full Profile
MODEL NUMBER: PCI-D9-02
Highlights
Each port supports data transfer
rates up to 115.2 Kbps
Complies with PCI Local Bus
Specification Revision 2.3
Compatible with universal 3.3V
and 5V 32-bit PCI/PCI-X slots
Compatible with industrial
standard 16550 UART
Works with Windows® and
Linux®
System Requirements
Computer with available
universal 3.3V and 5V 32-bit
PCI/PCI-X slot
Windows (XP and later) or Linux
(2.6.x and later)
Package Includes
PCI-D9-02 2-Port DB9 Serial
PCI Card with 16550 UART, Full
Profile
Driver CD
Owner’s manual
Adds 2 DB9 serial ports to your PCI computer or server or replaces existing DB9 ports.
Description
The PCI-D9-02 2-Port DB9 Serial PCI Card adds two DB9 serial ports to your computer or server. By
adding the PCI-D9-02 to a computer with no DB9 ports or not enough of them, you can upgrade your DB9
capability without having to buy a new computer.
Perfect for home or office, the PCI-D9-02 supports data transfer rates up to 115.2 Kbps on each port. It
easily installs inside your computer in just a few minutes. The standard bracket’s interface is compatible
with universal 3.3V and 5V 32-bit PCI/PCI-X slots. Allow the appropriate drivers to automatically install on
your hard drive (a driver CD is included if they don’t), and connect DB9 serial extension cables (such as
Tripp Lite’s P520-006) to the card’s DB9 connectors.
The PCI-D9-02 is fully compliant with PCI Local Bus Specification Revision 2.3 and compatible with
industrial standard 16550 UART. On-chip 256-byte depth FIFO in transmit and receive paths of each port.
Supports hardware and software flow control; PCI IRQ sharing and PCI power management; 5-, 6-, 7-, 8and 9-bit serial formats; Even, Odd, None, Space and Mark parity; and 1- or 2-stop bit operation.
Features
Adds 2 DB9 (RS-232) Serial Ports to Your Computer
● Upgrades your DB9 capability without buying a new computer or server
Each port supports data transfer rates up to 115.2 Kbps
Perfect for home or office use
Easy to Install Inside Your Computer
● Compatible with universal 3.3V and 5V 32-bit PCI/PCI-X slots
Appropriate drivers install to your hard drive automatically
Loaded with the Latest Features
● Complies with PCI Local Bus Specification Revision 2.3
Compatible with industrial standard 16550 UART
1/2
Supports PCI IRQ sharing and PCI power management
Supports 5-, 6-, 7-, 8- and 9-bit serial formats
Supports Even, Odd, None, Space and Mark parity
Supports 1- or 2-stop bit operation
Specifications
OVERVIEW
UPC Code
037332193681
PHYSICAL
Color
Red
Cable Length (ft.)
Cable Length (m)
0.00
Shipping Dimensions (hwd / cm)
2.54 x 12.70 x 14.73
Shipping Dimensions (hwd / in.)
1.00 x 5.00 x 5.80
Shipping Weight (kg)
0.09
Shipping Weight (lbs.)
0.20
CONNECTIONS
Number of Ports
2
WARRANTY
Product Warranty Period
(Worldwide)
2-year limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“PCI-D9-02”相匹配的价格&库存,您可以联系我们找货
