F201-003
F201-003
    TRIPPLITE
    CARD IEEE1394 FIREWIRE PCI
F201-003 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States FireWire ® - 3-Port IEEE 1394 Firewire PCI Card Highlights ● Provides 3 active 6-pin Firewire ports ● Meets IEEE 1394 standards set by the Institute of Electrical and Electronic Engineers ● Fully supports version 2.0 of the IEEE 1394 standard for highspeed serial bus communication ● 100% Plug and Play compatible - Devices can be added or removed without restarting the computer ● Supports up to 63 connected Firewire devices MODEL NUMBER: F201-003 Description Tripp Lite's IEEE 1394 Firewire 3 Port PCI Card provides your PC with 3 high-speed Firewire ports. Once this card has been installed in your PC you will have a simple and easy way to connect up to three IEEE 1394 Firewire devices. Connecting DV camcorders, hard disk drives, removable drives, scanners, printers, and other 1394 A/V devices including TVs, VCRs and DVDs will be a breeze. Supports data transfer rates up to 400Mb/s. The flexible 3-and-1 design also provides an internal port in case you are using an internal Firewire device such as a hard drive. Tripp Lite warrants this product to be free from defects in materials and workmanship for life. Features ● Provides 3 active 6-pin Firewire ports ● 3rd port can be internal or external ● Meets IEEE 1394 standards set by the Institute of Electrical and Electronic Engineers ● Provides three fully 1394-compliant ports at 100, 200 and 400 Mbps ● 100% compliant with open host controller interface (OHCI) requirements ● 100% Plug and Play compatible - Devices can be added or removed without restarting the computer ● Supports up to 63 connected Firewire devices ● Peer to Peer communication structure ● Tripp Lite warrants this product to be free from defects in materials and workmanship for life Package Includes Specifications OVERVIEW UPC Code 037332096203 Technology FireWire PHYSICAL Color Silver Cable Length (ft.) 0 Cable Length (m) 0.00 Shipping Dimensions (hwd / in.) 9.50 x 6.50 x 2.50 Shipping Dimensions (hwd / cm) 24.13 x 16.51 x 6.35 Shipping Weight (lbs.) 0.66 Shipping Weight (kg) 0.30 CONNECTIONS Number of Ports 3 Side B - Connector 1 (3) 6 PIN (FEMALE) 1/2 ● IEEE 1394 Firewire PCI Card - 3 Port 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
F201-003 价格&库存
很抱歉,暂时无法提供与“F201-003”相匹配的价格&库存,您可以联系我们找货
